查看: 5265|回复: 3
GY-30 STM32代码
ID:256683 发表于 2018-7-30 08:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "GY30.h"
  2. #include "stm32f10x.h"
  3. #include "stm32f10x_gpio.h"
  4. #include "stm32f10x_rcc.h"
  5. //工程使用iic通信
  6. //SDA接的管脚为  PB0
  7. //SCL接的管脚为   PB1
  8. void GPIOConfig(void)//io口初始化
  9. {
  10.          GPIO_InitTypeDef  GPIO_InitStructure;
  11.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能PB端口时钟
  12.          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;                //
  13.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
  14.          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  15.          GPIO_Init(GPIOB, &GPIO_InitStructure);
  16. }
  17. void Delay_mms(uint16_t tmp)//延时毫秒
  18. {
  19.         uint16_t i=0;
  20.         while(tmp--)
  21.         {
  22.                 i = 12000;
  23.                 while(i--);
  24.         }
  25. }
  26. void Delay_5us(void) //延时5um
  27. {
  28.         uint16_t i =0 ;
  29.         uint16_t timer =5;
  30.         while(timer--)
  31.         {
  32.                 i =10;
  33.                 while(i--);
  34.         }
  35. }
  36. void GY30_Start() //开始信号
  37. {
  38.          GPIO_SetBits(GPIOB,GPIO_Pin_0);     //拉高数据线
  39.          GPIO_SetBits(GPIOB,GPIO_Pin_1);            //拉高时钟线
  40.          Delay_5us();
  41.          GPIO_ResetBits(GPIOB,GPIO_Pin_0);                          //产生下降沿
  42.          Delay_5us();
  43.          GPIO_ResetBits(GPIOB,GPIO_Pin_1);             //拉低时钟线
  44. }
  45. void GY30_Stop()  //停止信号
  46. {
  47.          GPIO_ResetBits(GPIOB,GPIO_Pin_0);      //拉低数据线
  48.          GPIO_SetBits(GPIOB,GPIO_Pin_1);               //拉高时钟线
  49.          Delay_5us();
  50.          GPIO_SetBits(GPIOB,GPIO_Pin_0);    //产生上升沿
  51.          Delay_5us();
  52. }
  53. void GY30_SendACK(int ack)                //发送应答信号
  54. {
  55.          GPIO_InitTypeDef  GPIO_InitStructure;
  56.          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                //SDA
  57.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
  58.          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  59.          GPIO_Init(GPIOB, &GPIO_InitStructure);
  60.         if(ack ==1)
  61.         {
  62.                 GPIO_SetBits(GPIOB,GPIO_Pin_0);
  63.         }
  64.         else if(ack ==0 )
  65.         {
  66.                 GPIO_ResetBits(GPIOB,GPIO_Pin_0);
  67.         }
  68.         else
  69.                 return;
  70.           GPIO_SetBits(GPIOB,GPIO_Pin_1);
  71.           Delay_5us();
  72.                 GPIO_ResetBits(GPIOB,GPIO_Pin_1);
  73.                 Delay_5us();
  74. }
  75. int GY30_RecvACK()                                        //接受应答信号
  76. {
  77.         GPIO_InitTypeDef  GPIO_InitStructure;
  78.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                //GPIO_Pin_0    0    GPIO_Pin_1 1
  79.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                  //输入上拉
  80.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  81.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  82.
  83.         GPIO_SetBits(GPIOB,GPIO_Pin_1);
  84.         Delay_5us();
  85.
  86.         if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0) == 1)
  87.                 mcy = 1;
  88.         else
  89.                 mcy =0;
  90.
  91.         GPIO_ResetBits(GPIOB,GPIO_Pin_1);                                //拉低时钟线
  92.         Delay_5us();
  93.
  94.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
  95.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  96.         return mcy;
  97. }
  98. void GY30_SendByte(uchar dat)
  99. {
  100.         uchar i;
  101.         for(i=0; i<8;i++)
  102.         {
  103.                 if(0x80 & dat)
  104.                                 GPIO_SetBits(GPIOB,GPIO_Pin_0);
  105.                 else
  106.                                 GPIO_ResetBits(GPIOB,GPIO_Pin_0);
  107.                                 dat <<= 1;
  108.
