查看: 1258|回复: 0
安卓应用
ID:218332 发表于 2018-5-10 13:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
package com.example.computer.myapplication;
import android.app.DatePickerDialog;
import android.content.DialogInterface;
import android.support.v7.app.AlertDialog;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.widget.DatePicker;
import android.widget.EditText;
import android.widget.LinearLayout;
import android.widget.Toast;
public class MainActivity extends AppCompatActivity {
    LinearLayout xingming;
    EditText editText_xingming;
    String string_xingming;
    int m_year=2016,m_month=9,m_day=1;
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        super.onCreateOptionsMenu(menu);
        menu.add(1,//组号
                1,// 唯一ID
                1,//排序号
                "姓名" );
        menu.add(1,2,2,"入学日期");
        menu.add(1,3,3,"照片");
        return super.onCreateOptionsMenu(menu);
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        AlertDialog.Builder dialog = new AlertDialog.Builder(MainActivity.this);
        switch (item.getItemId()) {
            case 1:
                xingming = (LinearLayout) getLayoutInflater().inflate(R.layout.xingming, null);
                editText_xingming = (EditText) xingming.findViewById(R.id.editText_xingming);
                dialog.setView(xingming);
                dialog.setTitle("输入姓名");
                dialog.setPositiveButton("确定", new okClick());
                dialog.setNegativeButton("取消", new noClick());
                dialog.create().show();
                break;
            case 2:
                DatePickerDialog.OnDateSetListener dateSetListener=new DatePickerDialog.OnDateSetListener() {
                    @Override
                    public void onDateSet(DatePicker view, int year, int month, int dayOfMonth) {
                        m_year=year;
                        m_month=month;
                        m_day=dayOfMonth;
                        Toast.makeText(MainActivity.this,m_year+"年"+m_month+"月"+m_day+"日",Toast.LENGTH_SHORT).show();
                //创建日期对话框对象
                DatePickerDialog date= new DatePickerDialog(MainActivity.this,dateSetListener,m_year,m_month,m_day);
                date.setTitle("日期对话框");
                date.show();
                break;
            case 3:
                Toast.makeText(this, string_xingming, Toast.LENGTH_SHORT).show();
                break;
        return super.onOptionsItemSelected(item);
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
    class okClick implements DialogInterface.OnClickListener{
        @Override
        public void onClick(DialogInterface dialog, int which) {
            string_xingming=editText_xingming.getText().toString();
    class noClick implements DialogInterface.OnClickListener{
        @Override
            dialog.cancel();//关闭对话框
//                        Intent intent = new Intent(MainActivity.this,Main2Activity.class);
//                        Bundle bundle = new Bundle();
//                        bundle.putString("txt",m_year+"年"+m_month+"月"+m_day+"日");
//                        intent.putExtras(bundle);
//                        startActivity(intent);
