查看: 3738|回复: 1
基于51单片机的adc0809自动切换量程
adc0809测量范围为5V,如果大于5V,就要分压;
自动切换量程,就是先采集分压之后的电压,如果过小,就通过继电器换路,进行直接测量
电路原理图如下:
单片机源码:
  1. #include<regx51.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. #define Duan P2
  6. #define Wei P1
  7. sbit START=P0^0;
  8. sbit EOC=P0^1;
  9. sbit max=P0^2;
  10. unsigned char code smg_duan[] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  11. unsigned char code smg_duan1[] ={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
  12. unsigned char code smg_wei[] ={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  13. void delay_ms(int t){
  14.         int i;
  15.         for(t;t>0;t--)
  16.                 for(i=110;i>0;i--);
  17. }
  18. void display(long num)
  19. {
  20.         long num1[8],i;
  21.         num1[7] = num/10000000;
  22.         num1[6] = (num/1000000)%10;
  23.         num1[5] = (num/100000)%10;
  24.         num1[4] = (num/10000)%10;
  25.         num1[3] = (num/1000)%10;
  26.         num1[2] = (num/100)%10;
  27.         num1[1] = (num/10)%10;
  28.         num1[0] = num%10;
  29.         for(i=0;i<8;i++){
  30.         Wei = smg_wei[i];
  31.         if(i==4)
  32.                 Duan = smg_duan1[num1[i]];
  33.         else
  34.                 Duan = smg_duan[num1[i]];
  35.         delay_ms(1);
  36.         }
  37. }
  38. void main(){
  39.         uint ad_value;
  40.         long dis;
  41.         while(1){
  42.                 max=0;
  43.                 display(dis);
  44.                 START = 0;
  45.                 START = 1;
  46.                 _nop_();
  47.                 _nop_();
  48.                 START = 0;    //产生下降沿,启动AD
  49.                 while(!EOC);
  50.                 P3=0xff;
  51.                 ad_value=P3;
  52.                 dis=(ad_value)*196.0784*20;
  53.                 if(dis<=5)    //直接测量
  54.                 {
  55.                         max=1;
  56.                         display(dis);
  57.                         START = 0;
  58.                         START = 1;
  59.                         _nop_();
  60.                         _nop_();
  61.                         START = 0;    //产生下降沿,启动AD
  62.                         while(!EOC);
  63.                         P3=0xff;
  64.                         ad_value=P3;
  65.                         dis=(ad_value)*196.0784;
  66.                 }
  67.
  68.                 //display(dis);
  69.                 //delay_ms(10);
  70.         }
  71. }
ID:247623 发表于 2020-6-26 21:00 | 只看该作者
没有下载的资料?
