查看: 2040|回复: 1
MSP430I2C oled程序这个程序怎么编啊 求大神指导
ID:328885 发表于 2018-5-13 15:03 | 显示全部楼层 |阅读模式
//P1.7 为 OLED 数据信号, P1.6 为 OLED 时钟信号
#define SDA_H P1OUT |= BIT7 //SDA = 1
#define SDA_L P1OUT &=~ BIT7 //SDA = 0
#define SCL_H P1OUT |= BIT6 //SCL = 1
#define SCL_L P1OUT &=~ BIT6 //SCL = 0
#define Brightness 0xFF
#define X_WIDTH 128
#define Y_WIDTH 64
/****************************************8*16的点阵************************************/
const unsigned char Hzk[][32]={
{0x00,0x00,0xF0,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0xF0,0x00,0x00,0x00},
{0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x0F,0x00,0x00,0x00},/*"中",0*/
{0x40,0x40,0x40,0x5F,0x55,0x55,0x55,0x75,0x55,0x55,0x55,0x5F,0x40,0x40,0x40,0x00},
{0x00,0x40,0x20,0x0F,0x09,0x49,0x89,0x79,0x09,0x09,0x09,0x0F,0x20,0x40,0x00,0x00},/*"景",1*/
{0x00,0xFE,0x02,0x42,0x4A,0xCA,0x4A,0x4A,0xCA,0x4A,0x4A,0x42,0x02,0xFE,0x00,0x00},
{0x00,0xFF,0x40,0x50,0x4C,0x43,0x40,0x40,0x4F,0x50,0x50,0x5C,0x40,0xFF,0x00,0x00},/*"园",2*/
{0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00},
{0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},/*"电",3*/
{0x80,0x82,0x82,0x82,0x82,0x82,0x82,0xE2,0xA2,0x92,0x8A,0x86,0x82,0x80,0x80,0x00},
{0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"子",4*/
{0x24,0x24,0xA4,0xFE,0xA3,0x22,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,0x00},
{0x08,0x06,0x01,0xFF,0x00,0x01,0x04,0x04,0x04,0x04,0x04,0xFF,0x02,0x02,0x02,0x00},/*"科",5*/
{0x10,0x10,0x10,0xFF,0x10,0x90,0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x08,0x00},
{0x04,0x44,0x82,0x7F,0x01,0x80,0x80,0x40,0x43,0x2C,0x10,0x28,0x46,0x81,0x80,0x00},/*"技",6*/
/*********************OLED 延时函数 ***********************/
void delay(unsigned int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y=1330;y>0;y--);
void IIC_Start()
P1DIR |=BIT6;
SCL_H;
SDA_H;
SDA_L;
SCL_L;
void IIC_Stop()
P1DIR |=BIT6;
SCL_L;
SDA_L;
SCL_H;
SDA_H;
void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
for(i=0;i<8;i++)
if(IIC_Byte & 0x80)
SDA_H;
SDA_L;
SCL_H;
SCL_L;
IIC_Byte<<=1;
void OLED_WrDat(unsigned char IIC_Data)
IIC_Start();
Write_IIC_Byte(0x78);
Write_IIC_Byte(0x40);  //write data
Write_IIC_Byte(IIC_Data);
IIC_Stop();
void OLED_WrCmd(unsigned char IIC_Command)
IIC_Start();
Write_IIC_Byte(0x78);//Slave address,SA0=0
Write_IIC_Byte(0x00); //write command
Write_IIC_Byte(IIC_Command);
IIC_Stop();
void OLED_Set_Pos(unsigned char x, unsigned char y)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(((x&0xf0)>>4)|0x10);
OLED_WrCmd(x&0x0f);
void OLED_Fill(unsigned char bmp_dat)
unsigned char y,x;
for(y=0;y<8;y++)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(0x01);
OLED_WrCmd(0x10);
for(x=0;x<X_WIDTH;x++)
OLED_WrDat(bmp_dat);
void OLED_CLS(void)
unsigned char y,x;
for(y=0;y<8;y++)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(0x01);
OLED_WrCmd(0x10);
OLED_WrDat(0);
void OLED_Init(void)
  P1DIR |=BIT6;
  P1DIR &=~ BIT7;
  delay(500);//初始化之前的延时很重要!
OLED_WrCmd(0xae);//--turn off oled panel
OLED_WrCmd(0x00);//---set low column address
OLED_WrCmd(0x10);//---set high column address
OLED_WrCmd(0x40);//--set start line address Set Mapping RAM Display Star
OLED_WrCmd(0x81);//--set contrast control register
OLED_WrCmd(Brightness); // Set SEG Output Current Brightness
OLED_WrCmd(0xa1);//--Set SEG/Column Mapping 0xa0 左右反置 0xa1 正常
OLED_WrCmd(0xc8);//Set COM/Row Scan Direction 0xc0 上下反置 0xc8
OLED_WrCmd(0xa6);//--set normal display
OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
OLED_WrCmd(0x3f);//--1/64 duty
OLED_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter
OLED_WrCmd(0x00);//-not offset
OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WrCmd(0xd9);//--set pre-charge period
OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WrCmd(0xda);//--set com pins hardware configuration
OLED_WrCmd(0x12);
OLED_WrCmd(0xdb);//--set vcomh
OLED_WrCmd(0x40);//Set VCOM Deselect Level
OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WrCmd(0x02);//
OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
OLED_WrCmd(0x14);//--set(0x10) disable
OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
OLED_WrCmd(0xaf);//--turn on oled panel
void OLED_ShowCHinese(unsigned char x,unsigned char y,unsigned char no)
unsigned char t,adder=0;
OLED_Set_Pos(x,y);
    for(t=0;t<16;t++)
    OLED_WrDat(Hzk[2*no][t]);
    adder+=1;
  OLED_Set_Pos(x,y+1);
    for(t=0;t<16;t++)
    OLED_WrDat(Hzk[2*no+1][t]);
    adder+=1;
ID:328885 发表于 2018-5-13 15:04 | 显示全部楼层
来人啊
