查看: 4484|回复: 3
精品0.96寸液晶图形摸拟钟加摸拟温度计
ID:358930 发表于 2018-7-14 12:10 来自触屏版 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
图片在底部
  1. //A4  SDA
  2. //A5  SCL
  3. //0X57   0X68
  4. #include <Arduino.h>
  5. #include <DS3231.h>
  6. #include <Wire.h>
  7. #include <Adafruit_GFX.h>
  8. #include <Adafruit_SSD1306.h>
  9. int r,xo,yo,a,b,c,z;//动画变量不能用char型变量无法计算
  10. int sec;//动画变量不能用char型变量无法计算
  11. DS3231 Clock;
  12. bool Century=false;
  13. bool h12;
  14. bool PM;
  15. byte ADay, AHour, AMinute, ASecond, ABits;
  16. bool ADy, A12h, Apm;
  17. int second,minute,hour,date,month,year,DoW;
  18. byte   temperature;//温度
  19. #define OLED_RESET 4
  20. Adafruit_SSD1306 display(OLED_RESET);
  21. #define NUMFLAKES 10
  22. #define XPOS 0
  23. #define YPOS 1
  24. #define DELTAY 2
  25. #define LOGO16_GLCD_HEIGHT 16
  26. #define LOGO16_GLCD_WIDTH  16
  27. #if (SSD1306_LCDHEIGHT != 64)
  28. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  29. #endif
  30. int x;//动画变量
  31. //显示一个心形
  32. static const uint8_t PROGMEM Heart_16x16[] = {
  33.   0x00,0x00,0x18,0x18,0x3C,0x3C,0x7E,0x7E,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  34.   0xFF,0xFF,0x7F,0xFE,0x3F,0xFC,0x1F,0xF8,0x0F,0xF0,0x07,0xE0,0x03,0xC0,0x00,0x00//未命名文件0
  35. };
  36. static const uint8_t PROGMEM bbjj_16x16[] ={
  37. 0x00,0x00,0x23,0xF8,0x12,0x08,0x12,0x08,0x83,0xF8,0x42,0x08,0x42,0x08,0x13,0xF8,
  38. 0x10,0x00,0x27,0xFC,0xE4,0xA4,0x24,0xA4,0x24,0xA4,0x24,0xA4,0x2F,0xFE,0x00,0x00,/*"温",0*/
  39. 0x01,0x00,0x00,0x80,0x3F,0xFE,0x22,0x20,0x22,0x20,0x3F,0xFC,0x22,0x20,0x22,0x20,
  40. 0x23,0xE0,0x20,0x00,0x2F,0xF0,0x24,0x10,0x42,0x20,0x41,0xC0,0x86,0x30,0x38,0x0E,/*"度",1*/
  41. };
  42. void setup()   {
  43. // Serial.begin(115200);
  44.   delay(500);
  45. Wire.begin();
  46.       /*
  47.          //改时间
  48.         Clock.setSecond(10);//Set the second
  49.         Clock.setMinute(40);//Set the minute
  50.         Clock.setHour(1);  //Set the hour
  51.         Clock.setDoW(7);    //Set the day of the week
  52.         Clock.setDate(24);  //Set the date of the month
  53.         Clock.setMonth(6);  //Set the month of the year
  54.         Clock.setYear(18);  //Set the year (Last two digits of the year)
  55.       */
  56.   display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  57. }
  58. void ReadDS3231()//读取时间
  59. {
  60.   second=Clock.getSecond(); //时间
  61.   minute=Clock.getMinute();//时间
  62.   hour=Clock.getHour(h12, PM);//时间
  63.   date=Clock.getDate(); //日期
  64.   month=Clock.getMonth(Century);//日期
  65.   year=Clock.getYear();  //日期
  66.   DoW=Clock.getDoW();//星期
  67.   temperature=Clock.getTemperature();//温度
  68. }
  69. void loop() {
  70.      ReadDS3231();//读取时间
  71.
  72.   //1.检测全屏显示(看看有没有大面积坏点)
  73.   display.fillScreen(WHITE);//检测全屏显示(看看有没有大面积坏点)
  74.   display.clearDisplay();   // clears the screen and buffer
  75. /*
  76.    //2.画点 点坐标(10,10)
  77.   display.drawPixel(20, 20, WHITE);// 列127 行63 画点 点坐标
  78.
  79.   //3. 画线 从(0,0)到(50,50)
  80.   display.drawLine(20, 25,20,63, WHITE);//(开始列127  开始行63)( 结束列127 结束行63)
  81.
  82.   //4.画空心矩形  左上角坐标(x0,y0)  右下角坐标(x1,y1)
  83.   display.drawRect(2,50,10,10,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y)
  84.
  85.   //5.画个实心矩形
  86.   display.fillRect(2,35,10,10,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y)
  87.
