查看: 4577|回复: 8
求助基于89C51的,用ds18b20检测,单片机输出信号由D/A转换后电阻加热的温度控制系统
2000黑币
要求必须有完整的电路图和单片机源程序,最好使用proteus仿真
ID:336165 发表于 2018-5-29 23:55 | 只看该作者
你是想用电阻来加热吗???这个怎么加热
ID:303383 发表于 2018-5-30 08:47 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:411308 发表于 2019-9-18 16:19 | 只看该作者
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #define uchar unsigned char//o궨òå
  4. #define uint unsigned int
  5. ////////////////////諾ֱäá¿/////////////////////////////
  6. float  TEMP_NOW=0.0;
  7. float  TEMP_SET=30.0;
  8. uint  T_Count=0;
  9. uint  S_Count=0;
  10. uint  P_Count=0;
  11. uint  N_Count=0;
  12. uint  M_Count=1;
  13. #define                K_UP                    0X20//¶¨òå¼üÖμ
  14. #define                K_DOWN                 0X21
  15. #define                K_CLEAR             0X24
  16. #define                K_OK                    0X25
  17. #define                K_ONE                    0X30
  18. #define                K_FOUR                 0X31
  19. #define                K_SEVEN            0X32
  20. #define                K_POINT                 0X33
  21. #define                K_TWO                    0X34
  22. #define                K_FIVE                    0X43
  23. #define                K_EIGHT                0X36
  24. #define                K_ZERO                0X37
  25. #define                K_THREE                0X38
  26. #define                K_SIX                    0X40
  27. #define                K_NINE                0X41
  28. #define                K_SET                   0X42
  29. extern float TEMP_NOW;
  30. extern float TEMP_SET;
  31. extern uint  T_Count;
  32. extern uint  S_Count;
  33. extern uint  P_Count;
  34. extern uint  N_Count;
  35. extern uint  M_Count;
  36. extern uchar Current_Temp_Display_Buffer[];
  37. extern uchar set_Temp_Display_Buffer[];
  38. extern int sel;
  39. sbit  lcden=P2^7;//òo¾§ê1Äü
  40. sbit  lcdrs=P2^6;//òo¾§êy¾Y/ÃüáîÑ¡Ôñ¶Ë
  41. sbit  DQ   =P3^7;//DS18B20êy¾Y¶Ë
  42. sbit  XX   =P2^5;//¶áD′Ñ¡Ôñ¶Ë
  43. sbit  cold =P2^0;//êä3öDÅoÅ
  44. sbit  warm =P2^1;//êä3öDÅoÅ
  45. uchar Current_Temp_Display_Buffer[]={"   NOW: 0.0"};
  46. uchar set_Temp_Display_Buffer[]=    {"   SET: 30.0"};
  47. int sel=0;
  48. uchar code KeyCodeTable[]=
  49. {
  50.           0x11,0x12,0x14,0x18,0x21,0x22,0x24,0x28,0x41,0x42,0x44,0x48,0x81,0x82,0x84,0x88
  51. };
  52. #define delayNOP() {_nop_();_nop_();_nop_();_nop_();}
  53. uchar code Temperature_Char[8] = {0x0c,0x12,0x12,0x0c,0x00,0x00,0x00,0x00};
  54. uchar code df_Table[]={0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};
  55. uchar CurrentT = 0;
  56. uchar Temp_Value[]={0x00,0x00};
  57. uchar Display_Digit[]={0,0,0,0};
  58. bit DS18B20_IS_OK = 1;
  59. void Read_Temperature();
  60. void Display_Temperature();
  61. void Comparison();
  62. //////////////////////¶¨ê±///////////////////////////////
  63. void timer0_init(void)
  64. {
  65.         TMOD =        0x00  ; //éèÖö¨ê±Æ÷0μÄ1¤×÷·½ê½
  66.         TH0 = (8192-5000)/32;//μ¥Ƭ»ú¾§ÕñÎa12MHz£¬»úÆ÷ÖüÆúÎa1us£¬t=5ms£¬
  67.                       //N=5000/1=5000
  68.         TL0 = (8192-5000)%32;
  69.         IE  =        0x82;
  70.         TR0=1;
  71. }
  72. void timer0() interrupt 1
  73. {
  74.         TH0 = (8192-5000)/32;
  75.         TL0 = (8192-5000)%32;
  76.         if(++T_Count == 100)                   //////100Îa0.5s
  77.         {
  78.                 TR0=0;
  79.                 Read_Temperature();
  80.                 Display_Temperature() ;
  81.                 T_Count=0;
  82.                 if(++P_Count == 6)
  83.                 {
  84.                          N_Count=1;
  85.                 }
  86.                    TR0=1;
  87.         }
  88. }
  89. void delay1(uint z)          //Ñóê±oˉêy
  90. {
  91.         uint x,y;
  92.         for(x=z;x>0;x--)
  93.                 for(y=110;y>0;y--);
  94. }
  95. void write_com(uchar com)  //D′Ãüáîoˉêy
  96. {
  97.         lcdrs=0;  //Ñ¡ÔñD′ÃüáîÄ£ê½
  98.         P0=com;          //½«òaD′μÄÃüáî×ÖËíμ½êy¾Y×üÏßéÏ
  99.         delay1(5); //éÔ×÷Ñóê±òÔ′yêy¾YÎ趨
  100.         lcden=1;  //ê1Äü¶Ë¸øò»¸ßÂö3壬òòÎa3õê¼»ˉoˉêyÖDòѾ-½«lcdenÖÃáã
  101.         delay1(5); //éÔ×÷Ñóê±
  102.         lcden=0;  //½«ê1Äü¶ËÖÃ0íê3é¸ßÂö3å
  103. }
  104. void write_date(uchar date)         //D′êy¾Yoˉêy
  105. {
  106.         lcdrs=1;   //Ñ¡ÔñD′êy¾YÄ£ê½
  107.         P0=date;
  108.         delay1(5);
  109.         lcden=1;
  110.         delay1(5);
  111.         lcden=0;
