查看: 2382|回复: 0
求大神帮忙看看3路超声波控制小车程序,始终不动
ID:321034 发表于 2018-5-24 21:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我  编写了一套  3路超声波控制小车进行测距的程序   ,   程序一直显示没有问题,但是小车始终不动   我不知道是哪的状况   ,求各位大神帮忙看看  小弟感激不尽!!
源程序如下:
  1. # include "reg52.h"
  2. # include "intrins.h"
  4. #define uint unsigned int
  5. sbit L298N_INA = P1^0;
  6. sbit L298N_INB = P1^1;
  7. sbit L298N_INC = P1^2;
  8. sbit L298N_IND = P1^3;
  9. sbit ENA_pwm = P2^6;
  10. sbit ENB_pwm = P2^7;
  11. sbit Trlg1 = P2^0;
  12. sbit Echo1 = P2^1;
  13. sbit Trlg2 = P3^1;
  14. sbit Echo2 = P3^2;
  15. sbit Trlg3 = P3^3;
  16. sbit Echo3 = P3^4;
  17. bit flag = 0;
  18. unsigned char pwm_val_left =0;    //pwm变量定义
  19. unsigned char push_val_left =0;   // 左电机占空比N/10
  20. unsigned char pwm_val_right =0;
  21. unsigned char push_val_right=0;   // 右电机占空比N/10
  22. unsigned int time=0;
  23. unsigned long S1 = 0;            //距离
  24. unsigned long S2 = 0;
  25. unsigned long S3 = 0;
  26. /************************************************************************/
  27.                             /* 运动模块*/
  28. void Go_forward()
  29. {
  30.     push_val_left=4;
  31.     push_val_right=4;
  32.     L298N_INA = 0;
  33.     L298N_INB = 1;
  34.     L298N_INC = 1;
  35.     L298N_IND = 0;
  36. }
  37. void Go_back()
  38. {
  39.     push_val_left=4;
  40.     push_val_right=4;
  41.     L298N_INA = 1;
  42.     L298N_INB = 0;
  43.     L298N_INC = 0;
  44.     L298N_IND = 1;
  45. }
  46. void Go_left()
  47. {
  48.     push_val_left=3;
  49.     push_val_right=3;
  50.     L298N_INA = 0;
  51.     L298N_INB = 1;
  52.     L298N_INC = 1;
  53.     L298N_IND = 1;
  54. }
  55. void Go_right()
  56. {
  57.     push_val_left=3;
  58.     push_val_right=3;
  59.     L298N_INA = 1;
  60.     L298N_INB = 0;
  61.     L298N_INC = 0;
  62.     L298N_IND = 0;
  63. }
  64. void Stop()
  65. {
  66.     L298N_INA = 0;
  67.     L298N_INB = 0;
  68.     L298N_INC = 0;
  69.     L298N_IND = 0;
  70. }
  71. /************************************************************************/
  72.                           /* 延时模块*/
  73. void delay(uint c)      //1ms延时函数
  74. {
  75.     uint a, b;
  76.     for(a=c;a>0;a--)
  77.     {
  78.        for(b=110;b>0;b--);
  79.     }
  80. }
  81. void Delay10us_CSB1(unsigned char i)   //10us延时函数 启动超声波模块时使用
  82. {
  83.    unsigned char j;
  84.         do{
  85.                 j = 10;
  86.                 do{
  87.                         _nop_();
  88.                                 _nop_();
  89.                 }while(--j);
  90.         }while(--i);
  91. }
  92. void Delay10us_CSB2(unsigned char i)
  93. {
  94.    unsigned char j;
  95.         do{
  96.                 j = 10;
  97.                 do{
  98.                         _nop_();
  99.                                 _nop_();
  100.                 }while(--j);
  101.         }while(--i);
  102. }
  103. void Delay10us_CSB3(unsigned char i)
  104. {
  105.    unsigned char j;
  106.         do{
  107.                 j = 10;
  108.                 do{
  109.                         _nop_();
  110.                                 _nop_();
  111.                 }while(--j);
  112.         }while(--i);
  113. }
  114. /************************************************************************/
  115.                      /* PWM调制电机转速 */
  116. void pwm_out_left_moto(void)
  117. {
  118.                 if(pwm_val_left<=push_val_left)
  119.                         ENA_pwm=1;
  120.                 else
  121.                         ENA_pwm=0;
  122.                 if(pwm_val_left==10)            //  0~10  ,  0最小,10最大
  123.                         pwm_val_left=0;
  124. }
  125. void pwm_out_right_moto(void)
  126. {
  127.                 if(pwm_val_right<=push_val_right)
  128.                         ENB_pwm=1;
  129.                 else
  130.                         ENB_pwm=0;
  131.                 if(pwm_val_right==10)           //  0~10  ,  0最小,10最大
  132.                         pwm_val_right=0;
  133. }
  134.                             /*中断函数产生PWM信号*/
  135. void timer1()interrupt 3
  136. {
  137.      TH1=(65536-10)/256;          //10US定时
  138.      TL1=(65536-10)%256;
  139.