  88.    //6.画空心圆
  89.   display.drawCircle(36,50,6,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  90.
  91.   //7.画实心圆
  92.   display.fillCircle(36,30,6,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  93.
  94.   //8.画空心三角形
  95.   display.drawTriangle(60,32,45,43,70,43,WHITE);//(控制三角形A点列0/127 行0/63  控制三角形B点列0/127 行0/63 控制三角形C点列0/127 行0/63)
  96.
  97.   //9.画实心三角形
  98.   display.fillTriangle(86,32,72,43,100,43,WHITE);//(控制三角形A点列0/127 行0/63  控制三角形B点列0/127 行0/63 控制三角形C点列0/127 行0/63)
  99.   //10.画空心圆角矩形
  100.   display.drawRoundRect(50,17,15,15,2,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y  控制圆角=+x)
  101. //11.画实心圆角矩形
  102.   display.fillRoundRect(70,17,15,15,2,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y  控制圆角=+x)
  103.   //12.画心形(自己用取模软件画的)相当于一个任意16X16字
  104.   display.drawBitmap(88,17,Heart_16x16,16,16,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=16  结束大小=16)这里只能是16X16因为是16X16字
  105. //13.显示英文
  106.   display.setTextSize(2);//设置字体大小
  107.   display.setTextColor(WHITE);//设置字体不反白
  108.   display.setCursor(0,0);//列127 行63     坐标
  109.   display.println("bb");
  110.
  111.   //14.显示数字变量
  112.   display.setTextSize(2);//设置字体大小
  113.   display.setTextColor(BLACK, WHITE); //设置字体反白
  114.   display.setCursor(30,0);//列127 行63     坐标
  115.   display.println(x);
  116.
  117. //15.显示16进制变量
  118.   display.setTextSize(2);
  119.   display.setTextColor(WHITE);//设置字体不反白
  120.   display.setCursor(60,0);//列127 行63     坐标
  121.   display.print("0x");
  122.   display.println(x, HEX);
  123. //16.显示单个文字 就是调用drawBitmap(自己用取模软件取模)相当于一个任意16X16字
  124.   //display.drawBitmap(0,17,Strong_16x16,16,16,BLACK);//可用BLACK黑字在图片上显示(控制位置列0/127   控制位置行0/63  )(控制大小=16  结束大小=16)这里只能是16X16因为是16X16字
  125.   display.drawBitmap(0,17,Strong_16x16,16,16,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=16  结束大小=16)这里只能是16X16因为是16X16字
  126. //17.显示多个文字(在库里面加入一个ShowCN_16方法  为了同时显示多个中文 16X16 ,不然的话 就得一个一个drawBitmap)
  127.   display.ShowCN_16(0,45, bbjj_16x16,sizeof(bbjj_16x16)/32,WHITE);//查找数组法(控制位置列0/127   控制位置行0/63  )
  128. */
  129. //6.画空心圆
  130.    display.drawCircle(xo,yo,19,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  131.    display.drawCircle(xo,yo,25+6,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  132.   //7.画实心圆
  133.   display.fillCircle(xo,yo,2,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  134.    //不能用char型变量无法计算
  135.   r=17;//指针半径
  136.   xo=80;//圆心坐标x MAX 127
  137.   yo=32;//圆心坐标y  MAX 63
  138.   z=180;//圆
  139.   //second=0;//调整
  140.   // minute=0;//调整
  141.    // hour=0;//调整
  142.   int  hour1=hour;
  143.    if(hour1>12)
  144. {hour1=hour1-12;}
  145. else
  146. {hour1=hour1;}
  147.   a=(second-15)*6;//圆角度360/60
  148.   b=(minute-15)*6;//圆角度360/60
  149.   c=(hour1-15)*30;//圆角度360/12
  150.   //.画一圈实心圆
  151.    int B;
  152.    for(B=0;B<12;B++)//.画一圈实心圆
  153.    {
  154.      int A=B*30;//圆角度
  155.     if(B==0||B==3||B==6||B==9)//跳过这几个点画实心圆
  156.     {}
  157.     else
  158.    {
  159.     display.fillCircle((xo+((r+9)*cos(A*3.14/z))),(yo+((r+9)*sin(A*3.14/z))),1,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  160.    }
  161.    }
  162.   //.画sec时针线
  163.    display.drawLine((xo+(r*cos(a*3.14/z))),(yo+(r*sin(a*3.14/z))),xo,yo, WHITE);//(开始列127  开始行63)( 结束列127 结束行63) /////00
  164.   //.画minute时针线
  165.    display.drawLine((xo+((r-2)*cos(b*3.14/z))),(yo+((r-2)*sin(b*3.14/z))),xo,yo, WHITE);//(开始列127  开始行63)( 结束列127 结束行63) /////00
  166.    //.画hour时针线
  167.    display.drawLine((xo+((r-6)*cos(c*3.14/z))),(yo+((r-6)*sin(c*3.14/z))),xo,yo, WHITE);//(开始列127  开始行63)( 结束列127 结束行63) /////00
  168.
