查看: 7285|回复: 4
16X16的LED点阵屏可实现左移,右移、单片机源码及仿真图等资料
ID:326016 发表于 2018-5-9 16:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>//头文件
sbit shcp=P1^2;//数据输入时钟线 59511
sbit stcp=P1^1;//输出存储器锁存时钟线 59512
sbit ds=P1^0;//数据线  59514
sbit s1=P3^1;//按下暂停再暂按继续
sbit s2=P3^2;//按下方向取反
bit fx;//方向切换
unsigned char alt;//数据移动定时时间
unsigned int net;//控制显示的字符
unsigned char zi=8;
unsigned int zong;//总字符  (所有的字数+1*32   字数指的是汉字,字母、数字两个算一个数字
unsigned char code tab[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//(0) (1) (2) (3) (4) (5) (6) (7)
0x04,0x08,0x04,0x10,0x24,0x20,0x24,0x40,0x24,0xFC,0x24,0xA2,0xFD,0x22,0x26,0x22,
0x24,0x42,0x2C,0x42,0x14,0x42,0x24,0x82,0x44,0x1E,0x04,0x00,0x04,0x00,0x00,0x00,/*"",0*/
0x00,0x00,0x3F,0xE1,0x00,0x02,0x00,0x0C,0xFF,0xF0,0x00,0x00,0x40,0x00,0x47,0xF8,
0x44,0x00,0x44,0x00,0x7F,0xFF,0x44,0x10,0x44,0x08,0x47,0xF0,0x40,0x00,0x00,0x00,/*"",1*/
0x00,0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"",2*/
0x04,0x02,0x08,0x0C,0x10,0x00,0x3F,0xEE,0xC4,0x01,0x08,0x81,0x11,0x11,0xE6,0x4D,
0x20,0x21,0x2F,0xC1,0x20,0x01,0x24,0x07,0x2A,0x00,0x31,0x88,0x00,0x06,0x00,0x00,/*"",3*/
0x02,0x00,0x02,0x20,0x22,0x20,0x22,0x20,0x2A,0x20,0x26,0x20,0xA2,0x20,0x63,0xFF,
0x22,0x20,0x26,0x20,0x2A,0x20,0x22,0x20,0x22,0x20,0x02,0x20,0x02,0x00,0x00,0x00,/*"",4*/
0x21,0x00,0x21,0x00,0x21,0x00,0x21,0x3F,0xF9,0x22,0x21,0x22,0x21,0x22,0x2F,0xE2,
0x21,0x22,0x21,0x22,0xF9,0x22,0x21,0x3F,0x21,0x00,0x21,0x00,0x21,0x00,0x00,0x00,/*"",5*/
0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x02,0x40,0x01,0x47,0xFE,
0x44,0x00,0x48,0x00,0x50,0x00,0x60,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"",6*/
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"",7*/
unsigned char code tab1[]={
void delay(unsigned int z)//延时子函数
   unsigned char x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void writedata(unsigned char dat1,unsigned char dat2)         //595显示子函数
        unsigned char i;
        //CY存储移位之后的数据  CY进位标志位,单片机内部的寄存器   移位之后的数据就存在CY里面
        for(i=0;i<8;i++)//循环八次
                dat1=dat1<<1;//数据左移
                ds=CY;//数据发送
                shcp=1;//上升沿发生移位
                shcp=0;
                dat2=dat2<<1;//数据左移
                ds=CY;//数据发送
                shcp=1;//上升沿发生移位
                shcp=0;
        stcp=0;
        stcp=1;//上升沿将数据送到输出锁存器
        stcp=0;
void main()         //主函数
        char i,aa;
        TMOD=0x01;//定时器0  模式1  16位定时模式
        TH0=(65536-10000)/256;//定时10.000ms
        TL0=(65536-10000)%256;
        ET0=1;//使能定时器0
        EA=1;//开启总中断
        TR0=1;//开始计数
        zong=(zi+1)*32;
        while(1)         //无限循环
                if(s1==0)//检测按键
                        delay(30);//延时消除按键抖动
                        if(s1==0)
                                TR0=~TR0;//按下暂停  暂按继续
                                while(s1==0);//等待按键松手
                if(s2==0)//检测按键
                        if(s2==0)
                                fx=~fx;//方向取反
                                aa=0;
                                if(fx==0)net=0;//正向移动
                                if(fx==1)net=zong;//反向移动
                                while(s2==0);//等待按键松手
                for(i=0;i<16;i++)//循环移位
                        //两片138组成的4-16线译码器
                        P2=i;//列数据驱动,138的驱动端口
                        if(fx==0)writedata(tab[net+aa],tab[net+aa+1]);//显示数据的数字位置
                        if(fx==1)writedata(tab1[net+aa],tab1[net+aa+1]);//显示数据的数字位置
                        delay(3);//延时
                        writedata(0,0);//清屏
                        aa+=2;//数据加 实现扫描
                        if(aa>30)aa=0;//循环16次 清零
void timer0() interrupt 1
        TH0=(65536-10000)/256;//10.000ms   进入一次中断
        alt++;
        if(alt==10)//100.000ms时间加以实现移动
                alt=0;
                if(fx==0)//正向移动
                        net=net+2;        //每次送两个编码数据
                        if(net>zong)//达到总字符
                        net=0;//数据清零
                else//否则反向移动
                        net=net-2;//每次送两个编码数据
                        if(net<2)//数据完毕
                        net=zong;//回到总字符
1程序 老师 您辛苦了.zip
69.24 KB, 下载次数: 109, 下载积分: 黑币 -5
源码
收藏收藏4 分享淘帖 顶1 踩
ID:352628 发表于 2018-7-19 17:56 | 只看该作者
仿真呢?
ID:378732 发表于 2018-9-19 16:05 | 只看该作者
学习下下。。
ID:241596 发表于 2018-12-22 12:49 | 只看该作者
无仿真与电路原理图
ID:443646 发表于 2019-1-4 16:09 | 只看该作者
仿真硬件图有没有
