查看: 1819|回复: 0
STM32F4 ADC代码
ID:346755 发表于 2018-6-7 10:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "adc.h"
#include "delay.h"
//初始化ADC
void  Adc_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
        ADC_InitTypeDef       ADC_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//使能GPIOA时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //使能ADC1时钟
  //先初始化ADC1通道5 IO口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//PA5 通道5
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;//模拟输入
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;//不带上下拉
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,ENABLE);          //ADC1复位
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,DISABLE);        //复位结束
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;//独立模式
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//两个采样阶段之间的延迟5个时钟
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; //DMA失能
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;//预分频4分频。ADCCLK=PCLK2/4=84/4=21Mhz,ADC时钟最好不要超过36Mhz
  ADC_CommonInit(&ADC_CommonInitStructure);//初始化
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//12位模式
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;//非扫描模式
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//关闭连续转换
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//禁止触发检测,使用软件触发
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐
  ADC_InitStructure.ADC_NbrOfConversion = 1;//1个转换在规则序列中 也就是只转换规则序列1
  ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
        ADC_Cmd(ADC1, ENABLE);//开启AD转换器
//获得ADC值
//ch: @ref ADC_channels
//通道值 0~16取值范围为:ADC_Channel_0~ADC_Channel_16
//返回值:转换结果
u16 Get_Adc(u8 ch)
                  //设置指定ADC的规则组通道,一个序列,采样时间
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_480Cycles );        //ADC1,ADC通道,480个周期,提高采样时间可以提高精确度
        ADC_SoftwareStartConv(ADC1);                //使能指定的ADC1的软件转换启动功能
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束
        return ADC_GetConversionValue(ADC1);        //返回最近一次ADC1规则组的转换结果
//获取通道ch的转换值,取times次,然后平均
//ch:通道编号
//times:获取次数
//返回值:通道ch的times次转换结果平均值
u16 Get_Adc_Average(u8 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        for(t=0;t<times;t++)
                temp_val+=Get_Adc(ch);
                delay_ms(5);
        return temp_val/times;
