查看: 9882|回复: 0
HT7350(7350-A)引脚图与电路图及封装 pdf资料手册下载
HT7350引脚图:
HT7350功能框图:
HT7350典型应用电路图:
HT7350封装:
HT7350资料手册: HT7350(7350-A).pdf (119.8 KB, 下载次数: 51)
The HT73XX series is a set of three-terminal, low power,
high voltage regulators implemented in CMOS technol-
ogy. The series features extremely low quiescent cur-
rent which is typically 3.5A . They allow input voltages
as high as 12V. The device provides large current with a
significantly small dropout voltage.
The HT73XX consists of a high-precision voltage refer-
ence, an error correction circuit, and a current limited
output driver. They are available with several fixed out-
put voltages ranging from 1.8V to 5.0V. CMOS technol-
ogy ensures low dropout voltage and low current
consumption. Although designed primarily as fixed volt-
age regulators, these devices can be used with external
components to generate variable voltages and currents.
 Ultra low quiescent current: 3.5A (typ.)
 High input voltage (up to 12V)
 Output voltage:
1.8V, 2.5V, 2.7V, 3.0V, 3.3V, 3.5V, 5.0V
 Output voltage accuracy: tolerance 3%
 Battery-powered equipment
 Voltage regulator for microprocessor
 Voltage regulator for LAN cards
