查看: 2987|回复: 0
灯带控制程序
ID:350956 发表于 2018-6-13 11:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* Function Name  : WS2812_WriteRGB
* Description    : ledμÆ′ø¿ØÖÆ3ìDò
* Input          :
* Output         : None
* Return         : None
void WS2812_WriteRGB(u16 Addr, u8 Num, u8 R8, u8 G8, u8 B8)
        u16 i = 0,itemp = 0;
   for (itemp=0;itemp<(Num);itemp++)
                u32 RGB24 = (R8<<8)+(G8<<16)+(B8<<0);
                 for(i=0;i<(24);i++)
                           if(((RGB24<<i)&0x800000))
                                        LED_BYTE_Buffer[Addr*24*Num+itemp*24+i] = TIMING_ONE;
                                        LED_BYTE_Buffer[Addr*24*Num+itemp*24+i] = TIMING_ZERO;
        DMA_SetCurrDataCounter(DMA1_Channel2, WS2812_Buffer_Size);         // »ñè¡μ±Ç°ê£óàêy¾Yá¿′óD¡load number of bytes to be transferred
        DMA_Cmd(DMA1_Channel2, ENABLE);                         //ê1Äü DMA ′«êäí¨μà enable DMA channel 6
        TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 3
        while(!DMA_GetFlagStatus(DMA1_FLAG_TC2)) ;         // 2éÑˉ DMA í¨μà 2 ′«êäêÇ·ñíê3éwait until transfer complete
        TIM_Cmd(TIM2, DISABLE);         // disable Timer 3
        DMA_Cmd(DMA1_Channel2, DISABLE);                         // disable DMA channel 6
        DMA_ClearFlag(DMA1_FLAG_TC2);
