查看: 17036|回复: 1
ACS712引脚图电路图与pdf数据手册下载
ACS712引脚图:
ACS712管脚功能:
ACS712应用电路图:
Features and Benefits
▪  Low-noise analog signal path
▪  Device bandwidth is set via the new FILTER pin
▪ 5 μs output rise time in response to step input current
▪  80 kHz bandwidth
▪  Total output error 1.5% at TA
= 25°C
▪  Small footprint, low-profile SOIC8 package
▪ 1.2 mΩ internal conductor resistance
▪ 2.1 kVRMS minimum isolation voltage from pins 1-4 to pins 5-8
▪  5.0 V, single supply operation
▪  66 to 185 mV/A output sensitivity
▪  Output voltage proportional to AC or DC currents
▪  Factory-trimmed for accuracy
▪  Extremely stable output offset voltage
▪  Nearly zero magnetic hysteresis
▪  Ratiometric output from supply voltage
完整的pdf格式文档51黑下载地址:
ACS712 数据手册.pdf (680.22 KB, 下载次数: 125)
ID:138533 发表于 2022-12-4 22:47 | 只看该作者
资料下载了,谢谢分享。
