查看: 10104|回复: 8
基于STM32F103RCT6的串口数据采集(4路ADC+4路数字量)源程序
ID:360398 发表于 2018-6-27 16:55 | 显示全部楼层 |阅读模式
4路ADC+4路数字量。4路模拟信号+4路数字信号
被测电路设计
被测电路设计
测量结果
测量结果
基于STM32F103RCT6的串口数据采集程序
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. #include "dma.h"
  8. #define  Channel_Number 4 // 通道数的宏定义
  9. #define KEY0  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)
  10. #define KEY1  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)
  11. #define KEY2  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2)
  12. #define KEY3  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3)
  13. #define KEY0_PRES 1
  14. #define KEY1_PRES        2
  15. #define KEY2_PRES        3
  16. #define KEY3_PRES 4
  17. u16  AD_Digital_Value[Channel_Number];                                        //AD采样值
  18. float AD_Analog_Value[Channel_Number];                                        //AD模拟电压值
  19. void KEY_Init(void)
  20. {
  21.         GPIO_InitTypeDef GPIO_InitStructure;
  22.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOE,ENABLE);
  23.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
  24.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  25.         GPIO_Init(GPIOE, &GPIO_InitStructure);
  26.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0;
  27.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  28.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  29. }
  30. u8 KEY_Scan1(u8 mode)
  31. {
  32.         static u8 key_up=1;
  33.         if(mode)key_up=1;
  34.         if(key_up&&(KEY0==0))
  35.         {
  36.                 delay_ms(10);
  37.                 key_up=0;
  38.                 if(KEY0==0)return KEY0_PRES;
  39. //                else if(KEY1==0)return KEY1_PRES;
  40. //                else if(KEY2==0)return KEY2_PRES;
  41. //                else if(KEY3==0)return KEY3_PRES;
  42.         }else if(KEY0==1)key_up=1;
  43.         return 0;
  44. }
  45. u8 KEY_Scan2(u8 mode)
  46. {
  47.         static u8 key_up=1;
  48.         if(mode)key_up=1;
  49.         if(key_up&&(KEY1==0))
  50.         {
  51.                 delay_ms(10);
  52.                 key_up=0;
  53.                 if(KEY1==0)return KEY1_PRES;
  54. //                else if(KEY1==0)return KEY1_PRES;
  55. //                else if(KEY2==0)return KEY2_PRES;
  56. //                else if(KEY3==0)return KEY3_PRES;
  57.         }else if(KEY1==1)key_up=1;
  58.         return 0;
  59. }
  60. u8 KEY_Scan3(u8 mode)
  61. {
  62.         static u8 key_up=1;
  63.         if(mode)key_up=1;
  64.         if(key_up&&(KEY2==0))
  65.         {
  66.                 delay_ms(10);
  67.                 key_up=0;
  68.                 if(KEY2==0)return KEY2_PRES;
  69.         }else if(KEY2==1)key_up=1;
  70.         return 0;
  71. }
  72. u8 KEY_Scan4(u8 mode)
  73. {
  74.         static u8 key_up=1;
  75.         if(mode)key_up=1;
  76.         if(key_up&&(KEY3==0))
  77.         {
  78.                 delay_ms(10);
  79.                 key_up=0;
  80.                 if(KEY3==0)return KEY3_PRES;
  81. //                else if(KEY1==0)return KEY1_PRES;
  82. //                else if(KEY2==0)return KEY2_PRES;
  83. //                else if(KEY3==0)return KEY3_PRES;
  84.         }else if(KEY3==1)key_up=1;
  85.         return 0;
  86. }
  87. int main(void)
  88. {
  89.                 u8 i;//定义一个变量
  90.                 char a1 = 0;
  91.                 char a2 = 0;
  92.                 char a3 = 0;
  93.                 char a4 = 0;
  94.                 KEY_Init();
  95.                 SystemInit();//延时初始化
  96.                 delay_init(72);             //延时初始化
  97.                 NVIC_Configuration();//中断初始化
  98.                  uart_init(9600);//串口初始化
  99.                  LED_Init();//led灯初始化
  100.                 LCD_Init();//lcd液晶显示屏初始化
  101.                 POINT_COLOR=RED;//设置字体为红色
  102.                 POINT_COLOR=BLUE;//设置字体为蓝色
  103.                 ADC1_Configuration();            //ADC初始化
  104.                 delay_ms(10);//延时
  105.                 DMA_Configuration(DMA1_Channel1,(u32)&ADC1->DR,(u32)AD_Digital_Value,Channel_Number );//DMA1通道1;外设为ADC1;
  106.                 DMA_Cmd(DMA1_Channel1, ENABLE);//启动DMA通道
  107.                 ADC_SoftwareStartConvCmd(ADC1, ENABLE);//软件启动AD转换
  108.         while (1)
  109.         {
  110.                 a1 = KEY_Scan1(1);
  111.                 a2 = KEY_Scan2(1);
  112.                 a3 = KEY_Scan3(1);
  113.                 a4 = KEY_Scan4(1);
  114.
