查看: 7954|回复: 4
单片机驱动ADS1115的程序
ID:337087 发表于 2018-5-24 10:12 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
sbit   SCL=P1^0;         //SCL
sbit         SDA=P1^1;         //SDA
sbit led0 = P1^2;
sbit led1 = P1^3;
unsigned char   Initdata[4]={0};
code unsigned char seg7code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff}; //不带小数点的共阳数码管段码
code unsigned char seg7codeB[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0xff}; //带小数点的共阳数码管段码
unsigned int date;
unsigned char cnt;
//******************延时子程序 *******************************
void delay(unsigned char i)
for(i;i>0;i--);
void delay1ms(unsigned char t)
unsigned char i;
unsigned char j;
for(i=124;i>0;i--);
        for(j=0;j<t;j++);
/****************************开始ADC通信*************************/
void StartADcom()
        SDA =0;
  SCL=1;
  delay(100);
  SDA =1;
  delay(20);
  SDA =0;
  SCL=0;
  delay(10);
/***********************************停止ADC通信**************************************/
void StopADcom()
  SDA=0;
  delay(10);
  SCL=1;
  delay(20);
  SDA=1;
  delay(10);
/********************************单字节I2C传输**************************************/
void Send_Byte(unsigned char byte)
  unsigned char i;
  for(i=0;i<8;i++)
                if((byte<<i)&0x80)
                  SDA=1;
                  SDA=0;
          delay(5);
          SCL=1;
          delay(10);
    SCL=0;
    delay(10);
  delay(5);
  SDA=1;
  delay(5);
  SCL=1;
  delay(10);
  SCL=0;
  delay(10);
/*************************读取一个字节*****************************/
unsigned char Read_Byte()
  unsigned char temp=0;
  unsigned char i;
  for(i=0;i<8;i++)
                temp=temp<<1;           //shift left to receive next bit
                SCL=0;                        //set clock high
                delay(10);
                SCL=1;
                _nop_();
                delay(5);
                if(SDA==1)                //check if Data=high
                temp|=0x01;            //yes - set bit high
                _nop_();
                delay(10);
  SCL=0;
  delay(5);
  SDA=0;
  delay(5);
  SCL=1;
  delay(20);
  SCL=0;
  delay(5);
  SDA=1;
  return temp;
/**************************配置ADC转换芯片*************************************/
void Confige1115(unsigned char channel_x)
  unsigned char i=0;
  unsigned char a_channel;
  switch(channel_x)
                case 1:
                a_channel=0x42;
                break;
                case 2:
                a_channel=0x52;
                break;
                case 3:
                a_channel=0x62;
                break;
                case 4:
                a_channel=0x72;
                break;
                default:
                break;
  Initdata[0] =0x90;
  Initdata[1] =0x01;
  Initdata[2]=a_channel;
  Initdata[3] =0x83;
  SCL=1;
  StartADcom();
  for(i=0;i<4;i++)
                Send_Byte(Initdata[i]);
                delay(20);
  StopADcom();
/********指向转换结果寄存器**************************/
void Pointregister(void)
  unsigned char i=0;
  Initdata[0] =0x90;
  Initdata[1] =0x00;
  SCL=1;
  StartADcom();
  for(i=0;i<2;i++)
    delay(20);
  StopADcom();
  delay(10);
/*****************读取ADC转换结果*******************/
unsigned int Read1115(void)
  unsigned char   ResultL,ResultH;
  unsigned int    Result;
  Initdata[0] =0x91;
  SCL=1;
  StartADcom();
  delay(10);
  Send_Byte(Initdata[0]);
  delay(20);
  ResultH=Read_Byte();
  delay(10);
  ResultL=Read_Byte();
  StopADcom();
  Result=ResultH*256+ResultL;
  return   Result;
/*****ADC模拟量采集转化为数字量*********/
unsigned int  Ad_1115(unsigned char channel_Ad)
        unsigned int adc_value;
        Confige1115(channel_Ad);
        delay1ms(1);
        Pointregister();
        delay(10);
        adc_value=Read1115();
        return   adc_value;
//********************显示函数****************
void display()
         P2=0xfe;     //P1.0=0,选通第一位
         P0=seg7codeB[date/10000];  //十位数,查表,输出
         delay1ms(1);
         P0=0xff;        //消隐
         P2=0xfd;     //P1.1=0,选通第二位,个位数
         P0=seg7code[date%10000/1000];
         delay1ms(1);
         P0=0xff;       //消隐
         P2=0xfb;     //P1.3=0,选通第三位,小数点第一位
         P0=seg7code[date%1000/100];
         delay1ms(1);
         P0=0xff;         //消隐
         P2=0xf7;     //P1.3=0,选通第四位,小数点第二位
         P0=seg7code[date%100/10];
         delay1ms(1);
         P0=0xff;       //消隐
void Timer1Init(void)
        TMOD &= 0x0F;
        TMOD |= 0x10;
        TL1 = 0x00;
        TH1 = 0xff;
        TF1 = 0;
        TR1 = 1;
//**************************** //主程序
main()
        Timer1Init();
        EA = 1;
        ET1 = 1;
         //date=Ad_1115(1) * 1.2;
         display();
         if(date>40000)
                led0 = 1;
                led1 = 0;
                else if(date>35000)
                led0 = 0;
                delay(50);
                led0 = 1;
                led1 = 0;
                else if(date>15000)
                led0 = 0;
                led1 = 1;
                led0 = 0;
                delay(1);
                led0 = 1;
                led1 = 1;
void Timer1_isr(void) interrupt 3
        ET1 = 0;
        TH0=0x00;
        TL0=0xff;
        cnt = cnt + 1;
        if(cnt == 1)
                cnt = 0;
                //display();
        ET1 = 1;
ID:375976 发表于 2018-7-20 16:12 | 显示全部楼层
能不能发个原理图出来啊
ID:416501 发表于 2019-9-30 16:01 | 显示全部楼层
同上,确实只有代码看着晕。
ID:583839 发表于 2019-10-16 15:33 | 显示全部楼层
我把这个程序进行了编译,那示波器看这个SCL和SDA,两条线都统一被拉高了,没有数据变化呀
ID:66862 发表于 2025-5-24 00:07 | 显示全部楼层
测试了一下,好像不能用
