查看: 2465|回复: 0
单片机向主机发送字符串
ID:350999 发表于 2018-7-18 13:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
void Delay(uint x)
        uchar i;
        while(x--)
                 for(i=0;i<120;i++);
void putc_to_SerialPort(uchar c)
        SBUF = c;
        while(TI == 0);
        TI = 0;
void puts_to_SerialPort(uchar *s)
        while(*s != '\0')
                 putc_to_SerialPort(*s);
                s++;
                Delay(5);
        uchar c = 0;
        SCON = 0x40;
        TMOD = 0x20;
        PCON = 0x00;
        TH1  = 0xfd;
        TL1  = 0xfd;
        TI   = 0;
        TR1  = 1;
        Delay(200);
        puts_to_SerialPort("Receiving From 8051...\r\n");
        puts_to_SerialPort("------------------------------\r\n");
        Delay(50);
                putc_to_SerialPort(c+'A');
                Delay(100);
                putc_to_SerialPort(' '); //这个地方‘’间只能有且必须有一个空格
                Delay(100);
                if(c==25)
                         puts_to_SerialPort("\r\n---------------------------\r\n");
                        Delay(100);
                c = (c+1)%26;
                if(c%10==0)
                         puts_to_SerialPort("\r\n");
                        Delay(100);
