查看: 5235|回复: 7
12864字模软件怎么用?为什么提取出来的代码和教程中的代码不一样,也不能显示
ID:322094 发表于 2018-5-12 21:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  这是字模软件提取的,不能显示
/*--  文字:  普  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,0x00,
0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,0x00,
/*--  文字:  中  --*/
0x00,0x00,0xF0,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0xF0,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x0F,0x00,0x00,0x00,
/*--  文字:  科  --*/
0x24,0x24,0xA4,0xFE,0xA3,0x22,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,
0x08,0x06,0x01,0xFF,0x00,0x01,0x04,0x04,0x04,0x04,0x04,0xFF,0x02,0x02,0x02,0x00,
/*--  文字:  技  --*/
0x10,0x10,0x10,0xFF,0x10,0x90,0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x08,0x00,
0x04,0x44,0x82,0x7F,0x01,0x80,0x80,0x40,0x43,0x2C,0x10,0x28,0x46,0x81,0x80,0x00,
    下面是教程中的代码,可以显示出
/*--  文字:  普  --*/
"普",0x00,0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,
0x00,0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,
/*--  文字:  中  --*/
"中",0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
/*--  文字:  科  --*/
"科",0x00,0x00,0x00,0xFF,0x00,0x00,0xCC,0x22,0x00,0x91,0x51,0xFE,0x72,0x92,0x12,0x10,
0x00,0x01,0x01,0xFF,0x02,0x02,0x02,0x04,0x04,0x04,0x00,0xFF,0x00,0x01,0x02,0x04,
/*--  文字:  技  --*/
"技",0x00,0x08,0x48,0xC8,0x48,0x7F,0x48,0x48,0xC8,0x00,0x28,0x48,0xFF,0x88,0x08,0x08,
0x00,0x20,0x60,0x21,0x12,0x0C,0x0C,0x13,0x20,0x40,0x40,0x00,0x7F,0x80,0x41,0x01,
ID:303383 发表于 2018-5-12 23:42 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:155507 发表于 2018-5-13 08:10 | 只看该作者
你好:
不是不能显示,而是取模的设置不对。
汉字取模时,有C51格式和A51格式,上下颠倒、左右颠倒设置,仔细看看。
希望我的回答能帮助到你。
ID:322094 发表于 2018-5-13 12:21 | 只看该作者
angmall 发表于 2018-5-13 08:10
你好:
不是不能显示,而是取模的设置不对。
汉字取模时,有C51格式和A51格式,上下颠倒、左右颠倒设置, ...
用的c51格式,然后上下颠倒、左右颠倒都试过了,都和教程中的不一样,也不能显示
ID:328365 发表于 2018-7-18 18:46 | 只看该作者
我和您是一样的问题,请问最后您解决了吗?是怎么解决的?
ID:96920 发表于 2019-7-1 22:36 | 只看该作者
你是用什么取模工具做的
ID:579424 发表于 2019-7-7 17:10 | 只看该作者
点阵读取16进制是竖着读,取模软件是横着。把要写的内容顺时针90写就行了
ID:421308 发表于 2019-7-12 09:04 | 只看该作者
网上有教程的,一般都是倒序,
