查看: 2683|回复: 0
定时器计数器综合编程模拟控制交通指示灯
ID:350999 发表于 2018-7-16 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实验名称:定时器计数器综合编程模拟控制交通指示灯
#include <reg52.h>
sbit RED_A = P0^0;
sbit YELLOW_A = P0^1;
sbit GREEN_A = P0^2;
sbit RED_B = P0^3;
sbit YELLOW_B = P0^4;
sbit GREEN_B = P0^5;
uchar Time_Count = 0,Flash_Count = 0,Operation_Type = 1;
void T0_INT() interrupt 1
        TH0 = -50000/256;
        TL0 = -50000%256;
        switch(Operation_Type)
                 case 1:
                        RED_A=0;YELLOW_A=0;GREEN_A=1;
                        RED_B=1;YELLOW_B=0;GREEN_B=0;
                        if(++Time_Count != 100) return;
                        Time_Count=0;
                        Operation_Type = 2;
                        break;
                case 2:
                        if(++Time_Count != 8) return;
                        Time_Count=0;
                        YELLOW_A=!YELLOW_A;
                        GREEN_A=0;
                        if(++Flash_Count != 10) return;
                        Flash_Count=0;
                        Operation_Type = 3;
                        break;
                case 3:
                        RED_A=1;YELLOW_A=0;GREEN_A=0;
                        RED_B=0;YELLOW_B=0;GREEN_B=1;
                        Time_Count=0;
                        Operation_Type = 4;
                        break;
                case 4:
                        Time_Count=0;
                        YELLOW_B=!YELLOW_B;
                        GREEN_B=0;
                        if(++Flash_Count !=10)
                                return;
                        Flash_Count=0;
                        Operation_Type = 1;
                        break;
        TMOD = 0x01;
        IE = 0x82;
        TR0 = 1;
        while(1);
