查看: 9961|回复: 2
ADS1115引脚图电路图与arduino源程序及pdf资料手册下载
ADS1115资料,了解一下
ADS1115引脚图:
ADS1115管脚功能描述:
ADS1115框图:
ADS1115电路图:
arduino源程序如下:
  1. /**************************************************************************/
  2. /*!
  3.     @file     Adafruit_ADS1015.cpp
  4.     @author   K.Townsend (Adafruit Industries)
  5.     @license  BSD (see license.txt)
  6.     Driver for the ADS1015/ADS1115 ADC
  7.     This is a library for the Adafruit MPL115A2 breakout
  8.     Adafruit invests time and resources providing this open source code,
  9.     please support Adafruit and open-source hardware by purchasing
  10.     products from Adafruit!
  11.     @section  HISTORY
  12.     v1.0 - First release
  13. */
  14. /**************************************************************************/
  15. #if ARDUINO >= 100
  16. #include "Arduino.h"
  17. #else
  18. #include "WProgram.h"
  19. #endif
  20. #include <Wire.h>
  21. #include "Adafruit_ADS1015.h"
  22. /**************************************************************************/
  23. /*!
  24.     @brief  Abstract away platform differences in Arduino wire library
  25. */
  26. /**************************************************************************/
  27. static uint8_t i2cread(void) {
  28.   #if ARDUINO >= 100
  29.   return Wire.read();
  30.   #else
  31.   return Wire.receive();
  32.   #endif
  33. }
  34. /**************************************************************************/
  35. /*!
  36.     @brief  Abstract away platform differences in Arduino wire library
  37. */
  38. /**************************************************************************/
  39. static void i2cwrite(uint8_t x) {
  40.   #if ARDUINO >= 100
  41.   Wire.write((uint8_t)x);
  42.   #else
  43.   Wire.send(x);
  44.   #endif
  45. }
  46. /**************************************************************************/
  47. /*!
  48.     @brief  Writes 16-bits to the specified destination register
  49. */
  50. /**************************************************************************/
  51. static void writeRegister(uint8_t i2cAddress, uint8_t reg, uint16_t value) {
  52.   Wire.beginTransmission(i2cAddress);
  53.   i2cwrite((uint8_t)reg);
  54.   i2cwrite((uint8_t)(value>>8));
  55.   i2cwrite((uint8_t)(value & 0xFF));
  56.   Wire.endTransmission();
  57. }
  58. /**************************************************************************/
  59. /*!
  60.     @brief  Writes 16-bits to the specified destination register
  61. */
  62. /**************************************************************************/
  63. static uint16_t readRegister(uint8_t i2cAddress, uint8_t reg) {
  64.   Wire.beginTransmission(i2cAddress);
  65.   i2cwrite(ADS1015_REG_POINTER_CONVERT);
  66.   Wire.endTransmission();
  67.   Wire.requestFrom(i2cAddress, (uint8_t)2);
  68.   return ((i2cread() << 8) | i2cread());
  69. }
  70. /**************************************************************************/
  71. /*!
  72.     @brief  Instantiates a new ADS1015 class w/appropriate properties
  73. */
  74. /**************************************************************************/
  75. Adafruit_ADS1015::Adafruit_ADS1015(uint8_t i2cAddress)
  76. {
  77.    m_i2cAddress = i2cAddress;
  78.    m_conversionDelay = ADS1015_CONVERSIONDELAY;
  79.    m_bitShift = 4;
  80.    m_gain = GAIN_TWOTHIRDS; /* +/- 6.144V range (limited to VDD +0.3V max!) */
  81. }
  82. /**************************************************************************/
  83. /*!
  84.     @brief  Instantiates a new ADS1115 class w/appropriate properties
  85. */
  86. /**************************************************************************/
  87. Adafruit_ADS1115::Adafruit_ADS1115(uint8_t i2cAddress)
  88. {
  89.    m_i2cAddress = i2cAddress;
  90.    m_conversionDelay = ADS1115_CONVERSIONDELAY;
  91.    m_bitShift = 0;
  92.    m_gain = GAIN_TWOTHIRDS; /* +/- 6.144V range (limited to VDD +0.3V max!) */
  93. }
  94. /**************************************************************************/
  95. /*!
  96.     @brief  Sets up the HW (reads coefficients values, etc.)
  97. */
  98. /**************************************************************************/
  99. void Adafruit_ADS1015::begin() {
  100.   Wire.begin();
  101. }
  102. /**************************************************************************/
  103. /*!
  104.     @brief  Sets the gain and input voltage range
  105. */
  106. /**************************************************************************/
  107. void Adafruit_ADS1015::setGain(adsGain_t gain)
  108. {
  109.   m_gain = gain;
  110. }
  111. /**************************************************************************/
  112. /*!