  140.      pwm_val_left++;
  141.      pwm_val_right++;
  142.      pwm_out_left_moto();
  143.      pwm_out_right_moto();                                  //定时器100US为准。在这个基础上延时
  144. }
  145.                                 /* 计时器溢出模块*/
  146. void timer0() interrupt 1
  147. {
  148.         flag=1;
  149. }
  150. /************************************************************************/
  151.         /*计算超声波所测距离并显示   */
  152. void Conut1(void)                   //计算距离
  153.         {
  154.               while(!Echo1);        //当(ECHO信号回响)为零时等待
  155.             TR0=1;               //开启计数
  156.             while(Echo1);
  157.             TR0=0;               //关闭计数
  158.
  159.             time=TH0*256+TL0;                   //读取脉宽长度
  160.             TH0=0;
  161.             TL0=0;
  162.             S1=(float)(time*1.085)*0.17;
  163.                 if((S1>=7000)||(flag == 1))
  164.                 {
  165.                      flag = 0;
  166.                 }
  167.         }
  168. void Conut2(void)                   //计算距离
  169.         {
  170.               while(!Echo2);        //当(ECHO信号回响)为零时等待
  171.             TR0=1;               //开启计数
  172.             while(Echo2);
  173.             TR0=0;               //关闭计数
  174.
  175.             time=TH0*256+TL0;
  176.             TH0=0;
  177.             TL0=0;
  178.             S2=(float)(time*1.085)*0.17;
  179.                 if((S2>=7000)||(flag == 1))
  180.                 {
  181.                      flag = 0;
  182.                 }
  183.         }
  184. void Conut3(void)                   //计算距离
  185.         {
  186.                 while(!Echo3);        //当(ECHO信号回响)为零时等待
  187.             TR0=1;               //开启计数
  188.             while(Echo3);
  189.             TR0=0;               //关闭计数
  190.             time=TH0*256+TL0;
  191.             TH0=0;
  192.             TL0=0;
  193.             S3=(float)(time*1.085)*0.17;
  194.                 if((S3>=7000)||(flag == 1))
  195.                 {
  196.                     flag = 0;
  197.                 }
  198.         }
  199. void  bizhang (void)
  200. {
  201.            Trlg1=1;
  202.            Delay10us_CSB1(5);
  203.            Trlg1=0;          //启动超声波测距
  204.            Conut1();                           //计算距离
  205.
  206.            Trlg2=1;
  207.            Delay10us_CSB2(5);
  208.            Trlg2=0;
  209.            Conut2();
  210.
  211.            Trlg3=1;
  212.            Delay10us_CSB3(5);
  213.            Trlg3=0;
  214.            Conut3();
  215.     if(S1<50 && S2<50 && S3<50)
  216.     {
  217.        Go_back();
  218.          delay(50);
  219.          Stop();
  220.          if(S2<50 && S3>50)
  221.           {
  222.              Go_right();
  223.           }
  224.
  225.        if(S2>50 && S3<50)
  226.        {
  227.            Go_left();
  228.        }
  229.     }
  230.     else if(S1>50 && S2<50 && S3<50)
  231.     {
  232.          Stop();
  233.          delay(50);
  234.          if(S2<50 && S3>50)
  235.           {
  236.              Go_right();
  237.           }
  238.
  239.        if(S2>50 && S3<50)
  240.        {
  241.            Go_left();
  242.        }
  243.
  244.     }
  245.     else if(S1>50&& S2>50 && S3>50)
  246.     {
  247.         Go_forward();
  248.     }
  249. }
  250. void main(void)
  251. {
  252.         TMOD |= 0x20;//定时器1工作模式2,8位自动重装。用于产生PWM
  253.         TMOD |= 0x01;//定时器0工作模块1,16位定时模式。T0用测Echo脉冲长度
  254.         TH1=220;
  255.         TL1=220;
  256.         TH0 = 0;
  257.         TL0 = 0;
  258.         ET1 = 1;     //允许T1中断
  259.         ET0 = 1;     //允许T0中断
  260.         TR1 = 1;     //启动定时器1
  261.         EA  = 1;     //启动总中断
  262.         while(1)
  263.         {
  264.            bizhang();
  265.              delay(65);
  266.           }
  267. }
