查看: 2079|回复: 1
基于51单片机的四传感器的智能小车循迹
ID:295220 发表于 2018-6-4 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit IN1=P0^0;
sbit IN2=P0^1;
sbit IN3=P0^2;
sbit IN4=P0^3;
sbit L_PWM=P0^4;
sbit R_PWM=P0^5;
sbit hongwai_l1=P2^2;
sbit hongwai_r1=P2^3;
sbit hongwai_l2=P2^4;
sbit hongwai_r2=P2^5;
unsigned char l_tt=0;
unsigned char l_Lpwm=3;
unsigned char l_Rpwm=3;
void timer0()interrupt 1   using 2   //&para;¨&Ecirc;±&AElig;÷&Ouml;&ETH;&para;&Iuml;1&pound;&not;&Oacute;&Atilde;&micro;&Uacute;2×é&frac14;&Auml;&acute;&aelig;&AElig;÷
        TH0=0XFC;
        TL0=0X18;
        l_tt++;
        if(l_tt>9)l_tt=0;
        if(l_tt<=l_Lpwm){
                 L_PWM=1;
        else{
                L_PWM=0;
        if(l_tt<=l_Rpwm){
                R_PWM=1;
        else{
                R_PWM=0;
void delay1ms(uint i)
uint t;
for(;i>0;i--)
  for(t=110;t>0;t--);
void main(void)
        EA=1;
        TMOD|=0X11;
        TH0= 0XFC;
        TL0= 0X14;
        TR0= 1;
        ET0= 1;
        while(1){
                 if(hongwai_l1==0&&hongwai_r1==0)
          IN1=1;
          IN2=0;
          IN3=1;
          IN4=0;
          delay1ms(10);
         if(hongwai_l1==1&&hongwai_r1==1)
          IN1=1;
          IN2=1;
          IN3=1;
          IN4=1;
          delay1ms(200);
          IN1=0;
          IN2=1;
          IN3=0;
          IN4=1;
          delay1ms(200);
         if(hongwai_l1==1&&hongwai_r1==0)
           IN1=1;
          IN2=1;
          IN3=1;
          IN4=0;
          delay1ms(10);
         if(hongwai_l1==0&&hongwai_r1==1)
           IN1=1;
          IN2=0;
          IN3=1;
          IN4=1;
          delay1ms(10);
                 if(hongwai_l2==1)
          IN1=0;
          IN2=1;
          IN3=1;
          IN4=0;
           if(hongwai_l1==1)
           break;
               if(hongwai_r2==1)
         IN1=1;
         IN2=0;
         IN3=0;
         IN4=1;
        if(hongwai_r1==1)
         break;
ID:229756 发表于 2018-6-8 20:37 | 只看该作者
感谢分享
