查看: 3463|回复: 0
uC/OS-II, The Real-Time Kernel Version 2.52
全部资料51hei下载地址:
uCOS-II.zip (1.6 MB, 下载次数: 14)
                                Companion CD
                                Version 2.52
                                READ ME FILE
****************************** TABLE OF CONTENTS *****************************
1) Reporting problems
2) Software Upgrades
3) Release Notes
/*$PAGE*/
***************************** REPORTING PROBLEMS *****************************
    If  you find a problem (i.e. bug) in uC/OS-II, do not hesitate  to  report
the problem to either:
1) Through the INTERNET:
        My INTERNET address is:
2) By writing to me at:
        Micrium, Inc.
        949 Crestview Circle
        Weston, FL 33327
        U.S.A.
        c/o: Jean J. Labrosse
3) By calling Micrium, Inc.:
        (954) 217-2036
        (954) 217-2037, FAX
    Make sure that the problem you are  reporting is in  uC/OS-II and not your
application.    If you in fact discover a bug in uC/OS-II, check the  uC/OS-II
web site for a list of known bugs and their fixes:
    www.uCOS-II.com
    If you are  using  an  older  version,  you should  first  get the lastest
version.
/*$PAGE*/
****************************** SOFTWARE UPGRADES *****************************
    As you can see, I have been trying to support uC/OS (i.e. V1.xx) and  now,
uC/OS-II.  When bugs are found, I do my best to promptly correct them.   It is
virtually  impossible  to notify  everybody that  purchased the code (i.e. the
diskette)  to  tell  them  that  a  new  version  is  available.    You should
occasionally check the uC/OS-II WEB site (www.ucos-ii.com) or the  Micrium web
site to see what version is currently shipping.
    I will not be  upgrading the  publisher  everytime  I add new  features to
uC/OS-II.
    I  would  highly  suggest that you resist changing the  STYLE  of the code
unless you don't mind spending many hours doing so everytime you upgrade.
/*$PAGE*/
********************************  RELEASE NOTES  *****************************
1) RELEASE NOTES:
   The release notes are now provided in PDF format in the file:
    \SOFTWARE\uCOS-II\DOC\RelV252.PDF
2) FEATURES SINCE V2.00:
   All the features added since V2.00 are described in the PDF file:
    \SOFTWARE\uCOS-II\DOC\NewV252.PDF
3) QUICK REFERENCE CHART:
   A Quick Reference Chart for all the functions in V2.52 is provided in the
   following .PDF files:
    \SOFTWARE\uCOS-II\DOC\QuickRefChartV252-Color.PDF
   Once printed, simply FOLD the page in half and if you have a LAMINATION
   machine, you can protect the chart by laminating it.