  113.     @brief  Gets a gain and input voltage range
  114. */
  115. /**************************************************************************/
  116. adsGain_t Adafruit_ADS1015::getGain()
  117. {
  118.   return m_gain;
  119. }
  120. /**************************************************************************/
  121. /*!
  122.     @brief  Gets a single-ended ADC reading from the specified channel
  123. */
  124. /**************************************************************************/
  125. uint16_t Adafruit_ADS1015::readADC_SingleEnded(uint8_t channel) {
  126.   if (channel > 3)
  127.   {
  128.     return 0;
  129.   }
  130.
  131.   // Start with default values
  132.   uint16_t config = ADS1015_REG_CONFIG_CQUE_NONE    | // Disable the comparator (default val)
  133.                     ADS1015_REG_CONFIG_CLAT_NONLAT  | // Non-latching (default val)
  134.                     ADS1015_REG_CONFIG_CPOL_ACTVLOW | // Alert/Rdy active low   (default val)
  135.                     ADS1015_REG_CONFIG_CMODE_TRAD   | // Traditional comparator (default val)
  136.                     ADS1015_REG_CONFIG_DR_1600SPS   | // 1600 samples per second (default)
  137.                     ADS1015_REG_CONFIG_MODE_SINGLE;   // Single-shot mode (default)
  138.   // Set PGA/voltage range
  139.   config |= m_gain;
  140.   // Set single-ended input channel
  141.   switch (channel)
  142.   {
  143.     case (0):
  144.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_0;
  145.       break;
  146.     case (1):
  147.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_1;
  148.       break;
  149.     case (2):
  150.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_2;
  151.       break;
  152.     case (3):
  153.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_3;
  154.       break;
  155.   }
  156.   // Set 'start single-conversion' bit
  157.   config |= ADS1015_REG_CONFIG_OS_SINGLE;
  158.   // Write config register to the ADC
  159.   writeRegister(m_i2cAddress, ADS1015_REG_POINTER_CONFIG, config);
  160.   // Wait for the conversion to complete
  161.   delay(m_conversionDelay);
  162.   // Read the conversion results
  163.   // Shift 12-bit results right 4 bits for the ADS1015
  164.   return readRegister(m_i2cAddress, ADS1015_REG_POINTER_CONVERT) >> m_bitShift;
  165. }
  166. /**************************************************************************/
  167. /*!
  168.     @brief  Reads the conversion results, measuring the voltage
  169.             difference between the P (AIN0) and N (AIN1) input.  Generates
  170.             a signed value since the difference can be either
  171.             positive or negative.
  172. */
  173. /**************************************************************************/
  174. int16_t Adafruit_ADS1015::readADC_Differential_0_1() {
  175.   // Start with default values
  176.   uint16_t config = ADS1015_REG_CONFIG_CQUE_NONE    | // Disable the comparator (default val)
  177.                     ADS1015_REG_CONFIG_CLAT_NONLAT  | // Non-latching (default val)
  178.                     ADS1015_REG_CONFIG_CPOL_ACTVLOW | // Alert/Rdy active low   (default val)
  179.                     ADS1015_REG_CONFIG_CMODE_TRAD   | // Traditional comparator (default val)
  180.                     ADS1015_REG_CONFIG_DR_1600SPS   | // 1600 samples per second (default)
  181.                     ADS1015_REG_CONFIG_MODE_SINGLE;   // Single-shot mode (default)
  182.   // Set PGA/voltage range
  183.   config |= m_gain;
  184.
  185.   // Set channels
  186.   config |= ADS1015_REG_CONFIG_MUX_DIFF_0_1;          // AIN0 = P, AIN1 = N
  187.   // Set 'start single-conversion' bit
  188.   config |= ADS1015_REG_CONFIG_OS_SINGLE;
  189.   // Write config register to the ADC
  190.   writeRegister(m_i2cAddress, ADS1015_REG_POINTER_CONFIG, config);
  191.   // Wait for the conversion to complete
  192.   delay(m_conversionDelay);
  193.   // Read the conversion results
  194.   uint16_t res = readRegister(m_i2cAddress, ADS1015_REG_POINTER_CONVERT) >> m_bitShift;
  195.   if (m_bitShift == 0)
  196.   {
  197.     return (int16_t)res;
  198.   }
  199.   else
  200.   {
  201.     // Shift 12-bit results right 4 bits for the ADS1015,
  202.     // making sure we keep the sign bit intact
  203.     if (res > 0x07FF)
  204.     {
  205.       // negative number - extend the sign to 16th bit
  206.       res |= 0xF000;
  207.     }
  208.     return (int16_t)res;
  209.   }
  210. }
  211. /**************************************************************************/
  212. /*!
