查看: 2674|回复: 0
基于单片机的数字温度计
ID:325078 发表于 2018-5-8 15:15 | 显示全部楼层 |阅读模式
#include<reg52.h>
uchar code table[]="  hello!jasper  ";
uchar code table1[]="   xm.dabiao    ";
uchar code aa[]=" 2018-4-13 MON ";
uchar code bb[]="    14:30:00    ";
sbit lcden=P2^;
sbit lcdrs=P2^;
sbit dula=P2^6;
sbit wela=P2^7;
//sbit FM=P2^3;
uchar count;
char miao,fen=31,shi=14;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
lcdrs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
dula=0;
wela=0;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80+0x10);
for(num=0;num<16;num++)
   write_date(table[num]);
   delay(10);
write_com(0x80+0x51);
   write_date(table1[num]);
   delay(10);
  write_com(0x18);
  delay(160);
delay(1800);
void pingxian(void)
uchar num_x;
delay(500);
write_com(0x01);
write_com(0x80);
for(num_x=0;num_x<16;num_x++)
   write_date(aa[num_x]);
   delay(20);
write_com(0x80+0x40);
delay(5);
   write_date(bb[num_x]);
   delay(20);
delay(300);
void inittime(void)
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
// shi=0;
// fen=2;
// miao=59;
void didi(di_num)
  uchar d;
  for(d=di_num;d>0;d--)
   FM=0;
   delay(70);
   FM=1;
   delay(30);
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void main(void)
init();
pingxian();
inittime();
void timer0() interrupt 1
count++;
     if(count==19)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
基于单片机及时钟芯片DS1302的电子时钟设计.pdf
409.88 KB, 下载次数: 5, 下载积分: 黑币 -5