  112. }
  113. void init_lcd()                   //3õê¼»ˉoˉêy
  114. {
  115.         lcden=0;
  116.         write_com(0x38); //éèÖÃ16*2ÏÔê¾£¬5*7μãÕó£¬8λêy¾Y½ó¿ú
  117.         write_com(0x0c); //éèÖÿaÏÔê¾£¬2»ÏÔê¾1a±ê
  118.         write_com(0x06); //D′ò»¸ö×Ö·ûoóμØÖ·Ö¸Õë¼ó1
  119.         write_com(0x01); //ÏÔê¾Çå0,êy¾YÖ¸ÕëÇå0
  120. }
  121. void Print()
  122. {
  123.         uchar num;
  124.         write_com(0x80);
  125.         for(num=0;num<12;num++)
  126.         {
  127.                 write_date(Current_Temp_Display_Buffer[num]);
  128.         }
  129.         write_date(0xdf);
  130.         write_date('C');
  131.         write_com(0x80+0x40);
  132.         for(num=0;num<12;num++)
  133.         {
  134.                  write_date(set_Temp_Display_Buffer[num]);
  135.         }
  136.         write_date(0xdf);
  137.         write_date('C');
  138. }
  139. void Delay_INI(uint x)
  140. {
  141.         while(--x);
  142. }
  143. void Delay(unsigned int n)
  144. {
  145.         do
  146.         {
  147.                 _nop_();_nop_();
  148.                 _nop_();_nop_();
  149.                 _nop_();_nop_();
  150.                 _nop_();_nop_();
  151.                 _nop_();
  152.                 n--;
  153.         }while(n);
  154. }
  155. uchar Init_DS18B20()
  156.   {
  157.         uchar status;
  158.         DQ = 1;
  159.         Delay_INI(8);
  160.         DQ = 0;
  161.         Delay_INI(90);
  162.         DQ = 1;
  163.         Delay_INI(8);
  164.         status=DQ;
  165.         Delay_INI(100);
  166.         DQ = 1;
  167.         return status;
  168. }
  169. uchar ReadOneByte()
  170. {
  171.         uchar i,dat=0;
  172.         DQ = 1;
  173.         _nop_();
  174.         for(i=0;i<8;i++)
  175.         {
  176.                  DQ = 0;
  177.                 dat >>= 1;
  178.                 DQ = 1;
  179.                 _nop_();
  180.                 _nop_();
  181.                 if(DQ)
  182.                         dat |= 0X80;
  183.                 Delay(30);
  184.                 DQ = 1;
  185.         }
  186.         return dat;
  187. }
  188. void WriteOneByte(uchar dat)
  189. {
  190.         uchar i;
  191.         for(i=0;i<8;i++)
  192.         {
  193.                  DQ = 0;
  194.                 DQ = dat& 0x01;
  195.                 Delay(5);
  196.                 DQ = 1;
  197.                 dat >>= 1;
  198.         }
  199. }
  200. void Read_Temperature()
  201. {
  202.         if(Init_DS18B20()==1)
  203.                 DS18B20_IS_OK=0;
  204.         else
  205.         {
  206.                 WriteOneByte(0xcc);
  207.                 WriteOneByte(0x44);
  208.                 Init_DS18B20();
  209.                 WriteOneByte(0xcc);
  210.                 WriteOneByte(0xbe);
  211.                 Temp_Value[0] = ReadOneByte();
  212.                 Temp_Value[1] = ReadOneByte();
  213.                 DS18B20_IS_OK=1;
  214.         }
  215. }
  216. void Display_Temperature()
  217. {
  218.         uchar t = 150, ng = 0;
  219.         if((Temp_Value[1]&0xf8)==0xf8)
  220.         {
  221.                  Temp_Value[1] = ~Temp_Value[1];
  222.                 Temp_Value[0] = ~Temp_Value[0]+1;
  223.                 if(Temp_Value[0]==0x00)
  224.                         Temp_Value[1]++;
  225.                 ng = 1;
  226.         }
  227.         Display_Digit[0] = df_Table[Temp_Value[0]&0x0f];
  228.         CurrentT = ((Temp_Value[0]&0xf0)>>4) | ((Temp_Value[1]&0x07)<<4);
  229.         Display_Digit[3] = CurrentT/100;
  230.         Display_Digit[2] = CurrentT%100/10;
  231.         Display_Digit[1] = CurrentT%10;
  232.         Current_Temp_Display_Buffer[11] = Display_Digit[0] + '0';
  233.         Current_Temp_Display_Buffer[10] = '.';
  234.         Current_Temp_Display_Buffer[9]  = Display_Digit[1] + '0';
  235.         Current_Temp_Display_Buffer[8]  = Display_Digit[2] + '0';
  236.         Current_Temp_Display_Buffer[7]  = Display_Digit[3] + '0';
  237.         TEMP_NOW=Display_Digit[2]*10+Display_Digit[1]+Display_Digit[0]*0.1         ;
  238.         if(Display_Digit[3] == 0)
  239.                 Current_Temp_Display_Buffer[7]  = ' ';
  240.         if(Display_Digit[2] == 0&&Display_Digit[3]==0)
  241.                 Current_Temp_Display_Buffer[8]  = ' ';
  242.         if(ng)
  243.         {
  244.                 TEMP_NOW=-(Display_Digit[2]*10+Display_Digit[1]+Display_Digit[0]*0.1);
