查看: 1709|回复: 0
没有完成长按
ID:358998 发表于 2018-7-4 14:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "BS87D20A-3.h"
#define com1    _pc1
#define com2        _pc0
#define com3        _pc2
#define com4        _pc3
#define key1    _pd2
#define key2        _pd3
#define key3        _pa1
#define key4    _pa4
#define key_state_0        0   //按键的初始状态
#define key_state_1        1   //按键按下的状态
#define key_state_2        2   //按键释放的状态
volatile bit Flag_T5ms;
volatile bit Flag_T10ms;
volatile bit Flag_T1s;
const unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char strtab[3];//缓冲区
unsigned char key_number=0;
//unsigned char sec=0,min=0,hour=0;
unsigned char temp;
unsigned long s;  //秒级
unsigned long ms10;//毫秒
unsigned long ms5;
unsigned char n;
unsigned char read_key(void)
    static char key_state=0 ;     //按键的状态
    unsigned char key_press;       //按键是否被按下
        unsigned char key_return = 0;  //按键返回值
    key_press = key4;         // 读按键I/O电?
    switch (key_state)
        case key_state_0:                 // 按键初始态
                if (!key_press)
                                if(Flag_T10ms)
                                        Flag_T10ms=0;
                                key_return = 0;
                                key_state = key_state_1;// 键被按下,状态转换到键确认态
                else key_state = key_state_0;
                        break;
        case key_state_1:                   // 按键确认态
            if (!key_press)
                    if(Flag_T10ms)
                            Flag_T10ms=0;
                key_return = 1;         // 按键仍按下,按键确认输出为“1”
                key_state = key_state_2;// 状态转换到键释放态
                                key_state = key_state_0; // 按键已抬起,转换到按键初始态
                                key_return = 0;
            break;
        case key_state_2:
            if (key_press)
                            key_state = key_state_0;//按键已释放,转换到按键初始态
                            key_return = 0;
            break;
return key_return;                //返回按键值
void displaypro()
        strtab[0]=tab[sec%10];
        strtab[1]=tab[sec/10];
        strtab[2]=tab[min%10];
        strtab[3]=tab[min/10];
void display_drive()
        com1=1;com2=1;com3=1;com4=1;
                    switch(temp)
                        case 0:com4=0;
                         _pb=strtab[temp]; break;
                        case 1:com3=0;
                        case 2:com2=0;
                        case 3:com1=0;
                        default:break;
                temp++;
                if(temp==4)
                        temp=0;
void init()
    _ctm0c0=0x20;  // fh/16   2us
        _ctm0c1=0xc1; // 定时/计数器模式 比较器a
        _ctm0al=0xf4; // 1ms
    _ctm0ah=0x01;
        _pbc=0; //输出
        _pcc0=0;
        _pcc1=0;
        _pcc2=0;
        _pcc3=0;
        _pac1=1;
        _pac4=1;
        _pdc2=1;
        _pdc3=1;
        _pdpu3=1;
        _pdpu2=1;
        _papu1=1;
        _papu4=1;
        s=1000;
        ms10=10;
        ms5=5;
        temp=0;
        n=0;
        _mfe=1; //开多功能中断
    _ctm0ae=1; //CTM a中断使能
        _emi=1;        //开总中断
        _ct0on=1; //开定时器
                init();
                        if(Flag_T5ms)
                                Flag_T5ms=0;
                        if(Flag_T1s)
                                Flag_T1s=0;
                                displaypro();
                        if(Flag_T10ms)  //10MS进入一次
                                read_key();
                                key_number=read_key();//调用按键扫描函数,取得按键值,5MS调用一次
                        if(key_number==1)
                                n++;
                                _pb=tab[n];
                                Flag_T10ms=0;
                        GCC_CLRWDT();
                        com1=1;com2=1;com3=0;com4=0;
        void __attribute__((interrupt(0x14))) ISR_CTMO(void)
                _ctm0af=0;
                s--;
                ms5--;
                ms10--;
                  if(! ms5)
                        ms5=5;//5MS 视觉暂留
                        Flag_T5ms=1;
                if(!ms10)
                        ms10=10;
                        Flag_T10ms=1;
                if(! s)
                        Flag_T1s=1;
                        s=1000;//1s电子钟计数
                        sec++;
                if(sec==60)
               sec=0;
               min++;
               if(min==60)
                min=0;
                 hour++;
                 if(hour==24)
                  hour=0;
