查看: 8240|回复: 0
基于51单片机的4*4矩阵键盘扫描
ID:324067 发表于 2018-5-7 14:23 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define GPIO_KEY P1
uchar keynum = 0;
uchar KeyValue;
bit flag = 0;
uchar code ascii[]=
{0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
/*4*4矩阵键盘按键扫描*/
void KeyDown()
        char a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//读取按键是否按下
                delay(10);//延时10ms进行消抖
                if(GPIO_KEY!=0x0f)//再次检测键盘是否按下
                //测试列
                        GPIO_KEY=0X0F;
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d):   KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //测试行
                        GPIO_KEY=0XF0;
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //检测按键松手检测
                                delay(10);
                                a++;
[size=44.3333358764648px]void main()        //对应键盘键值显示 *=14 #=15
        EA = 1;
        EX0 = 1;
        IT0 = 1;
                GPIO_KEY=0x0f;
                if(flag==1)
                        KeyDown();
                        keynum = LED[KeyValue];
                        flag = 0;
void interrupt_0() interrupt 0
        EX0 = 0;
        flag = 1;
        EX0 = 1;
