查看: 3080|回复: 0
stm32显示gps信息到液晶屏上
ID:222344 发表于 2018-5-28 22:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,部分代码如下
* @file     core_cm3.c
* @brief    CMSIS Cortex-M3 Core Peripheral Access Layer Source File
* @version  V1.30
* @date     30. October 2009
* @note
* Copyright (C) 2009 ARM Limited. All rights reserved.
* @par
* ARM Limited (ARM) is supplying this software for use with Cortex-M
* processor based microcontrollers.  This file can be freely distributed
* within development tools that are supporting such ARM based processors.
* @par
* THIS SOFTWARE IS PROVIDED "AS IS".  NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#include <stdint.h>
/* define compiler specific symbols */
#if defined ( __CC_ARM   )
  #define __ASM            __asm                                      /*!< asm keyword for ARM Compiler          */
  #define __INLINE         __inline                                   /*!< inline keyword for ARM Compiler       */
#elif defined ( __ICCARM__ )
  #define __ASM           __asm                                       /*!< asm keyword for IAR Compiler          */
  #define __INLINE        inline                                      /*!< inline keyword for IAR Compiler. Only avaiable in High optimization mode! */
#elif defined   (  __GNUC__  )
  #define __ASM            __asm                                      /*!< asm keyword for GNU Compiler          */
  #define __INLINE         inline                                     /*!< inline keyword for GNU Compiler       */
#elif defined   (  __TASKING__  )
  #define __ASM            __asm                                      /*!< asm keyword for TASKING Compiler      */
  #define __INLINE         inline                                     /*!< inline keyword for TASKING Compiler   */
#endif
/* ###################  Compiler specific Intrinsics  ########################### */
#if defined ( __CC_ARM   ) /*------------------RealView Compiler -----------------*/
/* ARM armcc specific functions */
* @brief  Return the Process Stack Pointer
* @return ProcessStackPointer
* Return the actual process stack pointer
__ASM uint32_t __get_PSP(void)
  mrs r0, psp
  bx lr
* @brief  Set the Process Stack Pointer
* @param  topOfProcStack  Process Stack Pointer
* Assign the value ProcessStackPointer to the MSP
* (process stack pointer) Cortex processor register
__ASM void __set_PSP(uint32_t topOfProcStack)
  msr psp, r0
  bx lr
* @brief  Return the Main Stack Pointer
* @return Main Stack Pointer
* Return the current value of the MSP (main stack pointer)
* Cortex processor register
__ASM uint32_t __get_MSP(void)
  mrs r0, msp
  bx lr
* @brief  Set the Main Stack Pointer
* @param  topOfMainStack  Main Stack Pointer
* Assign the value mainStackPointer to the MSP
* (main stack pointer) Cortex processor register
__ASM void __set_MSP(uint32_t mainStackPointer)
  msr msp, r0
  bx lr
* @brief  Reverse byte order in unsigned short value
* @param   value  value to reverse
* @return         reversed value
* Reverse byte order in unsigned short value
__ASM uint32_t __REV16(uint16_t value)
  rev16 r0, r0
  bx lr
* @brief  Reverse byte order in signed short value with sign extension to integer
* Reverse byte order in signed short value with sign extension to integer
__ASM int32_t __REVSH(int16_t value)
  revsh r0, r0
  bx lr
#if (__ARMCC_VERSION < 400000)
* @brief  Remove the exclusive lock created by ldrex
* Removes the exclusive lock which is created by ldrex.
__ASM void __CLREX(void)
  clrex
* @brief  Return the Base Priority value
* @return BasePriority
* Return the content of the base priority register
__ASM uint32_t  __get_BASEPRI(void)
  mrs r0, basepri
  bx lr
* @brief  Set the Base Priority value
* @param  basePri  BasePriority
* Set the base priority register
__ASM void __set_BASEPRI(uint32_t basePri)
  msr basepri, r0
  bx lr
* @brief  Return the Priority Mask value
* @return PriMask
* Return state of the priority mask bit from the priority mask register
__ASM uint32_t __get_PRIMASK(void)
  mrs r0, primask
  bx lr
* @brief  Set the Priority Mask value
* @param  priMask  PriMask
* Set the priority mask bit in the priority mask register
__ASM void __set_PRIMASK(uint32_t priMask)
  msr primask, r0
  bx lr
* @brief  Return the Fault Mask value
* @return FaultMask
* Return the content of the fault mask register
__ASM uint32_t  __get_FAULTMASK(void)
  mrs r0, faultmask
  bx lr
* @brief  Set the Fault Mask value
* @param  faultMask  faultMask value
* Set the fault mask register
__ASM void __set_FAULTMASK(uint32_t faultMask)
  msr faultmask, r0
  bx lr
* @brief  Return the Control Register value
* @return Control value
* Return the content of the control register
__ASM uint32_t __get_CONTROL(void)
  mrs r0, control
  bx lr
* @brief  Set the Control Register value
* @param  control  Control value
* Set the control register