  245.                  if(Current_Temp_Display_Buffer[8]  == ' ')
  246.                         Current_Temp_Display_Buffer[8]  = '-';
  247.                 else if(Current_Temp_Display_Buffer[7]  == ' ')
  248.                         Current_Temp_Display_Buffer[7]  = '-';
  249.                 else
  250.                         Current_Temp_Display_Buffer[6]  = '-';
  251.         }
  252. }
  253. void Delay_key()
  254. {
  255.         uchar i;
  256.         for(i=0;i<200;i++);
  257. }
  258. uchar Keys_Scan()
  259. {
  260.         uchar sCode,kCode,k;
  261.         P1 = 0xf0;
  262.         if((P1&0xf0)!=0xf0)
  263.         {
  264.                  Delay_key();
  265.                 if((P1&0xf0)!=0xf0)
  266.                 {
  267.                          sCode = 0xfe;
  268.                         for(k=0;k<4;k++)
  269.                         {
  270.                                  P1 = sCode;
  271.                                 if((P1&0xf0)!=0xf0)
  272.                                 {
  273.                                          kCode = ~P1;
  274.                                         if(kCode == KeyCodeTable[0]) return K_ONE;
  275.                                         else if(kCode == KeyCodeTable[1]) return K_TWO;
  276.                                         else if(kCode == KeyCodeTable[2]) return K_THREE;
  277.                                         else if(kCode == KeyCodeTable[3]) return K_FOUR;
  278.                                         else if(kCode == KeyCodeTable[4]) return K_FIVE;
  279.                                         else if(kCode == KeyCodeTable[5]) return K_SIX;
  280.                                         else if(kCode == KeyCodeTable[6]) return K_SEVEN;
  281.                                         else if(kCode == KeyCodeTable[7]) return K_EIGHT;
  282.                                         else if(kCode == KeyCodeTable[8]) return K_NINE;
  283.                                         else if(kCode == KeyCodeTable[9]) return K_UP;
  284.                                         else if(kCode == KeyCodeTable[10]) return K_DOWN;
  285.                                         else if(kCode == KeyCodeTable[11]) return K_CLEAR;
  286.                                         else if(kCode == KeyCodeTable[12]) return K_OK;
  287.                                         else if(kCode == KeyCodeTable[13]) return K_ZERO;
  288.                                         else if(kCode == KeyCodeTable[14]) return K_POINT;
  289.                                         else if(kCode == KeyCodeTable[15]) return K_SET;
  290.                                 }
  291.                                 else
  292.                                         sCode = _crol_(sCode,1);
  293.                         }
  294.                 }
  295.         }
  296.         return -1;
  297. }
  298. void set_num()
  299. {
  300.         uchar key;
  301.         if(sel==0)
  302.         {
  303.                 key = Keys_Scan();
  304.                 if(K_CLEAR == key)
  305.                 {
  306.                         while(Keys_Scan() == K_CLEAR);
  307.                         set_Temp_Display_Buffer[8] =' ';
  308.                         set_Temp_Display_Buffer[9] =' ';
  309.                         set_Temp_Display_Buffer[10]=' ';
  310.                         set_Temp_Display_Buffer[11]=' ';  // 48(0)49(1)50(2)51(3)52(4)53(5)54(6)55(7)56(8)57(9)
  311.                         M_Count=0;
  312.                         cold=0;
  313.                         warm=0;
  314.                 }
  315.                 if(K_UP == key)
  316.                 {
  317.                         while(Keys_Scan() == K_UP);
  318.                         if((set_Temp_Display_Buffer[11]>47)&&(set_Temp_Display_Buffer[11]<57))
  319.                         {
  320.                                 set_Temp_Display_Buffer[11]+=1;
  321.                         }
  322.                         else if(set_Temp_Display_Buffer[11]==57)
  323.                         {
  324.                                 set_Temp_Display_Buffer[11]=48;
  325.                                 if((set_Temp_Display_Buffer[9]>47)&&(set_Temp_Display_Buffer[9]<57))
  326.                                 {
  327.                                         set_Temp_Display_Buffer[9]+=1;
  328.                                 }
  329.                                 else if(set_Temp_Display_Buffer[9]==57)
