查看: 3876|回复: 0
Arduino数字信号检测
ID:350876 发表于 2018-6-13 10:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int in_1 = 2;  //定义引脚为D2
int in_2 = 4;  //定义引脚为D4
int LED_G = 12;
int LED_R = 13;
int beep = 8;
int beep_en = 1;
int IO_x = 0;
int T = 1500;  //Period of the input signal (microsecond)
unsigned long duration_H;  //定义duration变量为无符号长整数型变量
unsigned long duration_L;  //定义duration变量为无符号长整数型变量
boolean value_1;
boolean value_2;
void setup()
  //Serial.begin(9600);  //串口波特率为9600
  pinMode(in_1, INPUT); //设置引脚为输入模式
  pinMode(in_2, INPUT); //设置引脚为输入模式
  pinMode(LED_G,OUTPUT);
  pinMode(LED_R,OUTPUT);
  pinMode(beep,OUTPUT);
void loop()
  digitalWrite(LED_R,HIGH);
  digitalWrite(LED_G,LOW);
  digitalWrite(beep,LOW);
    //initiate
     value_1=digitalRead(in_1);//读取电压值
     value_2=digitalRead(in_2);//读取电压值
    if(value_1== HIGH)    //IO_1
      IO_x = 1;
      if(beep_en > 0)      //enable beep
        digitalWrite(LED_R,LOW);
        digitalWrite(LED_G,HIGH);
        digitalWrite(beep,HIGH);
        delay(500);
        beep_en = 0;
    else if(value_2==HIGH)
      IO_x= 0;
          duration_H = pulseIn(in_2, HIGH,T);
          if(duration_H <1)  break;
     else if (IO_x>0)          //function 1
    else                        //function 2 and start
      //does not work