__ASM void __set_CONTROL(uint32_t control)
  msr control, r0
  bx lr
#endif /* __ARMCC_VERSION  */
#elif (defined (__ICCARM__)) /*------------------ ICC Compiler -------------------*/
/* IAR iccarm specific functions */
#pragma diag_suppress=Pe940
  __ASM("mrs r0, psp");
  __ASM("bx lr");
  __ASM("msr psp, r0");
  __ASM("bx lr");
  __ASM("mrs r0, msp");
  __ASM("bx lr");
void __set_MSP(uint32_t topOfMainStack)
  __ASM("msr msp, r0");
  __ASM("bx lr");
  __ASM("rev16 r0, r0");
  __ASM("bx lr");
* @brief  Reverse bit order of value
* Reverse bit order of value
uint32_t __RBIT(uint32_t value)
  __ASM("rbit r0, r0");
  __ASM("bx lr");
* @brief  LDR Exclusive (8 bit)
* @param  *addr  address pointer
* @return        value of (*address)
* Exclusive LDR command for 8 bit values)
uint8_t __LDREXB(uint8_t *addr)
  __ASM("ldrexb r0, [r0]");
  __ASM("bx lr");
* @brief  LDR Exclusive (16 bit)
* Exclusive LDR command for 16 bit values
uint16_t __LDREXH(uint16_t *addr)
  __ASM("ldrexh r0, [r0]");
  __ASM("bx lr");
* @brief  LDR Exclusive (32 bit)
* Exclusive LDR command for 32 bit values
uint32_t __LDREXW(uint32_t *addr)
  __ASM("ldrex r0, [r0]");
  __ASM("bx lr");
* @brief  STR Exclusive (8 bit)
* @param  value  value to store
* @return        successful / failed
* Exclusive STR command for 8 bit values
uint32_t __STREXB(uint8_t value, uint8_t *addr)
  __ASM("strexb r0, r0, [r1]");
  __ASM("bx lr");
* @brief  STR Exclusive (16 bit)
* Exclusive STR command for 16 bit values
uint32_t __STREXH(uint16_t value, uint16_t *addr)
  __ASM("strexh r0, r0, [r1]");
  __ASM("bx lr");
* @brief  STR Exclusive (32 bit)
* Exclusive STR command for 32 bit values
uint32_t __STREXW(uint32_t value, uint32_t *addr)
  __ASM("strex r0, r0, [r1]");
  __ASM("bx lr");
#pragma diag_default=Pe940
#elif (defined (__GNUC__)) /*------------------ GNU Compiler ---------------------*/
/* GNU gcc specific functions */
uint32_t __get_PSP(void) __attribute__( ( naked ) );
  uint32_t result=0;
  __ASM volatile ("MRS %0, psp\n\t"
                  "MOV r0, %0 \n\t"
                  "BX  lr     \n\t"  : "=r" (result) );
  return(result);
void __set_PSP(uint32_t topOfProcStack) __attribute__( ( naked ) );
  __ASM volatile ("MSR psp, %0\n\t"
                  "BX  lr     \n\t" : : "r" (topOfProcStack) );
uint32_t __get_MSP(void) __attribute__( ( naked ) );
  uint32_t result=0;
  __ASM volatile ("MRS %0, msp\n\t"
                  "MOV r0, %0 \n\t"
  return(result);
void __set_MSP(uint32_t topOfMainStack) __attribute__( ( naked ) );
  __ASM volatile ("MSR msp, %0\n\t"
                  "BX  lr     \n\t" : : "r" (topOfMainStack) );
  uint32_t result=0;
  __ASM volatile ("MRS %0, basepri_max" : "=r" (result) );
  return(result);
void __set_BASEPRI(uint32_t value)
  __ASM volatile ("MSR basepri, %0" : : "r" (value) );
* @return PriMask
  uint32_t result=0;
  __ASM volatile ("MRS %0, primask" : "=r" (result) );
  return(result);
  __ASM volatile ("MSR primask, %0" : : "r" (priMask) );
* @return FaultMask
  uint32_t result=0;
  __ASM volatile ("MRS %0, faultmask" : "=r" (result) );
  return(result);
  __ASM volatile ("MSR faultmask, %0" : : "r" (faultMask) );
  uint32_t result=0;
  __ASM volatile ("MRS %0, control" : "=r" (result) );
  return(result);
  __ASM volatile ("MSR control, %0" : : "r" (control) );
* @brief  Reverse byte order in integer value
* Reverse byte order in integer value
uint32_t __REV(uint32_t value)
  uint32_t result=0;
  __ASM volatile ("rev %0, %1" : "=r" (result) : "r" (value) );
  return(result);
  uint32_t result=0;
  __ASM volatile ("rev16 %0, %1" : "=r" (result) : "r" (value) );
  return(result);
  uint32_t result=0;
  __ASM volatile ("revsh %0, %1" : "=r" (result) : "r" (value) );
  return(result);
  uint32_t result=0;
   __ASM volatile ("rbit %0, %1" : "=r" (result) : "r" (value) );
   return(result);
    uint8_t result=0;
   __ASM volatile ("ldrexb %0, [%1]" : "=r" (result) : "r" (addr) );
   return(result);
    uint16_t result=0;
   __ASM volatile ("ldrexh %0, [%1]" : "=r" (result) : "r" (addr) );
   return(result);
    uint32_t result=0;
   __ASM volatile ("ldrex %0, [%1]" : "=r" (result) : "r" (addr) );
   return(result);
   uint32_t result=0;
   __ASM volatile ("strexb %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   return(result);
   uint32_t result=0;
   __ASM volatile ("strexh %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   return(result);
   uint32_t result=0;
   __ASM volatile ("strex %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   return(result);
#elif (defined (__TASKING__)) /*------------------ TASKING Compiler ---------------------*/
/* TASKING carm specific functions */
* The CMSIS functions have been implemented as intrinsics in the compiler.
* Please use "carm -?i" to get an up to date list of all instrinsics,
* Including the CMSIS ones.
#endif
6.STM32单片机例程.rar
313.8 KB, 下载次数: 16, 下载积分: 黑币 -5
源代码