  169.    //7.画实心圆//.画sec时针线
  170.   display.fillCircle((xo+((r-4)*cos(a*3.14/z))),(yo+((r-4)*sin(a*3.14/z))),2,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  171.
  172.    //13.显示英文
  173.   display.setTextSize(1);//设置字体大小
  174.   display.setTextColor(WHITE);//设置字体不反白
  175.   display.setCursor(xo-6,yo-29);//列127 行63     坐标
  176.   display.println("12");
  177.   display.setCursor(xo+22,yo-2);//列127 行63     坐标
  178.   display.println("3");
  179.   display.setCursor(xo-2,yo+22);//列127 行63     坐标
  180.   display.println("6");
  181.   display.setCursor(xo-27,yo-3);//列127 行63     坐标
  182.   display.println("9");
  183.
  184.
  185. // 17.显示多个文字(在库里面加入一个ShowCN_16方法  为了同时显示多个中文 16X16 ,不然的话 就得一个一个drawBitmap)
  186.   display.ShowCN_16(0,40, bbjj_16x16,sizeof(bbjj_16x16)/32,WHITE);//查找数组法(控制位置列0/127   控制位置行0/63  )
  187.
  188.   display.setTextSize(3);
  189.   display.setTextColor(WHITE);
  190.
  191.   display.setCursor(0,17);
  192.   display.println((int)temperature);////温度
  193.
  194.   display.setTextSize(1);
  195.   display.setTextColor(WHITE);
  196.    display.setCursor(0,5);
  197.   display.println((int)hour/10);////
  198.    display.setCursor(7,5);
  199.    display.println((int)hour%10);////
  200.    display.setCursor(18,5);
  201.   display.println((int)minute/10);////
  202.    display.setCursor(25,5);
  203.   display.println((int)minute%10);////
  204.   display.setCursor(37,5);
  205.   display.println((int)second/10);////
  206.    display.setCursor(44,5);
  207.   display.println((int)second%10);////
  208. display.drawPixel(15, 6, WHITE);// 列127 行63 画点 点坐标
  209. display.drawPixel(15, 10, WHITE);// 列127 行63 画点 点坐标
  210. display.drawPixel(33, 6, WHITE);// 列127 行63 画点 点坐标
  211. display.drawPixel(33, 10, WHITE);// 列127 行63 画点 点坐标
  212.    //11.画空心圆角矩形
  213.   display.drawRoundRect(37,16,9,30,3,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y  控制圆角=+x)
  214.   //6.画空心圆
  215.   display.fillCircle(41,50,7,WHITE);//(控制圆心位置列0/127   控制圆心位置行0/63  )(控制大小=0+x )
  216.   //5.画个实心矩形
  217.   display.fillRect(39,(16+((60-temperature)/2)),5,30-(((60-temperature)/2)),WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  结束大小=行+Y)//温度
  218.   display.display();
  219.
  220.
  221. }
ID:358930 发表于 2018-7-14 12:11 来自触屏版 | 只看该作者
//A4  SDA
//A5  SCL
//0X57   0X68
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#endif
int x;//动画变量
//显示一个心形
void setup()   {
  delay(500);
Wire.begin();
         //改时间
void loop() {
     ReadDS3231();//读取时间
   //2.画点 点坐标(10,10)
  //5.画个实心矩形
   //6.画空心圆
  //7.画实心圆
  //8.画空心三角形
  //9.画实心三角形
  //10.画空心圆角矩形
//11.画实心圆角矩形
//13.显示英文
  //14.显示数字变量
  display.println(x);
//15.显示16进制变量
//6.画空心圆
  //7.画实心圆
   //不能用char型变量无法计算
  r=17;//指针半径
  z=180;//圆
  //second=0;//调整
  // minute=0;//调整
   // hour=0;//调整
  int  hour1=hour;
   if(hour1>12)
{hour1=hour1-12;}
{hour1=hour1;}
  //.画一圈实心圆
   int B;
     int A=B*30;//圆角度
  //.画sec时针线
  //.画minute时针线
   //.画hour时针线
   //7.画实心圆//.画sec时针线
   //13.显示英文
   //11.画空心圆角矩形
  //6.画空心圆
  //5.画个实心矩形
  display.display();
ID:358930 发表于 2018-7-14 12:14 来自触屏版 | 只看该作者
冰冰洁洁 发表于 2018-7-14 12:11
//A4  SDA
//A5  SCL
//0X57   0X68
上个图,大家一起分享。
ID:219332 发表于 2018-7-30 11:01 来自触屏版 | 只看该作者
谢谢,做的真漂亮
