查看: 1405|回复: 0
1602液晶动态显示
ID:350005 发表于 2018-7-10 22:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
#include<intrins.h>
sbit RS = P2^4;   //定义端口
sbit RW = P2^5;
sbit EN = P2^6;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
uS延时函数,含有输入参数 unsigned char t,无返回值
unsigned char 是定义无符号字符变量,其值的范围是
0~255 这里使用晶振12M,精确延时请使用汇编,大致延时
长度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延时函数,含有输入参数 unsigned char t,无返回值
void DelayMs(unsigned char t)
while(t--)
     //大致延时1mS
     DelayUs2x(245);
         DelayUs2x(245);
              判忙函数
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
              写入命令函数
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙则等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
              写入数据函数
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
                清屏函数
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
              写入字符串函数
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);
         LCD_Write_Com(0xC0 + x);
while (*s)
LCD_Write_Data( *s);
s ++;
              写入字符函数
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函数
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*显示模式设置*/
   DelayMs(5);
   DelayMs(5);
   DelayMs(5);
   LCD_Write_Com(0x08);    /*显示关闭*/
   LCD_Write_Com(0x01);    /*显示清屏*/
   LCD_Write_Com(0x06);    /*显示光标移动设置*/
   DelayMs(5);
   LCD_Write_Com(0x0C);    /*显示开及光标设置*/
                    主函数
void main(void)
unsigned char i;
unsigned char *p;
LCD_Init();
while (1)
i = 1;
p = "3333333";
LCD_Clear();
LCD_Write_String(2,0,"Welcome to");
DelayMs(250);
while (*p)
        LCD_Write_Char(i,1,*p);
        i ++;
        p ++;
        DelayMs(250);
  DelayMs(250);