  330.                                 {
  331.                                         set_Temp_Display_Buffer[9]=48;
  332.                                         if((set_Temp_Display_Buffer[8]>47)&&(set_Temp_Display_Buffer[8]<57))
  333.                                         {
  334.                                                  set_Temp_Display_Buffer[8]+=1;
  335.                                         }
  336.                                         else if(set_Temp_Display_Buffer[8]==57)
  337.                                         {
  338.                                                  set_Temp_Display_Buffer[8]=48;
  339.                                         }
  340.                                 }
  341.                         }
  342.                 }
  343.                 if(K_DOWN == key)        // 48(0)49(1)50(2)51(3)52(4)53(5)54(6)55(7)56(8)57(9)
  344.                 {
  345.                         while(Keys_Scan() == K_DOWN);
  346.                         if((set_Temp_Display_Buffer[11]>48)&&(set_Temp_Display_Buffer[11]<58))
  347.                         {
  348.                                 set_Temp_Display_Buffer[11]-=1;
  349.                         }
  350.                         else if(set_Temp_Display_Buffer[11]==48)
  351.                         {
  352.                                 set_Temp_Display_Buffer[11]=57;
  353.                                 if((set_Temp_Display_Buffer[9]>48)&&(set_Temp_Display_Buffer[9]<58))
  354.                                 {
  355.                                         set_Temp_Display_Buffer[9]-=1;
  356.                                 }
  357.                                 else if(set_Temp_Display_Buffer[9]==48)
  358.                                 {
  359.                                         set_Temp_Display_Buffer[9]=57;
  360.                                         if((set_Temp_Display_Buffer[8]>48)&&(set_Temp_Display_Buffer[8]<58))
  361.                                         {
  362.                                                  set_Temp_Display_Buffer[8]-=1;
  363.                                         }
  364.                                         else if(set_Temp_Display_Buffer[8]==48)
  365.                                         {
  366.                                                  set_Temp_Display_Buffer[8]=57;
  367.                                         }
  368.                                 }
  369.                         }
  370.                 }
  371.                 if(K_ONE == key)
  372.                 {
  373.                         while(Keys_Scan() == K_ONE);
  374.                         set_Temp_Display_Buffer[11]='1';
  375.                         sel++;
  376.                 }
  377.                 if(K_TWO == key)
  378.                 {
  379.                         while(Keys_Scan() == K_TWO);
  380.                         set_Temp_Display_Buffer[11]='2';
  381.                         sel++;
  382.                 }
  383.                 if(K_THREE == key)
  384.                 {
  385.                         while(Keys_Scan() == K_THREE);
  386.                         set_Temp_Display_Buffer[11]='3';
  387.                         sel++;
  388.                 }
  389.                 if(K_FOUR == key)
  390.                 {
  391.                         while(Keys_Scan() == K_FOUR);
  392.                         set_Temp_Display_Buffer[11]='4';
  393.                         sel++;
  394.                 }
  395.                 if(K_FIVE == key)
  396.                 {
  397.                         while(Keys_Scan() == K_FIVE);
  398.                         set_Temp_Display_Buffer[11]='5';
  399.                         sel++;
  400.                 }
  401.                 if(K_SIX == key)
  402.                 {
  403.                         while(Keys_Scan() == K_SIX);
  404.                         set_Temp_Display_Buffer[11]='6';
  405.                         sel++;
  406.                 }
  407.                 if(K_SEVEN == key)
  408.                 {
  409.                         while(Keys_Scan() == K_SEVEN);
  410.                         set_Temp_Display_Buffer[11]='7';
  411.                         sel++;
  412.                 }
  413.                 if(K_EIGHT == key)
  414.                 {
  415.                         while(Keys_Scan() == K_EIGHT);
  416.                         set_Temp_Display_Buffer[11]='8';
