查看: 2800|回复: 0
ADC0809串口调试程序
#include"reg52.h"
#define u16 unsigned  int
#define u8 unsigned  int
sbit ST=P1^0;
sbit EOC=P1^1;
sbit OE=P1^2;
sbit ADDA=P1^3;
sbit ADDB=P1^4;
sbit ADDC=P1^5;
sbit ALE=P1^6;
sbit ADC0809CLK=P1^7;
u16 adc0809=0;
sbit p20=P2^0;
sbit p21=P2^1;
sbit p22=P2^2;
sbit p23=P2^3;
sbit p24=P2^4;
sbit p25=P2^5;
sbit p26=P2^6;
sbit p27=P2^7;
u16 sample;
u16 number=0;
u16 MAX=500000;
u16 ber=0;
void delay1(uchar i)
uchar j;
        while(i--)
        for(j=125;j>0;j--);
void AD0809OPERATION()
  ST=0;
        ALE=0;
        ADDA=1;
        ADDB=0;
        ADDC=0;
        delay1(15);
  ALE=1;
        ALE=1;
        ST=1;//启动AD转换
        ALE=1;
        delay1(20);
        ALE=0;
        ST=0;
        while(EOC==0);
        if(EOC==1)
          OE=1;
                delay1(3);
                adc0809=P2;
                adc0809=P2;
void Usartlnit()
        SCON=0X50;//设置工作方式1
        TMOD=0X20;//设置计数器工作方式2
        PCON=0X80;//波特率加倍
        TH1=0XF3;//计数器初始值设置,注意波特率是4800的
        TL1=0XF3;
        ES=1;//打开接收中断
        EA=1;//打开总中断
        TR1=1;//打开计数器
void rs232topc(unsigned char d)
  SBUF=d;
        while(!TI);
        TI=0;
unsigned char getASCII(unsigned char port)
return port+'0';
  Usartlnit();//串口初始化
  TL0=0XFE;
  TH0=0XFF;
  IE=0X82;
  TR0=1;
  ADDA=0;
  ADDB=0;
  ADDC=0;
  ADC0809CLK=0;
  number=0;
  ber=0;
        if (number%MAX==0)
                AD0809OPERATION();
                number=0;
                if(p27==0)
                rs232topc('0');
                rs232topc('1');
                if(p26==0)
                rs232topc('0');
                rs232topc('1');
                if(p25==0)
                rs232topc('0');
                rs232topc('1');
                if(p24==0)
                rs232topc('0');
                rs232topc('1');
                if(p23==0)
                rs232topc('0');
                rs232topc('1');
                if(p22==0)
                rs232topc('0');
                rs232topc('1');
                if(p21==0)
                rs232topc('0');
                rs232topc('1');
                if(p20==0)
                rs232topc('0');
                rs232topc('1');
                rs232topc(',');
void T0IP()interrupt 1
          number=number+1;
         TL0=0XFE;
         TH0=0XFF;
ADC0809CLK=!ADC0809CLK;
