简单的串口数据发送,供大家参考!
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Windows.Forms;
- namespace 串口_数据发送
- public partial class Form1 : Form
- public Form1()
- InitializeComponent();
- private void Form1_Load(object sender, EventArgs e)
- // comboBox1.Items.Add("COM1");
- for (int i = 1; i < 16; i++)
- comboBox1.Items.Add("COM"+i.ToString());
- comboBox1.SelectedIndex = 1; //初始化COM口
- //串口发送的数据类型的最小单位是字节
- for (int i = 1; i < 20; i++)
- string str = Convert.ToString(i, 16);
- if (str.Length == 1)
- str = "0" + str;
- str = "0x" + str;
- comboBox2.Items.Add(str);
- private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
- private void button1_Click(object sender, EventArgs e)
- //serialPort1.PortName = comboBox1.Text;
- if (!serialPort1.IsOpen) //端口如果是关闭着的,请打开
- try
- serialPort1.PortName = comboBox1.Text;
- serialPort1.Open();
- button1.Text = "关闭窗口";
- catch
- MessageBox.Show("串口打开失败!");
- else
- try
- serialPort1.Close();
- button1.Text = "打开窗口";
- catch
- MessageBox.Show("串口关闭失败!");
- private void button2_Click(object sender, EventArgs e)
- //发送数据
- serialPort1.Write()
