查看: 1728|回复: 1
51单片机闪存程序
ID:157285 发表于 2018-7-24 15:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
sfr IAP_DATA  = 0xe2;
sfr IAP_ADDRH = 0xe3;
sfr IAP_ADDRL = 0xe4;
sfr IAP_CMD   = 0xe5;
sfr IAP_TRIG  = 0xe6;
sfr IAP_CONTR = 0xe7;
#define CMD_IDLE 0       //stand-by
#define CMD_READ 1       //byte-read
#define CMD_PROGPAM 2    //byte-program
#define CMD_ERASE 3      //sector-erase
#define ENABLE_IAP 0x81   //if sysclk<20MHz
#define IAP_ADDRESS 0x08000
void Iapidle();
BYTE IapReadByte(WORD addr);
void IapProgramByte(WORD addr,BYTE dat);
void IapEraseSector(WORD addr);
  WORD i;
  P1=0xfe;
  Delay(10);
  IapEraseSector(IAP_ADDRESS);
  for(i=0;i<512;i++)      //check whether all sector data is ff
    if(IapReadByte(IAP_ADDRESS+i)!=0xff)
    goto error;                  //if error break
  P1=0xfc;
  Delay(10);
  for(i=0;i<512;i++)           //program 512 bytes data into data flash
    IapProgramByte(IAP_ADDRESS+i,(BYTE)i);
  P1=0xf8;
  Delay(10);
  for(i=0;i<512;i++)
    if(IapReadByte(IAP_ADDRESS+i)!=(BYTE)i)
    goto Error;
  P1 = 0xf0;
  while(1);
Error:
  P1&0x7f;
  while(1);
software delay function
void Delay(BYTE n)
  WORD x;
  while(n--)
    x = 0;
    while(++x);
disable ISP/IAP/EEPROM function
make MCU in a safe state
void Iapdle()
  IAP_CONTR = 0;       //close IAP function
  IAP_CMD = 0;         //clear command to stand-by
  IAP_TRIG = 0;        //clear trigger register
  IAP_ADDRH = 0x80;    //data ptr point to non-EEPROM area
51内核单片机闪存的用法.docx
12.35 KB, 下载次数: 5, 下载积分: 黑币 -5
ID:1 发表于 2018-7-24 15:29 | 只看该作者
闪存的型号是?
