查看: 1773|回复: 0
基于51的简易计算器
ID:355780 发表于 2018-6-21 10:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define  uchar unsigned char
#define  ulong  unsigned long
//uchar code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40};                        //共阴极
               //   0    1           2    3         4    5    6    7    8     9   熄灭  -
//uchar code loc[]={0xff,0xfe,0xfd,0xfb,0xf7};
//uchar code ero[]={0x79,0x50,0x5c};
uchar code num[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0x40};                        //共阳极
uchar code loc[]={~0x00,~0x10,~0x20,~0x40,~0x80,~0x08,~0x04,~0x02,~0x01};
uchar code ero[]={~0x79,~0x77,~0x3f};
ulong  n=0,n1=0,n2=0;           //赋初值
uchar flag=0;               //计算类型选择关键字
void delay(int t);
void display(int n);
void error();
main()
                uchar temp;
            //第一行检测
            P1=0xfe;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(10);
                        temp=P1;
                        temp=temp&0xfe;
                        if(temp!=0xfe)
                                temp=P1;
                                switch(temp)
                                        case 0xee:n1=0;n2=0;n=0;flag=0;break;                                //清零
                                        case 0xde:n1=10*n1+0;n=n1;break;                                                             //0
                                        case 0xbe: if(flag==1)n=n2+n1;                                        //=
                                                          if(flag==2)n=n2-n1;
                                                          if(flag==3)n=n2*n1;
                                                          if(flag==4)n=n2/n1;
                                                            n1=0;
                                                      break;
                                        case 0x7e:                                                            // +
                                             n2=n1;n1=0;
                                                     flag=1;break;
                                while(temp!=0xf0)
                                                temp=P1;
                                                temp=temp&0xf0;
        //扫描第二行
                P1=0xfd;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(10);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xed:n1=10*n1+1;n=n1;break;                                //4
                                        case 0xdd:n1=10*n1+2;n=n1;break;                        //5
                                        case 0xbd:n1=10*n1+3;n=n1;break;                                //6
                                        case 0x7d:                                      // -
                                                          n2=n1;n1=0;
                                                          flag=2;break;
                                while(temp!=0xf0)
                                temp=P1;
                                temp=temp&0xf0;
        //扫描第三行
          P1=0xfb;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(10);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xeb:n1=10*n1+4;n=n1;break;
                                        case 0xdb:n1=10*n1+5;n=n1;break;
                                        case 0xbb:n1=10*n1+6;n=n1;break;
                                        case 0x7b:                                                     // *
                                                      n2=n1;n1=0;
                                                  flag=3;break;
                                while(temp!=0xf0)
                                        temp=P1;
                                        temp=temp&0xf0;
        //扫描第四行
                P1=0xf7;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(10);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xe7:n1=10*n1+7;n=n1;break;                           //7
                                        case 0xd7:n1=10*n1+8;n=n1;break;                           //8
                                        case 0xb7:n1=10*n1+9;n=n1;break;                           //9
                                        case 0x77:                                    // /
                                                      n2=n1;n1=0;
                                                  flag=4;break;
                                while(temp!=0xf0)
                                        temp=P1;
                                        temp=temp&0xf0;
                display(n);
//延时函数
void delay(int t)
        int x,y;
        for(x=0;x<t;x++)
                for(y=0;y<t;y++);
//数码管显示
void display(int n)
                //溢出处理
                uchar g,s,b,q,a,c;
                int abs;
                if((n>999999)||(n<-99999))
                error();
                //正数
                if((n>=0)&&(n<=999999))
                                g=n%10;
                                s=n/10%10;
                                b=n/100%10;
                                q=n/1000%10;
                                a=n/10000%10;
                                c=n/100000%10;
                                P0=num[g];
                                delay(5);
                                P2=loc[4];
                                delay(2);
                                P2=loc[0];
                                delay(3);
                                if(n>=10)
                                        P0=num[s];
                                        P2=loc[3];
                                        delay(2);
                                        P2=loc[0];
                                        delay(3);
                                if(n>=100)
                                        P0=num[b];
                                        P2=loc[2];
                                        delay(2);
                                        P2=loc[0];
                                        delay(3);
                                if(n>=1000)
                                        P0=num[q];
                                        P2=loc[1];
                                        delay(2);
                                        P2=loc[0];
                                        delay(3);
                                        if(n>=10000)
                                        P0=num[a];
                                        P2=loc[5];
                                        delay(2);
                                        P2=loc[0];
                                        delay(3);
                                if(n>=100000)
                                        P0=num[c];
                                        P2=loc[6];
                                        delay(2);
                                        P2=loc[0];
                                        delay(3);
                //负数
                if((n<0)&&(n>=-999))
                        abs=-n;
                        g=abs%10;
                        s=abs/10%10;
                        b=abs/100%10;
                        q=abs/1000%10;
                        P0=num[g];
                        P2=loc[4];
                        delay(2);
                        P2=loc[0];
                        delay(2);
                        if((abs/10%10>0)||(abs/100%10>0))
                                        P0=num[s];
                                        P2=loc[3];;
                                        delay(2);
                                        P2=loc[0];
                                        delay(2);
                                if((abs/100%10>0))
                                                P0=num[b];
                                                P2=loc[2];
                                                delay(2);
                                                P2=loc[0];
                                                delay(2);
                                                if((abs/1000%10>0))
        P0=num[q];
        P2=loc[1];
        delay(2);
        P2=loc[0];
        delay(2);
        P0=num[11];
        P2=loc[1];
        delay(2);
        P2=loc[0];
        delay(2);
                                                P0=num[11];
                                                P2=loc[2];
                                                delay(2);
                                                P2=loc[0];
                                                delay(2);
                                        P0=num[11];
                                        P2=loc[3];
                                        delay(2);
                                        P2=loc[0];
                                        delay(2);
//溢出显示
void error()
                P2=loc[5];
                P0=ero[0];
                delay(2);
                P2=loc[0];
                delay(3);
                P2=loc[1];
                P0=ero[1];
                delay(2);
                P2=loc[0];
                delay(3);
                P2=loc[2];
                P0=ero[1];
                delay(2);
                P2=loc[0];
                delay(3);
                P2=loc[3];
                P0=ero[2];
                delay(2);
                P2=loc[0];
                delay(3);
                P2=loc[4];
                P0=ero[1];
                delay(2);
                P2=loc[0];
                delay(3);
