查看: 2837|回复: 0
VB.NET与Q系列以太网通讯
ID:353596 发表于 2018-6-18 11:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Imports System.Net
Imports System.Runtime.InteropServices
Public Class Form1
    Dim Handle1 As Int32
    Dim EntLink1 As Boolean
    Dim ScanCount1 As Long
    Dim PLC As New EntQsPlc_Asc.PlcClient'EntQsPlc_ASC.DLL是Q系列以太网通讯组件
    Public Declare Function timeGetTime Lib "winmm.dll" () As UInt32
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.CenterToScreen()
        cmbReadMry.Items.Clear()
        cmbReadMry.Items.Add("X")
        cmbReadMry.Items.Add("Y")
        cmbReadMry.Items.Add("M")
        cmbReadMry.Items.Add("D")
        cmbReadMry.Items.Add("R")
        cmbReadMry.Items.Add("Z")
        cmbWriteMry.Items.Clear()
        cmbWriteMry.Items.Add("X")
        cmbWriteMry.Items.Add("Y")
        cmbWriteMry.Items.Add("M")
        cmbWriteMry.Items.Add("D")
        cmbWriteMry.Items.Add("R")
        cmbWriteMry.Items.Add("Z")
        cmbBitMry.Items.Clear()
        cmbBitMry.Items.Add("X")
        cmbBitMry.Items.Add("Y")
        cmbBitMry.Items.Add("M")
        cmbReadType.Items.Clear()
        cmbReadType.Items.Add("INT16")
        cmbReadType.Items.Add("UINT16")
        cmbReadType.Items.Add("DINT32")
        cmbReadType.Items.Add("HEX32")
        cmbReadType.Items.Add("REAL32")
        cmbReadType.Items.Add("BIN16")
        cmbWriteType.Items.Clear()
        cmbWriteType.Items.Add("INT16")
        cmbWriteType.Items.Add("UINT16")
        cmbWriteType.Items.Add("DINT32")
        cmbWriteType.Items.Add("HEX32")
        cmbWriteType.Items.Add("REAL32")
        cmbWriteType.Items.Add("BIN16")
        cmbReadMry.SelectedIndex = 3
        cmbWriteMry.SelectedIndex = 3
        cmbBitMry.SelectedIndex = 2
        cmbReadType.SelectedIndex = 0
        cmbWriteType.SelectedIndex = 0
        lstRead.Items.Clear()
        txtWrite.Text = ""
        cmbCmdType.SelectedIndex = 0
    End Sub
    Private Sub butLink_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butLink.Click
        Dim re As Short
        Dim restr As String = ""
        re = PLC.EntLink(Trim(txtLocalIP.Text), Val(txtLocalPort.Text), Trim(txtRemoteIP.Text), Val(txtRemotePort.Text), "DEMO", Handle1, 1000, CBool(cmbCmdType.SelectedIndex))
        txtReLink.Text = re.ToString
        If re = 0 Then
            EntLink1 = True
            MsgBox("PLC联接成功! ")
        Else
            EntLink1 = False
            MsgBox("PLC联接失败: " & restr)
        End If
    End Sub
    Private Sub butClose_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butClose.Click
        Dim re As Short
        If Not EntLink1 Then
            MsgBox("还未与PLC建立联接!")
            Exit Sub
        End If
        re = PLC.DeLink(Handle1)
        txtReClose.Text = re.ToString
    End Sub
    Private Sub butRead_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butRead.Click
        Dim re As Short
        Dim i As Short
        Dim RD() As Object
        ReDim RD(Val(txtReadCnt.Text - 1))
            ' Exit Sub
        End If
        Dim mry As EntQsPlc_Asc.PlcClient.PlcMemory = cmbReadMry.SelectedIndex + 1
        Dim typ As EntQsPlc_Asc.PlcClient.DataType = cmbReadType.SelectedIndex + 1
        re = PLC.CmdRead(Handle1, mry, typ, CInt(txtReadAdd.Text), CUShort(txtReadCnt.Text), RD)
        txtReRead.Text = re.ToString
        For i = 0 To UBound(RD) Step 1
            If Not IsNothing(RD(i)) Then lstRead.Items.Add(RD(i))
        Next i
        If re <> 0 Then
            Timer1.Enabled = False
            butScan.Text = "Cycle R/W"
        End If
    End Sub
    Private Sub butWrite_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butWrite.Click
        Dim re As Short
        Dim i As Short
        Dim temp() As String
        Dim WD() As Object
            Exit Sub
        End If
        ReDim WD(Val(txtWriteCnt.Text) - 1)
        temp = Split(txtWrite.Text, vbCrLf)
        For i = 0 To UBound(WD) Step 1
            If i > UBound(temp) Then
                WD(i) = 0
            Else
                WD(i) = Trim(temp(i))
            End If
        Next i
        Dim mry As EntQsPlc_Asc.PlcClient.PlcMemory = cmbWriteMry.SelectedIndex + 1
        Dim typ As EntQsPlc_Asc.PlcClient.DataType = cmbWriteType.SelectedIndex + 1
        re = PLC.CmdWrite(Handle1, mry, typ, CInt(txtWriteAdd.Text), CUShort(txtWriteCnt.Text), WD)
        txtReWrite.Text = re.ToString
        If re <> 0 Then
        End If
    End Sub
    Private Sub butScan_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butScan.Click
            Exit Sub
        End If
        Timer1.Enabled = Not Timer1.Enabled
        If Timer1.Enabled Then
            ScanCount1 = 0
            butScan.Text = "Stop R/W"
        Else
        End If
    End Sub
    Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        Dim tim As Integer = timeGetTime
            Exit Sub
        End If
        Call butRead_Click(Nothing, Nothing)
        Call butWrite_Click(Nothing, Nothing)
        If (Val(txtReRead.Text) < 0) Or (Val(txtReWrite.Text) < 0) Then
            Exit Sub
        Else
            ScanCount1 += 1
            txtScanCnt.Text = ScanCount1
            txtScanPrd.Text = (timeGetTime - tim) & "ms"
        End If
        Timer1.Enabled = True
    End Sub
    Private Sub butBitTest_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butBitTest.Click
            Exit Sub
        End If
        Dim rd As Boolean
        Dim re As Short
        Dim mry As EntQsPlc_Asc.PlcClient.PlcMemory = cmbBitMry.SelectedIndex + 1
        re = PLC.Bit_Test(Handle1, mry, CUShort(txtBitAdd.Text), rd)
        txtBitTest.Text = rd
        txtReBit.Text = re
    End Sub
    Private Sub butBitSet_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butBitSet.Click
            Exit Sub
        End If
        Dim re As Short
        re = PLC.Bit_Set(Handle1, cmbBitMry.SelectedIndex + 1, Val(txtBitAdd.Text))
        txtReBit.Text = re
    End Sub
    Private Sub butBitRst_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butBitRst.Click
            Exit Sub
        End If
        Dim re As Short
        re = PLC.Bit_Reset(Handle1, cmbBitMry.SelectedIndex + 1, Val(txtBitAdd.Text))
        txtReBit.Text = re
    End Sub
End Class
