查看: 2130|回复: 1
Mesh v1.0规范 英文版下载
ID:347029 发表于 2018-6-7 16:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Mesh v1.0规范 官方搬运
1    Introduction
The Bluetooth Mesh Profile specification defines fundamental requirements to enable an interoperable mesh networking solution for Bluetooth low energy wireless technology.
1.1    Conformance
If conformance to this specification is claimed, all capabilities indicated as mandatory for this specification shall be supported in the specified manner (process-mandatory). This also applies for all optional and conditional capabilities for which support is indicated.
1.2    Bluetooth specification release compatibility
This specification shall be used with:
•    Core Specification Addendum 6 [3] combined with an allowed Bluetooth Core Specification (see [3] Volume 1, Part D, Section 1.2, Table 1.3), OR
•    Any version of the Bluetooth Core Specification later than v5.0.
The Generic Attribute Profile (GATT) is required if the GATT provisioning bearer defined in Section 5.2.2 is supported or if the GATT bearer defined in Section 3.3.2 is supported.
1.3    Language
1.3.1    Language conventions
The Bluetooth SIG has established the following conventions for use of the words shall, must, will, should, may, can, is, and note in the development of specifications:
全部资料51hei下载地址:
Mesh_v1.0 (1).docx (4.52 MB, 下载次数: 19)
收藏收藏 分享淘帖 顶1 踩
ID:548072 发表于 2019-5-27 08:44 | 只看该作者
好资料
