查看: 4979|回复: 3
基于STM32F103RCT6的内部两路DAC其中一路不正常
ID:370737 发表于 2018-7-13 17:47 | 显示全部楼层 |阅读模式
为什么通道一输出正常,但是通道二输出总比设定值大啊?而且我给通道二设定初始值为零时,测量该引脚电压始终等于0.67V
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. #include "key.h"
  8. #include "dac.h"
  9. int main(void)
  10. {
  11.          u16 adcx;
  12.           u16 dacx=0;
  13.          u8 key;
  14.          float iwant[3]={1,1.5,2};
  15.          float temp1;
  16.          u16 temp2;
  17.          int i=0;
  18.          delay_init();
  19.          uart_init(9600);
  20.          LED_Init();
  21.          LCD_Init();
  22.          KEY_Init();
  23.         // Adc_Init();
  24.          Dac1_Init();
  25.          Dac2_Init();
  26.          Dac1_Set_Vol(1000);
  27.                  Dac2_Set_Vol(1500);
  28.
  29.           POINT_COLOR=BLACK;
  30.                  LCD_ShowString(30,40,200,16,16,"Mini STM32 ^_^");
  31.                  LCD_ShowString(30,60,200,16,16,"2018/7/9");
  32.                  LCD_ShowString(30,90,200,16,16,"DAC_VOL:");
  33.                  LCD_ShowString(30,110,200,16,16,"DAC_VAL:0.000");
  34.            LCD_ShowString(30,130,200,16,16,"ADC_VOL:");
  35.                  LCD_ShowString(30,150,200,16,16,"ADC_VAL:0.000");
  36.
  37.
  38.
  39.
  40.          while(1){
  41.                  key=KEY_Scan(0);
  42.                  delay_ms(10);
  43.                  if(key==KEY0_PRES){
  44.                          dacx=1.5/(3.3/4096);
  45.                          DAC_SetChannel1Data(DAC_Align_12b_R,dacx);
  46.                          DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  47.                          //adcx=Get_Adc_Average(ADC_Channel_1,10);
  48.          /*while(((iwant[i]/(3.3/4096))-adcx>5)||((adcx-(iwant[i]/(3.3/4096))>5)))
  49.                  {
  50.
  51.                                 if(adcx-(iwant[i]/(3.3/4096))>100){
  52.                                 dacx-=50;
  53.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  54.
  55.                                 }
  56.
  57.                         else if(( (iwant[i]/(3.3/4096))-adcx)>100){
  58.                                 dacx+=50;
  59.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  60.
  61.
  62.                         }
  63.                         else if((adcx-(iwant[i]/(3.3/4096))<=100)&&(adcx-(iwant[i]/(3.3/4096))>=20)){
  64.                                 dacx-=20;
  65.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  66.
  67.                         }
  68.                         else if(((iwant[i]/(3.3/4096))-adcx<=100)&&((iwant[i]/(3.3/4096))-adcx>=20)){
  69.                                 dacx+=20;
  70.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  71.
  72.                         }
  73.                         else if((adcx-(iwant[i]/(3.3/4096))<20)&&(adcx-(iwant[i]/(3.3/4096))>5)){
  74.                                 dacx-=2;
  75.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  76.                         }
  77.                                 else if(((iwant[i]/(3.3/4096))-adcx<20)&&((iwant[i]/(3.3/4096))-adcx>5)){
  78.                                 dacx+=2;
  79.                                 DAC_SetChannel2Data(DAC_Align_12b_R,dacx);
  80.
  81.                         }
  82.                         adcx=Get_Adc_Average(ADC_Channel_1,10);
  83.
  84.    LCD_ShowxNum(94,90,dacx,4,16,0);
  85.       temp1=(float)dacx*(3.3/4096);
  86.          temp2=temp1;
  87.          LCD_ShowxNum(94,110,temp2,1,16,0);
  88.          temp1-=temp2;
  89.          temp1*=1000;
  90.          LCD_ShowxNum(110,110,temp1,3,16,0X80);//显示DAC的实际值
  91.
  92.                                 LCD_ShowxNum(94,130,adcx,4,16,0);
  93.                                  temp1=(float)adcx*(3.3/4096);
  94.          temp2=temp1;
  95.          LCD_ShowxNum(94,150,temp2,1,16,0);
  96.          temp1-=temp2;
  97.          temp1*=1000;
  98.          LCD_ShowxNum(110,150,temp1,3,16,0X80);//显示ADC的实际值
  99.                         delay_ms(10);
  100.                         LED0=!LED0;
  101.          }*/
  102.                  LCD_ShowxNum(94,90,dacx,4,16,0);
  103.       temp1=(float)dacx*(3.3/4096);
  104.          temp2=temp1;
  105.          LCD_ShowxNum(94,110,temp2,1,16,0);
  106.          temp1-=temp2;
  107.          temp1*=1000;
  108.          LCD_ShowxNum(110,110,temp1,3,16,0X80);//显示DAC的实际值
  109.
  110.                                 /*LCD_ShowxNum(94,130,adcx,4,16,0);
  111.                                  temp1=(float)adcx*(3.3/4096);
  112.          temp2=temp1;
  113.          LCD_ShowxNum(94,150,temp2,1,16,0);
  114.          temp1-=temp2;
  115.          temp1*=1000;
  116.          LCD_ShowxNum(110,150,temp1,3,16,0X80);//显示ADC的实际值
  117.
  118.          if(i<2)
  119.          i++;
  120.          else i=0;*/
  121. }
  122.                  }
  123.          }
  124.
两路DA1.rar (338.97 KB, 下载次数: 43)
ID:331360 发表于 2020-5-25 11:38 | 显示全部楼层
我也是一样的问题,通道二PA5输出最低电压一直不为0
ID:375349 发表于 2021-5-6 13:03 | 显示全部楼层
同样的芯片我也是同样的写法,楼主解决了吗?
ID:375349 发表于 2021-5-6 13:04 | 显示全部楼层
您好,我和楼主同样的芯片,我也是同样的写法,请问你解决了吗?
