查看: 1817|回复: 0
arduino数码管显示
ID:380619 发表于 2018-7-29 20:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define d_a 2
#define d_b 3
#define d_c 4
#define d_d 5
#define d_e 6
#define d_f 7
#define d_g 8
#define d_h 9
#define COM1 10
#define COM2 11
#define COM3 12
#define COM4 13
unsigned char num[20][8] = {
//a  b  c  d  e  f  g  h
  {0,0,0,0,0,0,0,0},
  {1, 1, 1, 1, 1, 1, 0, 0},     //0
  {0, 1, 1, 0, 0, 0, 0, 0},     //1
  {1, 1, 0, 1, 1, 0, 1, 0},     //2
  {1, 1, 1, 1, 0, 0, 1, 0},     //3
  {0, 1, 1, 0, 0, 1, 1, 0},     //4
  {1, 0, 1, 1, 0, 1, 1, 0},     //5
  {1, 0, 1, 1, 1, 1, 1, 0},     //6
  {1, 1, 1, 0, 0, 0, 0, 0},     //7
  {1, 1, 1, 1, 1, 1, 1, 0},     //8
  {1, 1, 1, 1, 0, 1, 1, 0},     //9
  {1, 1, 1, 0, 1, 1, 1, 1},     //A
  {1, 1, 1, 1, 1, 1, 1, 1},     //B
  {1, 0, 0, 1, 1, 1, 0, 1},     //C
  {1, 1, 1, 1, 1, 1, 0, 1},     //D
  {1, 0, 0, 1, 1, 1, 1, 1},     //E
  {1, 0, 0, 0, 1, 1, 1, 1},     //F
  {0, 0, 0, 0, 0, 0, 0, 1},      //.
  {0,0,0,0,0,0,1,0},
  {1,1,1,1,1,1,0,1},
void setup()
    pinMode(d_a,OUTPUT);
    pinMode(d_b,OUTPUT);
    pinMode(d_c,OUTPUT);
    pinMode(d_d,OUTPUT);
    pinMode(d_e,OUTPUT);
    pinMode(d_f,OUTPUT);
    pinMode(d_g,OUTPUT);
    pinMode(d_h,OUTPUT);
    pinMode(COM1,OUTPUT);
    pinMode(COM2,OUTPUT);
    pinMode(COM3,OUTPUT);
    pinMode(COM4,OUTPUT);
void loop()
  for(int i=10;i>1;i--)
  {   for(int q = 0;q<250;q++)
      Display(3,18);
      delay(2);
      Display(4,i);
      delay(2);
  for(int j=10;j>1;j--)
      Display(3,19);
      delay(2);
      Display(4,j);
      delay(2);
    for(int j=1;j<=10;j++)
       if((j==3)||(j==4)||(j==6)||(j==8))
        Display(4,j);
        delay(100);
        Display(4,0);
        delay(100);
        Display(4,j);
        delay(100);
        Display(4,0);
        delay(100);
        Display(4,j);
        delay(100);
        Display(4,0);
        delay(100);
        Display (4,j);
        delay(1000);
       if((j==2)||(j==4)||(j==8)||(j==10))
        for(int p=0;p<250;p++){
        Display(3,2);
        delay(2);
        Display(4,j);
        delay(2);}
        Display(4,0);
        delay(100);
        Display(3,2);
        delay(2);
        Display(4,j);
        delay(2);}
        Display(4,0);
        delay(100);
        Display(3,2);
        delay(2);
        Display(4,j);
        delay(2);}
        Display(4,0);
        delay(100);
        Display(3,2);
        delay(2);
        Display(4,j);
        delay(2);}
      Display(3,3);
      delay(2);
      Display(4,1);
      delay(2);
void Display(unsigned char com,unsigned char n) {
    digitalWrite(d_a,LOW);
    digitalWrite(d_b,LOW);
    digitalWrite(d_c,LOW);
    digitalWrite(d_d,LOW);
    digitalWrite(d_e,LOW);
    digitalWrite(d_f,LOW);
    digitalWrite(d_g,LOW);
    digitalWrite(d_h,LOW);
    switch(com) {
        case 1:
            digitalWrite(COM1,LOW);
            digitalWrite(COM2,HIGH);
            digitalWrite(COM3,HIGH);
            digitalWrite(COM4,HIGH);
            break;
        case 2:
            digitalWrite(COM1,HIGH);
            digitalWrite(COM2,LOW);
            break;
        case 3:
            digitalWrite(COM3,LOW);
            break;
        case 4:
            digitalWrite(COM4,LOW);
            break;
        default:break;
    digitalWrite(d_a,num[n][0]);
    digitalWrite(d_b,num[n][1]);
    digitalWrite(d_c,num[n][2]);
    digitalWrite(d_d,num[n][3]);
    digitalWrite(d_e,num[n][4]);
    digitalWrite(d_f,num[n][5]);
    digitalWrite(d_g,num[n][6]);
    digitalWrite(d_h,num[n][7]);
