查看: 2936|回复: 1
屏厂客户LCD9325参考STM32源代码
屏厂客户LCD9325参考代码
  1. #include <stm32f10x_lib.h>
  2. #include "stdinc.h"
  3. #include "sys.h"
  4. #include "led.h"
  5. #include "key.h"
  6. #include "wdg.h"
  7. #include "TFT.h"
  8. #include "touch.h"
  9. #include "picture.h"
  10. #include "ui.h"
  11. #include "config.h"
  12. #include "sysserv.h"
  13. #include "TFT_Init.h"
  14. #include "ParamMgr.h"
  15. #include "DMX.h"
  16. #include "PCBATest.h"
  17.
  18. /**********************************************************************/
  19. //        DSP-A
  20. //        2016.9.28
  21. //
  22. /**********************************************************************/
  23. INT8U               GucMsg;
  24. INT8U                   GucTmr1Cnt = 0;
  25. BOOL                                GbTmr1MSSyncSig = FALSE;
  26. extern  INT8U       GucDMXCableValid;
  27. extern  BOOL        GbMaterSend;
  28. //+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
  29. void SysTimerInit (void);
  30. void sysSuspendForSync (void);
  31. void Timerx_Init (void);
  32. void sysInit (void);
  33. //+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
  34. #define T_10MS      0
  35. #define T_20MS      1
  36. #define T_200MS     2
  37. #define T_500MS     3
  38. //+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
  39. int main(void)
  40. {
  41.     INT8U            ucParam;
  42.     INT8U            ucKey;
  43.     static INT8U     ucDlyS = 0;
  44.
  45.     sysInit();
  46.
  47.     SetTimer(T_10MS, 10);
  48.     SetTimer(T_20MS, 20);
  49.     SetTimer(T_200MS, 200);
  50.     SetTimer(T_500MS, 1000);
  51.
  52.     GetLockCode();
  53.
  54.         while(1)
  55.         {
  56.                 sysSuspendForSync();
  57.
  58.         if (GbTmr1MSSyncSig)
  59.         {
  60.             GbTmr1MSSyncSig = FALSE;
  61.
  62.             SoftTimer1mSec();
  63.
  64.             AudioDetect();
  65.
  66.             CodingSwitch();
  67.         }
  68.
  69.
  70.         GucMsg = GetMessage(&ucParam);
  71.         switch (GucMsg)
  72.         {
  73.         case MSG_TIMEOUT:
  74.             switch (ucParam)
  75.             {
  76.             case T_10MS:
  77.                 if (GbMaterSend) // (PARAM(TEST_MASTER))        //        if I'm configed as master
  78.                 {
  79.                     RS485_AS_OUTPUT();        //  Set DMX as output to output data
  80.                     UART_RXD_DISABLE();
  81.                     if(ucDlyS > 2)
  82.                     {
  83.                         ucDlyS = 0;
  84.                         DMXSend();
  85.                     }
  86.                     ucDlyS++;
  87.                 }
  88.                 else
  89.                 {
  90.                     UART_RXD_ENABLE();
  91.                     RS485_AS_INPUT();        //        Set DMX as input, release RS485 bus
  92.                 }
  93.
  94.                 ParamUpdateRoutine();
  95.                 break;
  96.
  97.             case T_20MS:
  98.
  99.                 ucKey = KeyScan();
  100.                 //KeyHandle(ucKey);
  101.
  102.                 uiRoutine(ucKey);
  103.
  104.                 GbDMXUpdate = TRUE;
  105.                 break;
  106.
  107.             case T_200MS:
  108.                  //  Deal DMX cable active status
  109.                 if (GucDMXCableValid != 0)              //  DMX Cable is inserted and valid.
  110.                 {
  111.                     GucDMXCableValid--;
  112.                 }
  113.
  114.                 LedRoutine();
  115.
  116.                 TestDataRxRoutine();
  117.                 TestDataTxRoutine();
  118.                 break;
  119.
  120.             case T_500MS:
  121.                 ParamResetRoutine();
  122.
  123.
  124.                 PCBtestRoutine();
  125.                 break;
  126.
  127.             default:
  128.                 break;
  129.             }
  130.             break;
  131.
  132.         default:
  133.             break;
  134.         }
  135.
  136.         DMXSendRoutine();
  137.         }
  138. }
  139. void sysInit (void)
  140. {
  141.     Stm32_Clock_Init(6); //系统时钟设置
  142.     SysTimerInit();
  143.
  144.     Timerx_Init();
  145.
  146.     SoftTimerInit();
  147.     MsgQueueInit();
  148.
  149.         LCD_Init();                        // 初始化液晶
  150.     Touch_Init();
  151.
  152.         uiInit();
  153.
  154.     dmxInit();
  155.
  156.     uartInit();
  157.     PCB_TestInit();
  158.         //IWDG_Init(1,0xfff);
  159. }
  160. void sysSuspendForSync (void)
  161. {
  162.     IWDG_Feed();
  163.     while (GucTmr1Cnt < 8)
  164.     {
  165.         IWDG_Feed();        //        feed watch dog
  166.         if (GucTmr1Cnt >= 6)
  167.             continue;
  168.
  169.         //stpPosFeedback();
  170.     }
  171.     ENTER_CRITICAL();
  172.     GucTmr1Cnt -= 8;
  173.     EXIT_CRITICAL();
  174.
  175.
  176.     //lcdBufUpdate();
  177. }
  178. void SysTimerInit (void)
  179. {
  180.     SysTick->CTRL |= (1<<1)|(1<<2);
  181.     SysTick->LOAD = 749;           //  31.25us tick, 749 = (31.25 * 24MHz) - 1
  182.     SysTick->CTRL |= (1<<0);
  183. }
  184. void Timerx_Init (void)      //  1MS sync signal, avoid 31.25 tick loss
  185. {
  186.     RCC->APB1ENR |= (1<<4);
  187.     TIM6->ARR = 24000-1;          //1000us
  188.     TIM6->PSC = 0;
  189.     TIM6->CR1 |= (1<<0);
  190. }
  191. INT16S                   GiSlvSyncTick = 0;
  192. INT16S                   GiSlvSyncDelta = 0;
  193. INT16U                   GuiUpdateSysCnt = 0;
  194. #pragma optimize = speed
  195. void SysTick_Handler (void)  // 31.25us
  196. {
  197.     static INT8U    ch = 0;
  198.
  199.
  200. SYS_TMR:
  201.     if (GiSlvSyncDelta < -5)
  202.     {
  203.         GiSlvSyncDelta++;
  204.         return;
  205.     }
  206.
  207.         GucTmr1Cnt++;
  208.
  209.         GiSlvSyncTick++;
  210.
  211. ……………………
  212. …………限于本文篇幅 余下代码请从51黑下载附件…………
屏厂客户LCD9325参考代码.rar (624.14 KB, 下载次数: 10)
收藏收藏2 分享淘帖 顶顶1 踩踩
ID:222956 发表于 2019-3-30 15:10 | 只看该作者
谢谢,楼主
