查看: 3099|回复: 2
基于51单片机的噪声计设计
#include <reg52.h>
#include "LCD1602.h"
unsigned char welcome[]={"welcome!"};
unsigned char Show0[6]={"Noise:"};
unsigned char Show1[5]={"dB"};
/*unsigned int code Countnum[60]={ 11,  13,  15,  17,  19,  22,  24,  27,  31,  34,          //T0计数值
                            39,  44,  49,  55,  62,  69,  78,  87,  98,  110,
                            123, 138, 155, 174, 195, 219, 246, 276, 309, 347,
                            390, 438, 491, 550, 618, 693, 778, 873, 979, 1099,
                            1233,1383,1552,1742,1954,2193,2460,2760,3097,3475,
                            3899,4375,4909,5508,6180,6934,7780,8729,9794,10989,};*/
unsigned long code Countnum[100]={10,11,12,13,15,17,19,22,25,28,
        31,35,39,43,48,54,60,67,75,84,
        94,105,117,131,146,163,182,204,228,255,
        286,320,359,402,451,506,567,636,713,799,
        896,1005,1127,1264,1418,1590,1783,2000,2244,2517,
        2824,3168,3556,3989,4475,5020,5632,6319,7089,7953,
        8923,10011,11232,12602,14139,15863,17798,19969,22405,25138,
        28204,31644,35504,39835,44694,50146,56263,63127,70828,79469,
        89164,100042,112247,125941,141305,158544,177886,199588,223937,251257,
        281910,316303,354891,398187,446765,501270,562424,631039,708025,794404,};
unsigned char code dB[100][3]={"031","032","033","034","035","036","037","038","039","040",                //T0计数值对应 dB
                              "041","042","043","044","045","046","047","048","049","050",
                              "051","052","053","054","055","056","057","058","059","060",
                              "061","062","063","064","065","066","067","068","069","070",
                              "071","072","073","074","075","076","077","078","079","080",
                              "081","082","083","084","085","086","087","088","089","090",
                                                          "091","092","093","094","095","096","097","098","099","100",
                                                          "101","102","103","104","105","106","107","108","109","110",
                                                          "111","112","113","114","115","116","117","118","119","120",
                                                          "121","122","123","124","125","126","127","128","129","130",
sbit beep=P2^2;
sbit key_1=P2^1;
sbit key_2=P2^0;
//////////////////////////////////////////////////////全局变量/////////////////////////////////////////////////////
unsigned long count,c;
uchar t,z;
uchar shu,ys;
//////////////////////////////////////////////////////函数声明////////////////////////////////////////////////////
    延时子程序
        延时时间(xms*1)ms
void delayms(uint xms)                   //延时xms
        uint x,y;
        for(x=xms;x>0;x--)
                for(y=90;y>0;y--);
void key()
        if (key_1==0)
                delayms(10);
                if (key_1==0)
                        while(key_1==0);
                        if (shu<99) shu++;
        if (key_2==0)
                delayms(10);
                if (key_2==0)
                        while(key_2==0);
                        if (shu>0) shu--;
void alarm()
        ys++;
        if (ys>20)
                ys=0;
                beep=!beep;
//////////////////////////////////////////主函数///////////////////////////////////////////////////////////
void main(void)
        uint m,n;
    uint i;
    delayms(1000);
        TMOD=0X15;                   //T0外部计数 工作方式1    T1定时方式1
    EA=0;                                 //开总中断
    ET1=0;                                 //关闭T1
    TH0=0;
    TL0=0;
    TH1=(65536-50000)/256;           //裝初值
    TL1=(65536-50000)%256;           //裝初值
    init_1602();
    WRITE_LCD1602_COM(0x80+3);        //        显示地址
          for(i=0; i<6; i++)
                WRITE_LCD1602_DAT(Show0[i]);
        delayms(5);
    WRITE_LCD1602_COM(0x80+12);                   //        显示地址
    for(i=0;i<2;i++)
                WRITE_LCD1602_DAT(Show1[i]);
        delayms(5);
    WRITE_LCD1602_COM(0xc0+3);                   //        显示地址
        WRITE_LCD1602_byte("Limit:");
    WRITE_LCD1602_COM(0xc0+12);                   //        显示地址
    for(i=0;i<2;i++)
        delayms(5);
    EA=1;
    ET1=1;                        //开T1
    TR1=1;                        //T1开始定时
    TR0=1;                        //T0开始计数
                        key();
            WRITE_LCD1602_COM(0xc0+9);
                          WRITE_LCD1602_DAT(0x30+(shu+31)/100%10);
                          WRITE_LCD1602_DAT(0x30+(shu+31)/10%10);
                          WRITE_LCD1602_DAT(0x30+(shu+31)%10);
            i=0;
            if(count==0)
            continue;
            while(count>Countnum[i])
                i++;
            m=i;
                        i=0;
            WRITE_LCD1602_COM(0x80+9);
            for(n=0; n<3; n++)
                WRITE_LCD1602_DAT(dB[m][n]);
                delayms(5);
                        if(m>=shu)
                                alarm();
                        }else
                                beep=1;
void Timer0() interrupt 1
        z++;
void Timer1() interrupt 3
    TR1=0;          //关闭T1定时
    t++;
        if(t==20)           //定时1s时间到
            t=0;
            TR0=0;                //T0停止计数
            c=z*65535+(TH0*256+TL0);                // 将计数值读取
            TH0=0;                                                //清空计数值
            TL0=0;                                           //清空计数值
            TR0=1;                                                   //T0开始计数
                        count=c;
                        c=0;
                        z=0;
    TR1=1;                //T1开始定时
ID:1 发表于 2018-7-8 01:33 | 只看该作者
本帖需要补全头文件后才可获得积分
ID:513774 发表于 2019-4-16 16:45 | 只看该作者
楼主你好