  213.     @brief  Reads the conversion results, measuring the voltage
  214.             difference between the P (AIN2) and N (AIN3) input.  Generates
  215.             a signed value since the difference can be either
  216.             positive or negative.
  217. */
  218. /**************************************************************************/
  219. int16_t Adafruit_ADS1015::readADC_Differential_2_3() {
  220.   // Start with default values
  221.   uint16_t config = ADS1015_REG_CONFIG_CQUE_NONE    | // Disable the comparator (default val)
  222.                     ADS1015_REG_CONFIG_CLAT_NONLAT  | // Non-latching (default val)
  223.                     ADS1015_REG_CONFIG_CPOL_ACTVLOW | // Alert/Rdy active low   (default val)
  224.                     ADS1015_REG_CONFIG_CMODE_TRAD   | // Traditional comparator (default val)
  225.                     ADS1015_REG_CONFIG_DR_1600SPS   | // 1600 samples per second (default)
  226.                     ADS1015_REG_CONFIG_MODE_SINGLE;   // Single-shot mode (default)
  227.   // Set PGA/voltage range
  228.   config |= m_gain;
  229.   // Set channels
  230.   config |= ADS1015_REG_CONFIG_MUX_DIFF_2_3;          // AIN2 = P, AIN3 = N
  231.   // Set 'start single-conversion' bit
  232.   config |= ADS1015_REG_CONFIG_OS_SINGLE;
  233.   // Write config register to the ADC
  234.   writeRegister(m_i2cAddress, ADS1015_REG_POINTER_CONFIG, config);
  235.   // Wait for the conversion to complete
  236.   delay(m_conversionDelay);
  237.   // Read the conversion results
  238.   uint16_t res = readRegister(m_i2cAddress, ADS1015_REG_POINTER_CONVERT) >> m_bitShift;
  239.   if (m_bitShift == 0)
  240.   {
  241.     return (int16_t)res;
  242.   }
  243.   else
  244.   {
  245.     // Shift 12-bit results right 4 bits for the ADS1015,
  246.     // making sure we keep the sign bit intact
  247.     if (res > 0x07FF)
  248.     {
  249.       // negative number - extend the sign to 16th bit
  250.       res |= 0xF000;
  251.     }
  252.     return (int16_t)res;
  253.   }
  254. }
  255. /**************************************************************************/
  256. /*!
  257.     @brief  Sets up the comparator to operate in basic mode, causing the
  258.             ALERT/RDY pin to assert (go from high to low) when the ADC
  259.             value exceeds the specified threshold.
  260.             This will also set the ADC in continuous conversion mode.
  261. */
  262. /**************************************************************************/
  263. void Adafruit_ADS1015::startComparator_SingleEnded(uint8_t channel, int16_t threshold)
  264. {
  265.   // Start with default values
  266.   uint16_t config = ADS1015_REG_CONFIG_CQUE_1CONV   | // Comparator enabled and asserts on 1 match
  267.                     ADS1015_REG_CONFIG_CLAT_LATCH   | // Latching mode
  268.                     ADS1015_REG_CONFIG_CPOL_ACTVLOW | // Alert/Rdy active low   (default val)
  269.                     ADS1015_REG_CONFIG_CMODE_TRAD   | // Traditional comparator (default val)
  270.                     ADS1015_REG_CONFIG_DR_1600SPS   | // 1600 samples per second (default)
  271.                     ADS1015_REG_CONFIG_MODE_CONTIN  | // Continuous conversion mode
  272.                     ADS1015_REG_CONFIG_MODE_CONTIN;   // Continuous conversion mode
  273.   // Set PGA/voltage range
  274.   config |= m_gain;
  275.
  276.   // Set single-ended input channel
  277.   switch (channel)
  278.   {
  279.     case (0):
  280.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_0;
  281.       break;
  282.     case (1):
  283.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_1;
  284.       break;
  285.     case (2):
  286.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_2;
  287.       break;
  288.     case (3):
  289.       config |= ADS1015_REG_CONFIG_MUX_SINGLE_3;
  290.       break;
  291.   }
  292. ……………………
  293. …………限于本文篇幅 余下代码请从51黑下载附件…………
所有资料51hei提供下载(内含资料手册):
ADS1115,ADS1015资料.zip (1.4 MB, 下载次数: 49)
ID:389852 发表于 2018-9-3 10:01 | 只看该作者
最近在做这个啊,就是老感觉采样速度不行,该配置的都配置了,郁闷
ID:64765 发表于 2019-10-13 16:51 | 只看该作者
好资料,学习了,谢谢分享。
