查看: 2538|回复: 0
XHDZ-30102引脚图与pdf资料手册下载
XHDZ-30102引脚图:
管脚功能:
XHDZ-30102芯片介绍:
General Description
The MAX30102 is an integrated pulse oximetry and
heart-rate monitor module. It includes internal LEDs,
photodetectors, optical elements, and low-noise electronics
with ambient light rejection. The MAX30102 provides a
complete system solution to ease the design-in process
for mobile and wearable devices.
The MAX30102 operates on a single 1.8V power supply
and a separate 5.0V power supply for the internal LEDs.
Communication is through a standard I2C-compatible
interface. The module can be shut down through software
with zero standby current, allowing the power rails to
remain powered at all times.
完整的pdf格式文档51黑下载地址:
MAX30102.pdf (930.99 KB, 下载次数: 7)