  417.                         sel++;
  418.                 }
  419.                 if(K_NINE == key)
  420.                 {
  421.                         while(Keys_Scan() == K_NINE);
  422.                         set_Temp_Display_Buffer[11]='9';
  423.                         sel++;
  424.                 }
  425.                 if(K_ZERO == key)
  426.                 {
  427.                         while(Keys_Scan() == K_ZERO);
  428.                         set_Temp_Display_Buffer[11]='0';
  429.                         sel++;
  430.                 }
  431.                 if(K_OK == key)
  432.                 {
  433.                         while(Keys_Scan() == K_OK);
  434.                         TEMP_SET=(set_Temp_Display_Buffer[8]-48)*10+(set_Temp_Display_Buffer[9]-48)+(set_Temp_Display_Buffer[11]-48)*0.1;
  435.                         sel=0;
  436.                         M_Count=1;
  437.                 }
  438.         }
  439.         if(sel==1)
  440.         {
  441.                 key = Keys_Scan();
  442.                 if(K_CLEAR == key)
  443.                 {
  444.                         while(Keys_Scan() == K_CLEAR);
  445.                         set_Temp_Display_Buffer[8] =' ';
  446.                         set_Temp_Display_Buffer[9] =' ';
  447.                         set_Temp_Display_Buffer[10]=' ';
  448.                         set_Temp_Display_Buffer[11]=' ';
  449.                         M_Count=0;
  450.                         cold=0;
  451.                         warm=0;
  452.                         sel=0;
  453.                 }
  454.                 if(K_ONE == key)
  455.                 {
  456.                         while(Keys_Scan() == K_ONE);
  457.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  458.                         set_Temp_Display_Buffer[11]='1';
  459.                         sel++;
  460.                 }
  461.                 if(K_TWO == key)
  462.                 {
  463.                         while(Keys_Scan() == K_TWO);
  464.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  465.                         set_Temp_Display_Buffer[11]='2';
  466.                         sel++;
  467.                 }
  468.                 if(K_THREE == key)
  469.                 {
  470.                         while(Keys_Scan() == K_THREE);
  471.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  472.                         set_Temp_Display_Buffer[11]='3';
  473.                         sel++;
  474.                 }
  475.                 if(K_FOUR == key)
  476.                 {
  477.                         while(Keys_Scan() == K_FOUR);
  478.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  479.                         set_Temp_Display_Buffer[11]='4';
  480.                         sel++;
  481.                 }
  482.                 if(K_FIVE == key)
  483.                 {
  484.                         while(Keys_Scan() == K_FIVE);
  485.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  486.                         set_Temp_Display_Buffer[11]='5';
  487.                         sel++;
  488.                 }
  489.                 if(K_SIX == key)
  490.                 {
  491.                         while(Keys_Scan() == K_SIX);
  492.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  493.                         set_Temp_Display_Buffer[11]='6';
  494.                         sel++;
  495.                 }
  496.                 if(K_SEVEN == key)
  497.                 {
  498.                         while(Keys_Scan() == K_SEVEN);
  499.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  500.                         set_Temp_Display_Buffer[11]='7';
  501.                         sel++;
  502.                 }
  503.                 if(K_EIGHT == key)
  504.                 {
  505.                         while(Keys_Scan() == K_EIGHT);
  506.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  507.                         set_Temp_Display_Buffer[11]='8';
  508.                         sel++;
  509.                 }
  510.                 if(K_NINE == key)
  511.                 {
  512.                         while(Keys_Scan() == K_NINE);
  513.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  514.                         set_Temp_Display_Buffer[11]='9';
  515.                         sel++;
  516.                 }
  517.                 if(K_ZERO == key)
  518.                 {
