查看: 1902|回复: 0
51单片机与DHT11传感器
ID:343401 发表于 2018-6-2 12:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include "1602.h"
#include "dht.h"
//定义标识
volatile bit FlagStartRH = 0;  //开始温湿度转换标志
//定义温湿度传感器用外部变量
extern U8  U8FLAG,k;
extern U8  U8count,U8temp;
extern U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
extern U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
extern U8  U8comdata;
extern U8  count, count_r;
U16 temp;
S16 temperature, humidity;
//定义变量
U16 RHCounter;
//定时器0初始化
void Timer0_Init()
    ET0 = 1;        //允许定时器0中断
    TMOD = 1;       //定时器工作方式选择
    TL0 = 0x06;
    TH0 = 0xf8;     //定时器赋予初值
    TR0 = 1;        //启动定时器
//定时器0中断
void Timer0_ISR (void) interrupt 1 using 0
    TL0 = 0x06;
    //每2秒钟启动一次温湿度转换
    RHCounter ++;
    if (RHCounter >= 1000)
       FlagStartRH = 1;
       RHCounter = 0;
* 名称 : Main()
* 功能 : 主函数
    U16 i, j, testnum;
    EA = 0;
    Timer0_Init();  //定时器0初始化
    EA = 1;
    L1602_init();
    L1602_string(1,1," Welcome to T&H   ");
    L1602_string(2,1,"Detection System! ");
    //延时
    for (i=0;i<1000;i++)
       for (j=0;j<1000;j++)
    //清屏
    L1602_string(1,1,"                ");
    L1602_string(2,1,"                ");
    L1602_string(1,1,"Temperature:   C");
    L1602_string(2,1,"Humidity:      %");
       //温湿度转换标志检查
         if (FlagStartRH == 1)
             TR0 = 0;
             testnum = RH();
             FlagStartRH = 0;
             TR0 = 1;
             //读出温湿度,只取整数部分
             humidity = U8RH_data_H;
             temperature = U8T_data_H;
             //显示温湿度
             L1602_int(1,12,temperature);
             L1602_int(2,12,humidity);
#ifndef _DHT_H_
#define _DHT_H_
#include <reg52.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable      无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable        有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable     无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable       有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable     无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable       有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
sbit DATA = P1^7;
void Delay1(U16 );
void  Delay_10us(void);
void  COM(void);
U8 RH(void);
#endif