  115.                 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束
  116.           while(DMA_GetFlagStatus(DMA1_FLAG_TC1)==RESET);//等待传输完成否则第一位数据容易丢失
  117.                 DMA_ClearFlag(DMA1_FLAG_TC1); //清除通道 1 传输完成标志
  118.     for( i=0;i<Channel_Number;i++)
  119.                         {
  120.                                 AD_Analog_Value[i]=(float)AD_Digital_Value[i]*(3.3/4096); //将读取到的值存入数组里面
  121.                         }
  122.                 printf("\r\n 模拟信号1:%d  模拟电压1:%f \r\n",AD_Digital_Value[0],AD_Analog_Value[0]);        //串口打印出来通道1的电压值以及测得的ad转化的值
  123.                 printf("\r\n 模拟信号2:%d  模拟电压2:%f \r\n",AD_Digital_Value[1],AD_Analog_Value[1]);        //串口打印出来通道2的电压值以及测得的ad转化的值
  124.                 printf("\r\n 模拟信号3:%d  模拟电压3:%f \r\n",AD_Digital_Value[2],AD_Analog_Value[2]);        //串口打印出来通道3的电压值以及测得的ad转化的值
  125.                 printf("\r\n 模拟信号4:%d  模拟电压4:%f \r\n",AD_Digital_Value[3],AD_Analog_Value[3]);        //串口打印出来通道4的电压值以及测得的ad转化的值
  126.                 if(a1 == 1)
  127.                 {
  128.                                 printf("\r\n 数字信号通道1为1\r\n");
  129.                 }
  130.                 if(a1 == 0)
  131.                 {
  132.                                 printf("\r\n 数字信号通道1为0\r\n");
  133.                 }
  134.                 if(a2 == 1)
  135.                 {
  136.                                 printf("\r\n 数字信号通道2为1\r\n");
  137.                 }
  138.                 if(a2 == 0)
  139.                 {
  140.                                 printf("\r\n 数字信号通道2为0\r\n");
  141.                 }
  142.                 if(a3 == 1)
  143.                 {
  144.                                 printf("\r\n 数字信号通道3为1\r\n");
  145.                 }
  146.                 if(a3 == 0)
  147.                 {
  148.                                 printf("\r\n 数字信号通道3为0\r\n");
  149.                 }
  150.                 if(a4 == 1)
  151.                 {
  152.                                 printf("\r\n 数字信号通道4为1\r\n");
  153.                 }
  154.                 if(a4 == 0)
  155.                 {
  156.                                 printf("\r\n 数字信号通道4为0\r\n");
  157.                 }
  158. //                LED0=!LED0;
  159.                 delay_ms(100);
  160.
  161.         }
  162. }
4路ADC 4路数字量 (1).7z (735.19 KB, 下载次数: 226)
ID:390650 发表于 2018-9-17 15:18 | 显示全部楼层
有硬件电路图吗?
ID:465802 发表于 2019-1-10 14:21 | 显示全部楼层
只能先看看。。黑币不够。
ID:465802 发表于 2019-1-10 14:22 | 显示全部楼层
s360221867 发表于 2018-9-17 15:18
有硬件电路图吗?
这个外部电路很简单的。直接把电压接到单片机的ADC接口上去采集就好。
ID:66915 发表于 2019-1-15 16:37 | 显示全部楼层
貌似不是很懂我,还需要继续学习学习
ID:696937 发表于 2020-2-23 14:14 | 显示全部楼层
正需要呀
ID:702600 发表于 2020-3-6 10:00 | 显示全部楼层
多谢楼主分享,学习了。
ID:501920 发表于 2020-11-14 19:32 | 显示全部楼层
你这是RBT6呀
ID:278170 发表于 2020-11-25 10:47 | 显示全部楼层
正需要呀,多谢楼主分享,学习了。