  519.                         while(Keys_Scan() == K_ZERO);
  520.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  521.                         set_Temp_Display_Buffer[11]='0';
  522.                         sel++;
  523.                 }
  524.         }
  525.         if(sel==2)
  526.         {
  527.                 key = Keys_Scan();
  528.                 if(K_CLEAR == key)
  529.                 {
  530.                         while(Keys_Scan() == K_CLEAR);
  531.                         set_Temp_Display_Buffer[8] =' ';
  532.                         set_Temp_Display_Buffer[9] =' ';
  533.                         set_Temp_Display_Buffer[10]=' ';
  534.                         set_Temp_Display_Buffer[11]=' ';
  535.                         M_Count=0;
  536.                         cold=0;
  537.                         warm=0;
  538.                         sel=0;
  539.                 }
  540.                 if(K_POINT == key)
  541.                 {
  542.                         while(Keys_Scan() == K_POINT);
  543.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  544.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  545.                         set_Temp_Display_Buffer[11]='.';
  546.                         sel++;
  547.                 }
  548.         }
  549.         if(sel==3)
  550.         {
  551.                 key = Keys_Scan();
  552.                 if(K_CLEAR == key)
  553.                 {
  554.                         while(Keys_Scan() == K_CLEAR);
  555.                         set_Temp_Display_Buffer[8] =' ';
  556.                         set_Temp_Display_Buffer[9] =' ';
  557.                         set_Temp_Display_Buffer[10]=' ';
  558.                         set_Temp_Display_Buffer[11]=' ';
  559.                         M_Count=0;
  560.                         cold=0;
  561.                         warm=0;
  562.                         sel=0;
  563.                 }
  564.                 if(K_ONE == key)
  565.                 {
  566.                         while(Keys_Scan() == K_ONE);
  567.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  568.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  569.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  570.                         set_Temp_Display_Buffer[11]='1';
  571.                         sel++;
  572.                 }
  573.                 if(K_TWO == key)
  574.                 {
  575.                         while(Keys_Scan() == K_TWO);
  576.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  577.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  578.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  579.                         set_Temp_Display_Buffer[11]='2';
  580.                         sel++;
  581.                 }
  582.                 if(K_THREE == key)
  583.                 {
  584.                         while(Keys_Scan() == K_THREE);
  585.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  586.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  587.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  588.                         set_Temp_Display_Buffer[11]='3';
  589.                         sel++;
  590.                 }
  591.                 if(K_FOUR == key)
  592.                 {
  593.                         while(Keys_Scan() == K_FOUR);
  594.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  595.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  596.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  597.                         set_Temp_Display_Buffer[11]='4';
  598.                         sel++;
  599.                 }
  600.                 if(K_FIVE == key)
  601.                 {
  602.                         while(Keys_Scan() == K_FIVE);
  603.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  604.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  605.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  606.                         set_Temp_Display_Buffer[11]='5';
  607.                         sel++;
  608.                 }
  609.                 if(K_SIX == key)
  610.                 {
  611.                         while(Keys_Scan() == K_SIX);
  612.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  613.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  614.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  615.                         set_Temp_Display_Buffer[11]='6';
