查看: 5477|回复: 6
单片机控制的频率和幅度可调的信号发生器的问题
ID:314270 发表于 2018-5-15 16:48 | 显示全部楼层 |阅读模式
正在做一个频率和幅度可调的信号发生器,已经编程可实现正弦波,方波,三角波输出,并且用1602显示出当前波形种类。
求问怎样实现频率和幅度可调,并且用lcd1602显示出来,可以只介绍方法,譬如用哪种芯片或者什么手段控制谁,,当然有资料更好。
感激不尽!
下面是我的主函数一小部分,lcd1602的部分是老师的视频资料里介绍的,拿过来套用了,改了自定义字符为“正”“方”“三”,因为不能输出
稍微复杂的字符。第一次发帖求教,希望有人可以指教一二。
电路原理图如下:
dac0832::
  1. #include<delay.h>
  2. #include<dac0832.h>
  3. #include <config.h>
  4. unsigned char const code zxb_code[256]=
  5. {
  6. 0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,
  7. 0xa5,0xa8,0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,
  8. 0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,0xdc,0xde,0xe0,
  9. 0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,
  10. 0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,
  11. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,
  12. 0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,
  13. 0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,
  14. 0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,
  15. 0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,
  16. 0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,
  17. 0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,
  18. 0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x39,0x36,0x33,0x31,
  19. 0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,
  20. 0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,
  21. 0x3,0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
  22. 0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xa,0xc,0xd,
  23. 0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,
  24. 0x25,0x27,0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,
  25. 0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,
  26. 0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c
  27. };
  28. unsigned char keyscan()
  29. {
  30.     uint8 keyscan_num,temp;
  31.     P1=0xff;
  32.     temp=P1;
  33.     if(~(temp&0xff))                 //键盘扫描
  34.     {
  35.         if(k0==0)
  36.         {
  37.             keyscan_num=1;
  38.         }
  39.         else if(k1==0)
  40.         {
  41.             keyscan_num=2;
  42.         }
  43.         else if(k2==0)
  44.         {
  45.             keyscan_num=3;
  46.         }
  47.         else
  48.         {
  49.             keyscan_num=0;
  50.         }
  51.         return keyscan_num;
  52.     }
  53. }
  54. void init_dac()
  55. {
  56.     rd=0;
  57.     wr=0;
  58. }
  59. void zxb()
  60. {
  61.     uint16 i;
  62.     do
  63.     {
  64.         P2=zxb_code[i];
  65.         i++;
  66.     }while(i<256);
  67. }
  68. void fangbo()
  69. {
  70.     do
  71.     {
  72.         P2=20;
  73.         delay_fb();
  74.         P2=255;
  75.         delay_fb();
  76.     }while(k2==1&k0==1);
  77. }
  78. void sanjiao()
  79. {
  80.     unsigned int i;
  81.     do
  82.     {
  83.         for(i=0; i<255; i++)
  84.         {
  85.             P2=i;
  86.             delay_out();
  87.         }
  88.         for(i=255;i>0;i--)
  89.         {
  90.             P2=i;
  91.             delay_out();
  92.         }
  93.     }while(k1==1&k0==1);
  94. }
  95. main函数::
  96. /******************************************************************************/
  97. // 包含头文件
  98. /******************************************************************************/
  99. #include "config.h"
  100. #include "lcd1602.h"
  101. #include "dac0832.h"
  102. uint8 flag;                            //flag为0,1,2时分别表示正弦波,方波 ,三角波
  103. uint8 code lcd1602Table1[8]={0x1f,0x04,0x04,0x17,0x14,0x14,0x1f,0x00};//构造汉字“正”
  104. uint8 code lcd1602Table2[8]={0x04,0x1f,0x04,0x07,0x05,0x09,0x17,0x00};//构造汉字“方”
  105. uint8 code lcd1602Table3[8]={0x1f,0x00,0x00,0x0c,0x00,0x00,0x1f,0x00};//构造汉字“三”
  106. /******************************************************************************/
  107. // main函数
  108. /******************************************************************************/
  109. int main(void)
  110. {
  111.     Lcd1602_Init();
  112.     Lcd1602_Show_String(2,1,"50hz");
  113.     init_dac();
  114.     do
  115.     {
  116.         flag=keyscan();
  117.     }while(!flag);             //直到没有按键按下就停止扫描
  118.     while(1)
  119.     {
  120.         switch(flag)
  121.         {
  122.             case 1:do
  123.                     {
  124.                         flag=keyscan();
  125.                         zxb();
  126.                         Lcd1602_Custom_Char(1,1,0,lcd1602Table1);
  127.                     }while(flag==1);
  128.             break;
  129.             case 2:    do
  130.                     {
  131.                         flag=keyscan();
  132.                         fangbo();
  133.                         Lcd1602_Custom_Char(1,1,0,lcd1602Table2);
  134.                     }while(flag==2);
  135.             break;
  136.             case 3:    do
  137.                     {
  138.                         flag=keyscan();
  139.                         sanjiao();
  140.                         Lcd1602_Custom_Char(1,1,0,lcd1602Table3);
  141.                     }while(flag==3);
  142.             break;
  143.             default:flag=keyscan();
  144.             break;
  145.         }
  146.     }
  147. }
参与人数 1黑币 +3 收起 理由
RoomZt + 3 赞一个!
ID:96682 发表于 2018-5-15 18:06 | 显示全部楼层
楼主,汉字这种液晶屏根本无法显示好不好
ID:314270 发表于 2018-5-15 20:18 | 显示全部楼层
wc86110 发表于 2018-5-15 18:06
楼主,汉字这种液晶屏根本无法显示好不好
可以自定义字符显示简单的汉字,你看我的原理图显示了一个“方”字,我用他来代表方波
ID:341894 发表于 2018-5-31 07:45 | 显示全部楼层
楼主中的delay函数为什么么有看到,这是全部代码吗?频率可以改变产生波的延时来改变周期从而改变频率
ID:341894 发表于 2018-5-31 07:55 | 显示全部楼层
楼主可以分享一下频率波发生器的代码吗?最近我业余刚刚也在做这方面的东西希望得到新的启发,最近还有几个问题没解决,频率已有方案,就是之前提到过的改变产波延迟函数,幅度还有问题没有解决,不知道题主是否已经解决qq邮箱2254399709@qq.com以后希望多交流
ID:256945 发表于 2018-7-20 16:28 | 显示全部楼层
你这哪里可调了
ID:860103 发表于 2020-12-15 09:15 | 显示全部楼层
楼主,我最近也在做这个。我的想法是在波形输出的同时按键扫描,不同的键位改变delay(i)的i,或许可以做到。但是这样是只能可调,不能选择固定的频率。另外楼主能发你的仿真文件给我一封吗谢谢
