查看: 3202|回复: 0
PE43702引脚图与pdf资料手册下载
认真学习avr,首先可以学习ardunio
PE43702引脚图:
PE43702管脚功能定义:
The PE43702 is a HaRP™-enhanced, high linearity, 7-bit RF
Digital Step Attenuator (DSA).  This highly versatile DSA
covers a 31.75 dB attenuation range in 0.25 dB steps.  The
Peregrine 50Ω RF DSA provides both a serial and parallel
CMOS control interface.  It maintains high attenuation accuracy
over frequency and temperature and exhibits very low insertion
loss and low power consumption.  Performance does not
change with Vdd due to on-board regulator. This next
generation Peregrine DSA is available in a 4x4 mm 24 lead QFN footprint.
The PE43702 is manufactured on Peregrine’s UltraCMOS™
process, a patented variation of silicon-on-insulator (SOI)
technology on a sapphire substrate, offering the performance
of GaAs with the economy and integration of conventional
CMOS.
Product Description
完整的pdf格式文档51黑下载地址:
PE43702.pdf (465.35 KB, 下载次数: 10)