  616.                         sel++;
  617.                 }
  618.                 if(K_SEVEN == key)
  619.                 {
  620.                         while(Keys_Scan() == K_SEVEN);
  621.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  622.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  623.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  624.                         set_Temp_Display_Buffer[11]='7';
  625.                         sel++;
  626.                 }
  627.                 if(K_EIGHT == key)
  628.                 {
  629.                         while(Keys_Scan() == K_EIGHT);
  630.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  631.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  632.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  633.                         set_Temp_Display_Buffer[11]='8';
  634.                         sel++;
  635.                 }
  636.                 if(K_NINE == key)
  637.                 {
  638.                         while(Keys_Scan() == K_NINE);
  639.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  640.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  641.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  642.                         set_Temp_Display_Buffer[11]='9';
  643.                         sel++;
  644.                 }
  645.                 if(K_ZERO == key)
  646.                 {
  647.                         while(Keys_Scan() == K_ZERO);
  648.                         set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
  649.                         set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
  650.                         set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
  651.                         set_Temp_Display_Buffer[11]='0';
  652.                         sel++;
  653.                 }
  654.         }
  655.         if(sel==4)
  656.         {
  657.                 key = Keys_Scan();
  658.                 if(K_CLEAR == key)
  659.                 {
  660.                         while(Keys_Scan() == K_CLEAR);
  661.                         set_Temp_Display_Buffer[8] =' ';
  662.                         set_Temp_Display_Buffer[9] =' ';
  663.                         set_Temp_Display_Buffer[10]=' ';
  664.                         set_Temp_Display_Buffer[11]=' ';
  665.                         M_Count=0;
  666.                         cold=0;
  667.                         warm=0;
  668.                         sel=0;
  669.                 }
  670.                 if(K_OK == key)
  671.                 {
  672.                         while(Keys_Scan() == K_OK);
  673.                         TEMP_SET=(set_Temp_Display_Buffer[8]-48)*10+(set_Temp_Display_Buffer[9]-48)+(set_Temp_Display_Buffer[11]-48)*0.1;
  674.                         sel=0;
  675.                         M_Count=1;
  676.                 }
  677.         }
  678. }
  679. ////////////////////Ö÷3ìDò///////////////////////////////
  680. void main()
  681. {
  682.         init_lcd();
  683.         Init_DS18B20();
  684.         timer0_init();
  685.         while(1)
  686.         {
  687.                 Print();
  688.                 set_num();
  689.                 Comparison();
  690.         }
  691. }
  692. void Comparison()
  693. {
  694.         if(N_Count&&M_Count)
  695.         {
  696.                 if(TEMP_NOW<TEMP_SET)
  697.                 {
  698.                         warm=1;
  699.                         cold=0;
  700.                 }
  701.                 if(TEMP_NOW>TEMP_SET)
  702.                 {
  703.                         cold=1;
  704.                         warm=0;
  705.                 }
  706.                 if(TEMP_NOW==TEMP_SET)
  707.                 {
  708.                         cold=0;
  709.                         warm=0;
  710.                 }
  711.         }
  712. }
ID:138119 发表于 2019-9-19 10:17 | 只看该作者
我有基于PIC16F1847 + NTC热敏电阻 + 光耦可控硅输出 的PID恒温2度范围计算的 完整方案,之前在上家公司做的,可以修改成你的需要,不过您出辛苦费吗?
ID:221764 发表于 2020-4-10 10:33 | 只看该作者
yfpc2006 发表于 2019-9-19 10:17
我有基于PIC16F1847 + NTC热敏电阻 + 光耦可控硅输出 的PID恒温2度范围计算的 完整方案,之前在上家公司做 ...
怎么联系
ID:213173 发表于 2020-4-10 18:36 | 只看该作者
从你的框图看是控制直流电加热,根本不需要A/D转换,用PWM做恒温控制是轻而易举的事。
ID:593706 发表于 2020-4-11 11:34 | 只看该作者
楼主的图无法给出电原理图和源程序。你必须给出温度测量的范围、温度控制的精度、加热方式、加热功率,使用的场合,才可以给出完整可用的电原理图和源程序。
ID:591189 发表于 2020-4-11 17:04 | 只看该作者
这是我做的基于STC8A8K的温度控制装置,DS18B20监测温度,PID算法产生PWM控制加热丝加热的,我个人实物使用时温度控制在0.1度上下。加我QQ交流技术
