查看: 1806|回复: 0
接线如图所示,程序如下,求大佬指点
/*********引脚定义**********/
#include "reg51.h"
typedef unsigned int uint;
typedef unsigned char uchar;
#define Duty_cycle   35                      //占空比
#define Cycle                  100                                //PWM周期
sbit Sensor_1 = P1^1;                                        //红外检测
sbit Sensor_2 = P1^2;
sbit Motor_1H = P0^0;                                        //电机控制
sbit Motor_1L = P0^1;
sbit Motor_2H = P0^2;
sbit Motor_2L = P0^3;
sbit Motor_3H =        P0^4;
sbit Motor_3L =        P0^5;
sbit Motor_4H =        P0^6;
sbit Motor_4L = P0^7;
sbit En_pwm1 = P1^4;                                        //使能信号 (PWM)
sbit En_pwm2 = P1^5;
sbit En_pwm3 = P1^6;
sbit En_pwm4 = P1^7;
uchar timer1;                                                        //定义变量
/*********主函数**********/
void main ()
         Time1Config();                                                //定时器初始化
                if (Sensor_1 == 1 && Sensor_2 == 1)                        //状态:轨迹居中
                        Go_Straighe();                                                        //方向:前进
                else if (Sensor_1 == 1 && Sensor_2 == 0)          //状态:偏左
                        Turn_Righr();                                                        //方向:右转
                else if (Sensor_1 == 0 && Sensor_2 == 1)        //状态:偏右
                        Turn_Left();                                                        //方向:左转
                else if (Sensor_1 == 0 && Sensor_2 == 0)        //状态:偏离轨迹
                        Stop();        //方向:停止
                else Go_Straight();                                                        //其他情况:前进
/**********设置定时器**********/
void Time1Config()
        TMOD = 0x10;        //设置定时器计数器T1工作在模式1
        /**********定时器赋初值*********/
        TH1 = 0xFE;
        TL1 = 0x0c;
        ET1 = 1;        //开启定时器1中断
        EA = 1;
        TR1 = 1;        //开启定时器
/**********定时器1的中断函数**********/
void Time1(void) interrupt 3                                                 //3 为定时器的中断信号
        Time1++;
        if (Timer1 > Cycre)        //PWM周期
                Time1 = 0;
        if (Timer1 < Duty_cycle)                                                   //改变Duty_cycle 这个值,可以改变直流电机的速度
                En_pwm1 = 1;
                En_pwm2 = 1;
                En_pwm3 = 1;
                En_pwm4 = 1;
                En_pwm1 = 0;
                En_pwm2 = 0;
                En_pwm3 = 0;
                En_pwm4 = 0;
        TH1 = 0xFE;        //重新赋值
        TL1 = 0x0C;
