查看: 28885|回复: 0
D类放大器IRS2092引脚图电路图与资料手册下载
D 类放大器又可称数字式功率放大,基本架构如图 2 所示,输入讯号经由脉波宽度调变器(Pulse Width Modulation)将音频信号调制成数字信号后,由功率晶体管(Q1,Q2)放大输出,再经由低通滤波器(Lf,Cf)取出原输入端的音频讯号送至喇叭输出。
IRS2092引脚图:
IRS2092管脚功能定义:
IRS2092应用电路图:
IRS2092框图:
Note 1:  Logic operational for Vs equal to –5 V to +200 V. Logic state held for Vs equal to –5 V to –VBS.
Note 2:  Nominal voltage for VREF is 5.1 V.  IOREF of 0.3 – 0.8 mA dictates total external resistor value on VREF to be 6.3 kΩ to
16.7 kΩ.
Note 3:  GND input voltage is limited by IAAZ and ISSZ.
Note 4:  VSS ramps up from 0 V to 200 V.
Note 5:  Output logic status may not respond correctly if input pulse width is smaller than the minimum pulse width.
[10]IRAUDAMP7D.pdf
644.02 KB, 下载次数: 64, 下载积分: 黑币 -5
IRS2092.pdf
231.23 KB, 下载次数: 52, 下载积分: 黑币 -5
[02]IRS2092.pdf
375.04 KB, 下载次数: 53, 下载积分: 黑币 -5
2092数字板.pdf
79.96 KB, 下载次数: 82, 下载积分: 黑币 -5
