查看: 1198|回复: 0
UPG2406TK-E2规格书
ID:371080 发表于 2018-7-13 17:44 | 显示全部楼层 |阅读模式
DESCRIPTION
The  μ PG2406TK is a GaAs MMIC for L, S-band SPDT (Single Pole Double Throw) switch which were designed for
mobile phone and another L, S-band application.
This device can operate 2 control switching by control voltage 1.8 to 5.3 V. This device can operate frequency from
0.01 to 3.0 GHz, having the low insertion loss and high isolation.
This device is housed in a 6-pin lead-less minimold package. And this package is able to high-density surface
mounting.
FEATURES
• Switch control voltage  : V cont (H) = 1.8 to 5.3 V (2.7 V TYP.)
: V cont (L) = −0.2 to +0.2 V (0 V TYP.)
• Low insertion loss  : L ins = 0.40 dB TYP. @ f = 1.0 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
: L ins = 0.47 dB TYP. @ f = 2.5 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
• High isolation  : ISL = 27 dB TYP. @ f = 1.0 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
: ISL = 17 dB TYP. @ f = 2.5 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
• Handling power  : P in (0.1 dB) = +29.0 dBm TYP. @ f = 2.0/2.5 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
: P in (1 dB) = +30.5 dBm TYP. @ f = 0.5 to 3.0 GHz, V cont (H) = 2.7 V, V cont (L) = 0 V
• High-density surface mounting : 6-pin lead-less minimold package (1.5 × 1.1 × 0.55 mm)
APPLICATIONS
• L, S-band digital cellular or cordless telephone
• W-LAN, WLL and Bluetooth
TM etc.
ORDERING INFORMATION
Part Number  Order Number  Package  Marking  Supplying Form
μ PG2406TK-E2  μ PG2406TK-E2-A  6-pin lead-less minimold
(1511 PKG) (Pb-Free)
G5K  • Embossed tape 8 mm wide
• Pin 1, 6 face the perforation side of the tape
• Qty 5 kpcs/reel
Remark To order evaluation samples, contact your nearby sales office.
Part number for sample order:  μ PG2406TK
DATA SHEET
Caution Although this device is designed to be as robust as possible, ESD (Electrostatic Discharge) can
damage this device. This device must be protected at all times from ESD. Static charges may
easily produce potentials of several kilovolts on the human body or equipment, which can
discharge without detection. Industry-standard ESD precautions must be employed at all times.
The information in this document is subject to change without notice. Before using this document, please
confirm that this is the latest version.
Not all products and/or types are available in every country. Please check with an NEC Electronics
sales representative for availability and additional information.
