查看: 1643|回复: 0
stm32 pwm简单程序
ID:347642 发表于 2018-6-8 15:32 | 显示全部楼层 |阅读模式
  1. #include<stm32f10x.h>
  2. void TIM3_PWM_Init(u16 arr,u16 psc);
  3. //1ms延时函数(72MHz)
  4. void delay_nms(u16 time)
  5. {
  6.         u16 i=0;
  7.         while(time--)
  8.         {
  9.                 i=12000;
  10.                 while(i--);
  11.         }
  12. }
  13. int main(void)
  14. {
  15.         u16 TIMpulse=0;
  16.         u8 dir=1;
  17.         //TIM3_PWM_Init(899,0);//不分频,PWM频率=72000/900=80khz
  18.         TIM3_PWM_Init(999,61999);//1HZ,
  19.         delay_nms(100);//观察初始化的pwm
  20. //        TIM_SetCompare2(TIM3,200);//占空比200/999+1=20%
  21.         while(1)
  22.         {
  23.                 if(dir)TIMpulse++;
  24.                 else TIMpulse--;
  25.                 if(TIMpulse>999)dir=0;
  26.                 if(TIMpulse==0)dir=1;
  27.                 TIM_SetCompare2(TIM3,TIMpulse);//程序中修改占空比TIMpulse/arr
  28.                 ;
  29.         }
  30. }
  31. //arr:自动装载值   psc:预分频数
  32. //TIM3 PWM部分初始化
  33. void TIM3_PWM_Init(u16 arr,u16 psc)
  34. {
  35.         GPIO_InitTypeDef GPIO_InitStructure;
  36.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  37.         TIM_OCInitTypeDef TIM_OCInitStructure;
  38.
  39.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
  40.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO,ENABLE);//开启重映射时钟
  41.
  42.         GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);//重映射TIM3_CH2到PB5输出
  43.
  44.         //GPIO设置为复用输出,输出TIM3的CH2的PWM脉冲波形GPIOB5
  45.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  46.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5;
  47.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  48.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  49.
  50.         //初始化TIM3
  51.         TIM_TimeBaseStructure.TIM_Period=arr;                                        //设置自动重装载周期值(决定PWM的频率)
  52.         TIM_TimeBaseStructure.TIM_Prescaler=psc;                                //预分频值
  53.         TIM_TimeBaseStructure.TIM_ClockDivision=0;                                //设置时钟分割:TDTS=Tck_tim
  54.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上计数
  55.         TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
  56.
  57.         //初始化TIM3 Channel2 PWM模式
  58.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;                                //选择PWM模式2,计数值大于比较值有效
  59.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;        //比较输出使能
  60.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;                //输出极性 高为有效值
  61.         //配置占空比  500/arr重载计数器=500/999+1,,和函数TIM_SetCompare2(TIM3,TIMpulse);功能一样
  62.     TIM_OCInitStructure.TIM_Pulse=500;
  63.         TIM_OC2Init(TIM3,&TIM_OCInitStructure);                                                //初始化外设TIM3 OC2通道
  64.         TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);                        //使能预装载器即TIM3_CCR2的预装载值在更新事件到来时才能被传送至当前寄存器中
  65.
  66.         TIM_Cmd(TIM3,ENABLE);        //使能TIM3
  67. }
