查看: 2376|回复: 0
STM32超声波测距程序
ID:338925 发表于 2018-6-5 21:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "timer.h"
  2. #include "usart.h"
  3. #include "sys.h"
  4. void TIM4_Cap_Init(u16 arr,u16 psc)
  5. {
  6.         GPIO_InitTypeDef        GPIO_InitStructure;
  7.         TIM_ICInitTypeDef  TIM4_ICInitStructure;
  8.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  9.         NVIC_InitTypeDef NVIC_InitStructure;
  10.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);        //使能TIM4时钟
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);  //使能GPIOB时钟
  12.
  13.         /*TRIG触发信号*/
  14.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  15.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;                //推挽输出
  16.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8;
  17.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  18.         GPIO_ResetBits(GPIOB,GPIO_Pin_8);
  19.
  20.         /*ECOH回响信号*/
  21.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;                //浮空输入
  22.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
  23.         GPIO_Init(GPIOB, & GPIO_InitStructure);
  24.         GPIO_ResetBits(GPIOB,GPIO_Pin_9);
  25.         //初始化定时器4 TIM4
  26.         TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
  27.         TIM_TimeBaseStructure.TIM_Prescaler =psc;         //预分频器
  28.         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //不分频
  29.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
  30.         TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  31.
  32.         //初始化TIM4输入捕获参数
  33.         TIM4_ICInitStructure.TIM_Channel = TIM_Channel_4; //CC4S=01         选择输入端 IC4映射到TI4上
  34.   TIM4_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;        //上升沿捕获
  35.   TIM4_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI4上
  36.   TIM4_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;         //配置输入分频,不分频
  37.   TIM4_ICInitStructure.TIM_ICFilter = 0x03;//IC4F=0000 配置输入滤波器 不滤波
  38.   TIM_ICInit(TIM4, &TIM4_ICInitStructure);
  39.
  40.         //中断分组初始化
  41.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //TIM4中断
  42.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
  43.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  //从优先级0级
  44.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
  45.         NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
  46.
  47.         TIM_ITConfig(TIM4,TIM_IT_Update|TIM_IT_CC4,ENABLE);//允许更新中断 ,允许CC4IE捕获中断
  48.
  49.   TIM_Cmd(TIM4,ENABLE);
  50. }
  51. u8  TIM4CH4_CAPTURE_STA=0;        //输入捕获状态
  52. u16        TIM4CH4_CAPTURE_VAL;        //输入捕获值-----用来记录捕获到下降沿的时候 TIM4 _CNT的值
  53. //定时器4中断服务程序
  54. void TIM4_IRQHandler(void)
  55. {
  56.         if((TIM4CH4_CAPTURE_STA&0X80)==0)//还未成功捕获
  57.         {
  58.                 if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  59.
  60.                 {
  61.                         if(TIM4CH4_CAPTURE_STA&0X40)//已经捕获到高电平了
  62.                         {
  63.                                 if((TIM4CH4_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
  64.                                 {
  65.                                         TIM4CH4_CAPTURE_STA|=0X80;//标记成功捕获了一次
  66.                                         TIM4CH4_CAPTURE_VAL=0XFFFF;
  67.                                 }else TIM4CH4_CAPTURE_STA++;
  68.                         }
  69.                 }
  70.         if (TIM_GetITStatus(TIM4, TIM_IT_CC4) != RESET)//捕获4发生捕获事件
  71.                 {
  72.                         if(TIM4CH4_CAPTURE_STA&0X40)                //捕获到一个下降沿
  73.                         {
  74.                                 TIM4CH4_CAPTURE_STA|=0X80;                //标记成功捕获到一次上升沿
  75.                                 TIM4CH4_CAPTURE_VAL=TIM_GetCapture4(TIM4);
  76.                            TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Rising); //CC4P=0 设置为上升沿捕获
  77.                         }else        //还未开始,第一次捕获上升沿
  78.                         {
  79.                                 TIM4CH4_CAPTURE_STA=0;                        //清空
  80.                                 TIM4CH4_CAPTURE_VAL=0;
  81.                                  TIM_SetCounter(TIM4,0);
  82.                                 TIM4CH4_CAPTURE_STA|=0X40;                //标记捕获到了上升沿
  83.                            TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Falling);                //CC4P=1 设置为下降沿捕获
  84.                         }
  85.                 }
  86.         }
  87.     TIM_ClearITPendingBit(TIM4, TIM_IT_CC4|TIM_IT_Update); //清除中断标志位
  88. }
