查看: 2651|回复: 1
51数码八音盒
ID:352889 发表于 2018-7-7 15:29 | 显示全部楼层 |阅读模式
#include "reg52.h"                         //此文件中定义了单片机的一些特殊功能寄存器
#include "SoundPlay.h"
#include"music.h"
typedef unsigned int u16;          //对数据类型进行声明定义
typedef unsigned char u8;
void Delay1ms(unsigned int count)
        unsigned int i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
        InitialSound();
                Play(Music_Girl,0,3,360);
                Delay1ms(500);
                Play(Music_Same,0,3,360);
                Delay1ms(500);
                Play(Music_Two,0,3,360);
                Delay1ms(500);
#ifndef __SOUNDPLAY_H_REVISION_FIRST__
#define __SOUNDPLAY_H_REVISION_FIRST__
#include"music.h"
#define SYSTEM_OSC                 12000000        //定义晶振频率12000000HZ
#define SOUND_SPACE         4/5                 //定义普通音符演奏的长度分率,//每4分音符间隔
sbit    BeepIO    =           P1^5;                //定义输出管脚
unsigned char value=0;
unsigned int  code FreTab[12]  = { 262,277,294,311,330,349,369,392,415,440,466,494 }; //原始频率表
unsigned char code SignTab[7]  = { 0,2,4,5,7,9,11 };        //1~7在频率表中的位置
unsigned char code LengthTab[7]= { 1,2,4,8,16,32,64 };
unsigned char Sound_Temp_TH0,Sound_Temp_TL0;        //音符定时器初值暂存
unsigned char Sound_Temp_TH1,Sound_Temp_TL1;        //音长定时器初值暂存
void InitialSound(void)
        BeepIO = 0;
        Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256;        // 计算TL1应装入的初值         (10ms的初装值)
        Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256;        // 计算TH1应装入的初值
        TH1 = Sound_Temp_TH1;
        TL1 = Sound_Temp_TL1;
        TMOD  |= 0x11;
        ET0    = 1;
        ET1           = 0;
        TR0           = 0;
        TR1    = 0;
        EA     = 1;
void BeepTimer0(void) interrupt 1        //音符发生中断
        static unsigned char i;
        BeepIO = !BeepIO;
        TH0    = Sound_Temp_TH0;
        TL0    = Sound_Temp_TL0;
        i++;
        if(i==100)
                i=0;
                value++;
                if(value==5)value=0;
void Play(unsigned char *Sound,unsigned char Signature,unsigned Octachord,unsigned int Speed)
        unsigned int NewFreTab[12];                //新的频率表
        unsigned char i,j;
        unsigned int Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
        unsigned char Tone,Length,SL,SH,SM,SLen,XG,FD;
        for(i=0;i<12;i++)                                 // 根据调号及升降八度来生成新的频率表
                j = i + Signature;
                if(j > 11)
                        j = j-12;
                        NewFreTab[i] = FreTab[j]*2;
                        NewFreTab[i] = FreTab[j];
                if(Octachord == 1)
                        NewFreTab[i]>>=2;
                else if(Octachord == 3)
                        NewFreTab[i]<<=2;
        SoundLength = 0;
        while(Sound[SoundLength] != 0x00)        //计算歌曲长度
                SoundLength+=2;
        Point = 0;
        Tone   = Sound[Point];
        Length = Sound[Point+1];                         // 读出第一个音符和它时时值
        LDiv0 = 12000/Speed;                                // 算出1分音符的长度(几个10ms)
        LDiv4 = LDiv0/4;                                         // 算出4分音符的长度
        LDiv4 = LDiv4-LDiv4*SOUND_SPACE;         // 普通音最长间隔标准
        TR0          = 0;
        TR1   = 1;
        while(Point < SoundLength)
                SL=Tone%10;        //计算出音符
                SM=Tone/10%10;        //计算出高低音
                SH=Tone/100;        //计算出是否升半
                CurrentFre = NewFreTab[SignTab[SL-1]+SH];         //查出对应音符的频率
                if(SL!=0)
                        if (SM==1) CurrentFre >>= 2;                 //低音
                        if (SM==3) CurrentFre <<= 2;                 //高音
                        Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//计算计数器初值
                        Sound_Temp_TH0 = Temp_T/256;
                        Sound_Temp_TL0 = Temp_T%256;
                        TL0 = Sound_Temp_TL0 + 12; //加12是对中断延时的补偿
                SLen=LengthTab[Length%10];         //算出是几分音符
                XG=Length/10%10;                         //算出音符类型(0普通1连音2顿音)
                FD=Length/100;
                LDiv=LDiv0/SLen;                         //算出连音音符演奏的长度(多少个10ms)
                if (FD==1)
                        LDiv=LDiv+LDiv/2;
                if(XG!=1)
                        if(XG==0)                                 //算出普通音符的演奏长度
                                if (SLen<=4)
                                        LDiv1=LDiv-LDiv4;
                                        LDiv1=LDiv*SOUND_SPACE;
                                LDiv1=LDiv/2;                 //算出顿音的演奏长度
                        LDiv1=LDiv;
                if(SL==0) LDiv1=0;
                        LDiv2=LDiv-LDiv1;                 //算出不发音的长度
                  if (SL!=0)
                        TR0=1;
                        for(i=LDiv1;i>0;i--)         //发规定长度的音
                                while(TF1==0);
                                TF1=0;
                if(LDiv2!=0)
                        TR0=0; BeepIO=0;
                        for(i=LDiv2;i>0;i--)         //音符间的间隔
                                while(TF1==0);
                                TF1=0;
                Point+=2;
                Tone=Sound[Point];
                Length=Sound[Point+1];
        BeepIO = 0;
#endif
数码八音盒.docx
16.44 KB, 下载次数: 8, 下载积分: 黑币 -5
ID:560798 发表于 2019-6-12 13:02 | 显示全部楼层
谢谢分享啊
