查看: 5011|回复: 3
51单片机时钟设计C语言程序
ID:349605 发表于 2018-6-11 16:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit duan = P1^6; //段选
sbit wei = P1^7; //位选
sbit S1 = P3^0;        //暂停键
sbit S2 = P3^1;        //增加键
sbit S3 = P3^4;        //减少键
sbit S4 = P3^5; //闹钟设置键
sbit S5 = P3^6; //闹钟启用停止键
sbit BEE = P1^5;//蜂鸣器
uchar code aaa[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar temp,out = 1,qq = 0,ww = 0,H,M,S,j1,j2,k1,k2,l1,l2;
uchar H1 = 0,M1 = 0,Sa = 0,j10,j20,k10,k20,l10,l20,SS = 0;
uint UT;
void delayMS(x) //延时函数,单位毫秒
        uint a , b;
        for(a = 0 ; a < x ; a++ )
        for(b = 0 ; b < 110 ; b++);
void play(uint h1 , uint h2 , uint m1 , uint m2 , uint s1 , uint s2) //时分秒的显示
        wei = 1; //时的十位
        P2 = 0x7f;
        wei = 0;
        duan = 1;
        P0 = aaa[h1];
        duan = 0;
        delayMS(3);
        wei = 1; //时的个位
        P2 = 0xbf;
        wei = 0;
        duan = 1;
        P0 = aaa[h2];
        duan = 0;
        delayMS(3);
        wei = 1; //分的十位
        P2 = 0xdf;
        wei = 0;
        duan = 1;
        P0 = aaa[m1];
        duan = 0;
        delayMS(3);
        wei = 1; //分的个位
        P2 = 0xef;
        wei = 0;
        duan = 1;
        P0 = aaa[m2];
        duan = 0;
        delayMS(3);
        wei = 1; //秒的十位
        P2 = 0xf7;
        wei = 0;
        duan = 1;
        P0 = aaa[s1];
        duan = 0;
        delayMS(3);
        wei = 1; //秒的个位
        P2 = 0xfb;
        wei = 0;
        duan = 1;
        P0 = aaa[s2];
        duan = 0;
        delayMS(3);
void stopfunc() //S1键函数 暂停
        if(S1 == 0)
                while(!S1);
                qq++;
                out = 0; //暂停
                TR0 = 0;
void WWS4() //闹钟设置
        if(S4 == 0)
                while(!S4);
                ww++;
void begin() //S5键 闹钟启动和停止
        if(S5 == 0)
                while(!S5);
                SS = !SS;
void ala() //闹钟控制蜂鸣器
        if((H == H1) && (M == M1) && (SS == 1))
                BEE = 0;
        if((H == H1) && (M == M1+1) || (SS == 0))
                BEE = 1;
void buttfunc() //S2键、S3键函数 调时
        if(qq == 1) //第一次按S1时,调秒
                if(S2 == 0)
                        while(!S2);
                        if(S < 59)
                                S++;
                                S = 0;
                        delayMS(5);
                if(S3 == 0)
                        while(!S3);
                        if(S > 0)
                                S--;
                                S = 59;
                        delayMS(5);
                        j1=H%10;
                        j2=H/10;
                        k1=M%10;
                        k2=M/10;
                        l1=S%10;
                        l2=S/10;
                        play(j2,j1,k2,k1,l2,l1);
        if(qq == 2) //第二次按S1时,调分
                if(S2 == 0)
                        while(!S2);
                        if(M < 59)
                                M++;
                                M = 0;
                        delayMS(5);
                if(S3 == 0)
                        while(!S3);
                        if(M > 0)
                                M--;
                                M = 59;
                        delayMS(5);
                        j1=H%10;
                        j2=H/10;
                        k1=M%10;
                        k2=M/10;
                        l1=S%10;
                        l2=S/10;
        if(qq == 3) //第三次按S1时,调时
                if(S2 == 0)
                        while(!S2);
                        if(H < 23)
                                H++;
                                H = 0;
                        delayMS(5);
                if(S3 == 0)
                        while(!S3);
                        if(H > 0)
                                H--;
                                H = 23;
                        delayMS(5);
                        j1=H%10;
                        j2=H/10;
                        k1=M%10;
                        k2=M/10;
                        l1=S%10;
                        l2=S/10;
        if(qq == 4) //第四次 ,设闹钟
                j10=H1%10;
                j20=H1/10;
                k10=M1%10;
                k20=M1/10;
                l10=Sa%10;
                l20=Sa/10;
                play(j20,j10,k20,k10,l20,l10);
                if(ww == 1)
                        if(S2 == 0)
                                while(!S2);
                                if(M1 < 59)
                                        M1++;
                                        M1 = 0;
                                delayMS(5);
                        if(S3 == 0)
                                while(!S3);
                                if(M1 > 1)
                                        M1--;
                                        M1 = 59;
                if(ww == 2)
                        if(S2 == 0)
                                while(!S2);
                                if(H1 < 23)
                                        H1++;
                                        H1 = 0;
                                delayMS(5);
                        if(S3 == 0)
                                while(!S3);
                                if(H1 > 1)
                                        H1--;
                                        H1 = 23;
        if(qq == 5) //第五次按S1时,继续计时
                while(!S1);
                qq = 0;
                ww = 0;
                out = 1;
        TMOD = 0x01; //定时器0
        IE = 0x83; //中断打开,打开外部中断0和定时器0中断
        TH0 = (65536 - 46080)/256; //初值:2^16=65536   11.0592*10^6 * 50*10^(-3)=46080 (晶振*中断时间)
        TL0 = (65536 - 46080)%256;
                stopfunc();
                begin();
                ala();
                if(out == 1)
                        TR0 = 1;
                        if(UT == 20) //1秒钟到了----20*50=1000ms
                                UT = 0;
                                S++;
                                if(S == 60)
                                        S=0;
                                        M++;
                                        if(M == 60)
                                                M = 0;
                                                H++;
                                                if(H == 24) //24小时制
                                                        H = 0;
                        j1=H%10;
                        j2=H/10;
                        k1=M%10;
                        k2=M/10;
                        l1=S%10;
                        l2=S/10;
                        WWS4();
                        buttfunc();
void TIME() interrupt 1
        TH0 = (65536 - 46080)/256; //重装初值
        UT++;
收藏收藏1 分享淘帖 顶 踩
ID:455206 发表于 2018-12-27 16:06 | 只看该作者
楼主是真的厉害
ID:570182 发表于 2019-6-23 18:26 | 只看该作者
请问您下这里i现在还有仿真软件的接线图吗
ID:569940 发表于 2019-6-24 19:40 | 只看该作者
好像我的不太行呀
