查看: 2249|回复: 0
arduino pro mini的pcb库
ID:342604 发表于 2018-6-1 00:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Altium的PCB元件库,内容超多,且都是平常最有用的一些元器件,如表贴器件(FQP, QFN, SOP, TSOP, TSSOP, SON,...),USB,无线天线,等等。    我只在Altium Winter 09(DXP 2008)中装入使用。其他如99SE,DXP200?没有测试。网友下载后可将使用结果在留言中说明。谢谢!希望大家喜欢。    以下是其中的文件列表:(200多个文件)Axial Lead Diode.PcbLibBGA_Rect.PcbLibBGA_Sq_100P.PcbLibBGA_Sq_127P.PcbLibBGA_Sq_150P.PcbLibBGA_Sq_40P.PcbLibBGA_Sq_50P.PcbLibBGA_Sq_65P.PcbLibBGA_Sq_75P.PcbLibBGA_Sq_80P.PcbLibBridge Rectifier.PcbLibBumpered QFP - Centre Index.PcbLibBumpered QFP - Corner Index.PcbLibCAN - Circle pin arrangement.PcbLibCAN - Rectangl                            e pin arrangement.PcbLibCapacitor Electrolytic Mount Ring.PcbLibCapacitor Electrolytic Snap-In.PcbLibCapacitor Non-Polar Axial.PcbLibCapacitor Non-Polar Dipped Radial.PcbLibCapacitor Non-Polar Disc.PcbLibCapacitor Non-Polar Tubular.PcbLibCapacitor Polar Axial.PcbLibCapacitor Polar Radial Cylinder.PcbLibCapacitor Tantalum Leadless.PcbLibCapacitor Tantalum Radial Bead.PcbLibCapacitor Tantalum Radial Oval.PcbLibCapacitor Tantalum Radial Rectangle.PcbLibCeramic DFP.PcbLibCGA_Sq_100P.PcbLibCGA_Sq_127P.PcbLibChip Diode - 2 Contacts.PcbLibChip Resistor Array - Panasonic.PcbLibChip_Capacitor_L.PcbLibChip_Capacitor_M.PcbLibChip_Capacitor_N.PcbLibChip_Inductor_L.PcbLibChip_Inductor_M.PcbLibChip_Inductor_N.PcbLibChip_Resistor_L.PcbLibChip_Resistor_M.PcbLibChip_Resistor_N.PcbLibCon 050 DSubminiature.PcbLibCon Audio Video.PcbLibCon Audio.PcbLibCon Board-to-Board.PcbLibCon Card.PcbLibCon CardEdge.PcbLibCon CompactPCI.PcbLibCon DIN 41612.PcbLibCon DIN Circular.PcbLibCon Docking Station.PcbLibCon FPC-FFC.PcbLibCon High-Speed PCB.PcbLibCon IDC.PcbLibCon IEEE1394.PcbLibCon Low Power.PcbLibCon Mains Power.PcbLibCon Mod Jack PCB.PcbLibCon Rect Stag PCB.PcbLibCon RF Coaxial.PcbLibCon USB.PcbLibContents_290709.txtCQFP_Sq_127P_Side_L.PcbLibCQFP_Sq_127P_Side_M.PcbLibCQFP_Sq_127P_Side_N.PcbLibCQFP_Sq_50P_Side_L.PcbLibCQFP_Sq_50P_Side_M.PcbLibCQFP_Sq_50P_Side_N.PcbLibCQFP_Sq_63P_Ctr_L.PcbLibCQFP_Sq_63P_Ctr_M.PcbLibCQFP_Sq_63P_Ctr_N.PcbLibCQFP_Sq_63P_Side_L.PcbLibCQFP_Sq_63P_Side_M.PcbLibCQFP_Sq_63P_Side_N.PcbLibCQFP_Sq_65P_Side_L.PcbLibCQFP_Sq_65P_Side_M.PcbLibCQFP_Sq_65P_Side_N.PcbLibCQFP_Sq_80P_Side_L.PcbLibCQFP_Sq_80P_Side_M.PcbLibCQFP_Sq_80P_Side_N.PcbLibCrystal Oscillator.PcbLibCylinder with Flat Index.PcbLibDiamond