查看: 4440|回复: 2
RTC(rx8010sj)的读写相关代码,利用NXF8563的代码进行修改的。
ID:368032 发表于 2018-7-9 16:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  NXF8563初始化
void NXF8563_init()
        sda=1;
        delayus();
        scl=1;
        delayus();
        _write_add(0x10,0x00);
        _write_add(0x11,0x32);
        _write_add(0x12,0x10);
        _write_add(0x13,0x10);           //周四
        _write_add(0x14,0x05);
        _write_add(0x15,0x07);
        _write_add(0x16,0x18);
         开始信号
void start()
        sda=1;
        delayus();
                scl=1;
        delayus();
        sda=0;
        delayus();
        scl=0;
        delayus();
        停止
void stop()
        sda=0;
        delayus();
        scl=1;
        delayus();
        sda=1;
        delayus();
        应答
void respons()
        unchar i;
        scl=1;
        delayus();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delayus();
           写一个字节子函数
void write_byte(unchar date)
        unchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delayus();
                sda=CY;
                delayus();
                scl=1;
                delayus();
        scl=0;
        delayus();
        sda=1;
        delayus();
         读一个字节函数
unchar read_byte()
        unchar i,k;
        scl=0;
        delayus();
        sda=1;
        delayus();
        for(i=0;i<8;i++)
                scl=1;
                delayus();
                k=(k<<1)|sda;
                scl=0;
                delayus();
        return k;
         往一个单元里写内容函数
void _write_add(unchar address,unchar date)
        start();
        write_byte(0x64);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
                读一个单元的内容
unchar read_add(unchar address)
        unchar date;
        start();
        write_byte(0x64);
        respons();
        respons();
        start();
        write_byte(0x65);
        respons();
        date=read_byte();
        stop();
        return date;
           向nxf8563写入时钟数据
void Write8563(void)
        unchar i,tmp;
        for(i=0;i<8;i++)
            {                  //BCD处理
                tmp=time_buf1[i]/10;
                time_buf[i]=time_buf1[i]%10;
                time_buf[i]=time_buf[i]+tmp*16;
//        write_add(0x00,0x00);                            //关闭写保护
//        write_add(0x01,0x00);                                //暂停
        _write_add(0x10,time_buf[7]);                //秒
        _write_add(0x11,time_buf[6]);                //分
        _write_add(0x12,time_buf[5]);                //时
        _write_add(0x13,time_buf[4]);                //周
        _write_add(0x14,time_buf[3]);                //日
        _write_add(0x15,time_buf[2]);                //月
        _write_add(0x16,time_buf[1]);                //年
//        write_add(0x00,0x00);                        //打开写保护
   读出时钟数据
void read8563()
        time_buf[7]=read_add(0x16);                //秒
        time_buf[6]=read_add(0x15);                //分
        time_buf[5]=read_add(0x14);                //时
        time_buf[4]=read_add(0x13);                //周
        time_buf[3]=read_add(0x12);                //日
        time_buf[2]=read_add(0x11);                //月
        time_buf[1]=read_add(0x10);                //年
        //time_buf1[7]=time_buf[1]%16+(time_buf[1]/16)*10;
        //time_buf1[6]=(time_buf[2]&0x1f)%16+((time_buf[2]&0x1f)/16)*10;
        //time_buf1[5]=(time_buf[3]&0x3f)%16+((time_buf[3]&0x3f)/16)*10;
        //time_buf1[3]=(time_buf[4]&0x3f)%16+((time_buf[4]&0x3f)/16)*10;
        //time_buf1[2]=(time_buf[5]&0x7f)%16+((time_buf[5]&0x7f)/16)*10;
        //time_buf1[1]=(time_buf[6]&0x7f)%16+((time_buf[6]&0x7f)/16)*10;
        //time_buf1[7]=(time_buf[7]&0x07)%16+((time_buf[7]&0x07)/16)*10;
ID:368032 发表于 2018-7-9 16:14 | 只看该作者
本代码刚测试通过
ID:399111 发表于 2020-6-13 14:23 | 只看该作者
你这不能用啊,,能把全部的上传看下吗,我测试了,显示55
