查看: 4199|回复: 1
基于stm32f103c8板子的小车的电机驱动源码
ID:366692 发表于 2018-7-7 10:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是基于stm32f103c8板子的小车的电机驱动的keil工程源代码,这里是直流电机,由B6,B7,B8,B9四个管口输出PWM波来控制,前两个管口与B电机相关,后两个与A电机相关,两个口的PWM波占空比不同,产生压差,使电机转动
  1. #include "PWM.h"
  2. #include "stm32f10x.h"
  3. void TIM4_Init(void)
  4. {
  5.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  6.         GPIO_InitTypeDef GPIO_InitStructure;
  7.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  8.
  9.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);
  10.         //GPIO_InitTypeDef GPIO_InitStructure;
  11. //  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
  12. //  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13. //  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  14. //  GPIO_Init(GPIOB, &GPIO_InitStructure);
  15. //        GPIO_SetBits(GPIOB , GPIO_Pin_6);
  16. //        GPIO_SetBits(GPIOB , GPIO_Pin_7);
  17. //        GPIO_SetBits(GPIOB , GPIO_Pin_8);
  18. //        GPIO_SetBits(GPIOB , GPIO_Pin_9);
  19.
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//对应BIN2
  21.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  22.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  23.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  24.
  25.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;//对应BIN1
  26.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  28.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  29.
  30.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;//对应AIN2
  31.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  33.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  34.
  35.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//对应AIN1
  36.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  37.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  38.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  39.
  40.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4 , ENABLE);
  41.         //TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  42.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  43.         TIM_TimeBaseStructure.TIM_Period = 5000 ;
  44.   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;//TIM_CKD_DIV1;
  45.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  46.   TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  47.         //TIM_OCInitTypeDef  TIM_OCInitStructure;
  48.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  49.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  50.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  51.   TIM_OCInitStructure.TIM_Pulse =  2500;
  52.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  53.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  54.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  55.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  56.   TIM_OC1Init(TIM4 , &TIM_OCInitStructure);
  57.   TIM_OC1PreloadConfig(TIM4 , TIM_OCPreload_Enable);
  58.   TIM_ARRPreloadConfig(TIM4 , ENABLE);
  59.         TIM_CtrlPWMOutputs(TIM4 , ENABLE);
  60.         TIM_Cmd(TIM4 , ENABLE);
  61.
  62.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  63.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  64.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  65.   TIM_OCInitStructure.TIM_Pulse =  0;
  66.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  67.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  68.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  69.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  70.   TIM_OC2Init(TIM4 , &TIM_OCInitStructure);
  71.   TIM_OC2PreloadConfig(TIM4 , TIM_OCPreload_Enable);
  72.   TIM_ARRPreloadConfig(TIM4 , ENABLE);
  73.         TIM_CtrlPWMOutputs(TIM4 , ENABLE);
  74.         TIM_Cmd(TIM4 , ENABLE);
  75.
  76.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  77.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  78.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  79.   TIM_OCInitStructure.TIM_Pulse =  2500;
  80.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  81.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  82.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  83.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  84.   TIM_OC3Init(TIM4 , &TIM_OCInitStructure);
  85.   TIM_OC3PreloadConfig(TIM4 , TIM_OCPreload_Enable);
  86.   TIM_ARRPreloadConfig(TIM4 , ENABLE);
  87.         TIM_CtrlPWMOutputs(TIM4 , ENABLE);
  88.         TIM_Cmd(TIM4 , ENABLE);
  89.
  90.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  91.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  92.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  93.   TIM_OCInitStructure.TIM_Pulse =  0;
  94.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  95.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  96.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  97.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  98.   TIM_OC4Init(TIM4 , &TIM_OCInitStructure);
  99.   TIM_OC4PreloadConfig(TIM4 , TIM_OCPreload_Enable);
  100.   TIM_ARRPreloadConfig(TIM4 , ENABLE);
  101.         TIM_CtrlPWMOutputs(TIM4 , ENABLE);
  102.         TIM_Cmd(TIM4 , ENABLE);
  103.         //TIM1->CCR1 = 200;
  104.
  105. }
驱动电机.rar (390.61 KB, 下载次数: 36)
ID:394828 发表于 2018-9-8 10:24 | 只看该作者
很不错