Base CAN - 2 Leads.PcbLibDiamond Base CAN - 3+ Leads.PcbLibDIP - LED Display.PcbLibDIP - Peg Leads.PcbLibDIP, Modified - Trimmed Leads.PcbLibDIP, Shrink - Stub Leads.PcbLibDPAK_L.PcbLibDPAK_M.PcbLibDPAK_N.PcbLibDual-In-Line Package.PcbLibFlange Mount with Rectangular Base.PcbLibHorizontal, Flange Mount with Tab.PcbLibLCC_Sq_L.PcbLibLCC_Sq_M.PcbLibLCC_Sq_N.PcbLibLeaded Chip Carrier - Rectangle.PcbLibLeadless Chip Carrier - Rectangle.PcbLibLeadless Chip Carrier - Square.PcbLibLog_290709.txtLow Profile Module (LPM).PcbLibMELF - Diode.PcbLibMELF - Resistor.PcbLibMicroSMD_40P_V.PcbLibMicroSMD_50P_V.PcbLibMiscellaneous Connector PCB.PcbLibMiscellaneous Devices PCB.PcbLibMiscellaneous.PcbLibPcbLib.LstPin Grid Array Package (PGA).PcbLibPLCC_Sq_127P_Ctr_L.PcbLibPLCC_Sq_127P_Ctr_M.PcbLibPLCC_Sq_127P_Ctr_N.PcbLibQFN_Rect_50P_Side_V.PcbLibQFN_Sq_100P_Side_L.PcbLibQFN_Sq_100P_Side_M.PcbLibQFN_Sq_100P_Side_N.PcbLibQFN_Sq_40P_Side_L.PcbLibQFN_Sq_40P_Side_M.PcbLibQFN_Sq_40P_Side_N.PcbLibQFN_Sq_40P_Side_V.PcbLibQFN_Sq_50P_Side_L.PcbLibQFN_Sq_50P_Side_M.PcbLibQFN_Sq_50P_Side_N.PcbLibQFN_Sq_50P_Side_V.PcbLibQFN_Sq_65P_Side_L.PcbLibQFN_Sq_65P_Side_M.PcbLibQFN_Sq_65P_Side_N.PcbLibQFN_Sq_65P_Side_V.PcbLibQFN_Sq_80P_Side_L.PcbLibQFN_Sq_80P_Side_M.PcbLibQFN_Sq_80P_Side_N.PcbLibQFP_Rect_100P_Side_L.PcbLibQFP_Rect_100P_Side_M.PcbLibQFP_Rect_100P_Side_N.PcbLibQFP_Rect_65P_Side_L.PcbLibQFP_Rect_65P_Side_M.PcbLibQFP_Rect_65P_Side_N.PcbLibQFP_Rect_80P_Side_L.PcbLibQFP_Rect_80P_Side_M.PcbLibQFP_Rect_80P_Side_N.PcbLibQFP_Shrink_Rect_30P_Side_L.PcbLibQFP_Shrink_Rect_30P_Side_M.PcbLibQFP_Shrink_Rect_30P_Side_N.PcbLibQFP_Shrink_Rect_40P_Side_L.PcbLibQFP_Shrink_Rect_40P_Side_M.PcbLibQFP_Shrink_Rect_40P_Side_N.PcbLibQFP_Shrink_Rect_50P_Side_L.PcbLibQFP_Shrink_Rect_50P_Side_M.PcbLibQFP_Shrink_Rect_50P_Side_N.PcbLibQFP_Shrink_Sq_40P_Side_L.PcbLibQFP_Shrink_Sq_40P_Side_M.PcbLibQFP_Shrink_Sq_40P_Side_N.PcbLibQFP_Shrink_Sq_50P_Side_L.PcbLibQFP_Shrink_Sq_50P_Side_M.PcbLibQFP_Shrink_Sq_50P_Side_N.PcbLibQFP_Sq_100P_Side_L.PcbLibQFP_Sq_100P_Side_M.PcbLibQFP_Sq_100P_Side_N.PcbLibQFP_Sq_127P_Side_L.PcbLibQFP_Sq_127P_Side_M.PcbLibQFP_Sq_127P_Side_N.PcbLibQFP_Sq_65P_Side_L.PcbLibQFP_Sq_65P_Side_M.PcbLibQFP_Sq_65P_Side_N.PcbLibQFP_Sq_80P_Side_L.PcbLibQFP_Sq_80P_Side_M.PcbLibQFP_Sq_80P_Side_N.PcbLibQFP_Thin_Rect_50P_Side_L.PcbLibQFP_Thin_Rect_50P_Side_M.PcbLibQFP_Thin_Rect_50P_Side_N.PcbLibQFP_Thin_Rect_65P_Side_L.PcbLibQFP_Thin_Rect_65P_Side_M.PcbLibQFP_Thin_Rect_65P_Side_N.PcbLibQFP_Thin_Sq_40P_Side_L.PcbLibQFP_Thin_Sq_40P_Side_M.PcbLibQFP_Thin_Sq_40P_Side_N.PcbLibQFP_Thin_Sq_50P_Side_L.PcbLibQFP_Thin_Sq_50P_Side_M.PcbLibQFP_Thin_Sq_50P_Side_N.PcbLibQFP_Thin_Sq_50P_Side_V.PcbLibQFP_Thin_Sq_65P_Side_L.PcbLibQFP_Thin_Sq_65P_Side_M.PcbLibQFP_Thin_Sq_65P_Side_N.PcbLibQFP_Thin_Sq_65P_Side_V.PcbLibQFP_Thin_Sq_80P_Side_L.PcbLibQFP_Thin_Sq_80P_Side_M.PcbLibQFP_Thin_Sq_80P_Side_N.PcbLibQuad In-Line Package (QUIP).PcbLibResistor - Axial.PcbLibSingle In-Line with Mounting Hole.PcbLibSingle In-Line with no Mounting Hole.PcbLibSingle-In-Line Package - 5+ Leads.PcbLibSmall Outline Diode - 2 C-Bend Leads.PcbLibSmall Outline Diode - 2 Flat Leads.PcbLibSmall Outline Diode - 2 Gullwing Leads.PcbLibSmall Outline Diode - 2 Yoke Leads.PcbLibSmall Outline Diode - 2 Z-Bend Leads.PcbLibSmall Outline Diode - 3+ Flat Leads.PcbLibSmall Outline with C-Bend Leads.PcbLibSmall Outline with J Leads.PcbLibSOIC_127P_L.PcbLibSOIC_127P_M.PcbLibSOIC_127P_N.PcbLibSON_127P_V.PcbLibSON_40P_L.PcbLibSON_40P_M.PcbLibSON_40P_N.PcbLibSON_40P_V.PcbLibSON_50P_L.PcbLibSON_50P_M.PcbLibSON_50P_N.PcbLibSON_50P_V.PcbLibSON_65P_L.PcbLibSON_65P_M.PcbLibSON_65P_N.PcbLibSON_65P_V.PcbLibSON_80P_V.PcbLibSON_95P_V.PcbLibSOP_102P_L.PcbLibSOP_102P_M.PcbLibSOP_102P_N.PcbLibSOP_127P_L.PcbLibSOP_127P_M.PcbLibSOP_127P_N.PcbLibSOP_254P_L.PcbLibSOP_254P_M.PcbLibSOP_254P_N.PcbLibSOP_635P_L.PcbLibSOP_635P_M.PcbLibSOP_635P_N.PcbLibSOP_65P_L.PcbLibSOP_65P_M.PcbLibSOP_65P_N.PcbLibSOP_80P_L.PcbLibSOP_80P_M.PcbLibSOP_80P_N.PcbLibSOT - 3 Flat Leads.PcbLibSOT 89.PcbLibSOT143_L.PcbLibSOT143_M.PcbLibSOT143_N.PcbLibSOT223_L.PcbLibSOT223_M.PcbLibSOT223_N.PcbLibSOT23_5-6Lead_L.PcbLibSOT23_5-6Lead_M.PcbLibSOT23_5-6Lead_N.PcbLibSOT23_L.PcbLibSOT23_M.PcbLibSOT23_N.PcbLibSOT343_L.PcbLibSOT343_M.PcbLibSOT343_N.PcbLibSOT89_L.PcbLibSOT89_M.PcbLibSOT89_N.PcbLibTSOP_65P_L.PcbLibTSOP_65P_M.PcbLibTSOP_65P_N.PcbLibTSSOP_30P_L.PcbLibTSSOP_30P_M.PcbLibTSSOP_30P_N.PcbLibTSSOP_40P_L.PcbLibTSSOP_40P_M.PcbLibTSSOP_40P_N.PcbLibTSSOP_50P_L.PcbLibTSSOP_50P_M.PcbLibTSSOP_50P_N.PcbLibTSSOP_55P_L.PcbLibTSSOP_55P_M.PcbLibTSSOP_55P_N.PcbLibVertical, Dual-Row, Flange Mount with Tab.PcbLibVertical, Single-Row, Flange Mount with Tab.PcbLibZig-Zag-In-Line Package Odd Lead Number.PcbLibZig-Zag-In-Line Package, Even Lead Number.PcbLib