  109.                            GPIO_SetBits(GPIOB,GPIO_Pin_1);
  110.                                 Delay_5us();
  111.                            GPIO_ResetBits(GPIOB,GPIO_Pin_1);
  112.                                 Delay_5us();
  113.
  114.         }
  115.         GY30_RecvACK();
  116. }
  117. uchar GY30_RecvByte()
  118. {
  119.         uchar i;
  120.         uchar dat=0;
  121.         uchar bit;
  122.         GPIO_InitTypeDef  GPIO_InitStructure;
  123.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                //SDA
  124.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                  //输入上拉
  125.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  126.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  127.
  128.         GPIO_SetBits(GPIOB,GPIO_Pin_0);                        //使能内部上拉,准备接受数据
  129.         for(i=0; i<8;i++)
  130.         {
  131.                 dat <<= 1;
  132.                 GPIO_SetBits(GPIOB,GPIO_Pin_1);     //拉高时钟线
  133.                 Delay_5us();
  134.                 if(SET == GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0))
  135.                         bit = 0x01;
  136.                 else
  137.                         bit = 0x00;
  138.                 dat |= bit;                                //读数据
  139.                 GPIO_ResetBits(GPIOB,GPIO_Pin_1);
  140.                 Delay_5us();
  141.                 }
  142.
  143.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //输入上拉
  144.                 GPIO_Init(GPIOB, &GPIO_InitStructure);
  145.                 return dat;
  146.
  147. }
  148. void Single_Write_GY30(uchar REG_Address)
  149. {
  150.         GY30_Start();                                //起使信号
  151.         GY30_SendByte(SlaveAddress);                                //发送设备地址+写信号
  152.         GY30_SendByte(REG_Address);                                        //内部寄存器地址
  153.         GY30_Stop();
  154. }
  155. void Init_GY30()
  156. {
  157.         Single_Write_GY30(0x01);
  158. }
  159. void mread(void)
  160. {
  161.         uchar i;
  162.         GY30_Start();
  163.         GY30_SendByte(SlaveAddress + 1);                                //发送设备地址+读信号
  164.         for(i=0; i<3;i++)
  165.         {
  166.                 BUF[i] = GY30_RecvByte();
  167.                 if(i ==3)
  168.                 {
  169.                         GY30_SendACK(1);                                //最后一个回应NOACK
  170.                 }
  171.                 else
  172.                 {
  173.                         GY30_SendACK(0);
  174.                 }
  175.         }
  176.                 GY30_Stop();
  177.                 Delay_mms(5);
  178. }
  179. #ifndef __GY30_H
  180. #define __GY30_H
  181. #include "stm32f10x.h"
  182. #define uchar unsigned char
  183. #define uint unsigned int
  184. #define SlaveAddress 0x46
  185. extern         uchar BUF[8];  //接受数据缓存区域
  186. extern        int dis_data;  //变量
  187. extern  int mcy; //进位
  188. void GPIOConfig(void);
  189. void Delay_mms(uint16_t tmp);
  190. void Delay_5us(void);
  191. void GY30_Start(void); //开始信号
  192. void GY30_Stop(void);  //停止信号
  193. void GY30_SendACK(int ack);
  194. int GY30_RecvACK(void);
  195. void GY30_SendByte(uchar dat);
  196. uchar GY30_RecvByte(void);
  197. void Single_Write_GY30(uchar REG_Address);
  198. void Init_GY30(void);
  199. void mread(void);
  200. #endif
ID:1 发表于 2018-7-30 14:42 | 只看该作者
代码不完整需要补全后压缩包后才可获得积分
ID:504136 发表于 2019-4-3 15:36 | 只看该作者
main函数莫得了?
ID:503529 发表于 2019-4-3 20:45
怎么没有了??
ID:570939 发表于 2019-6-28 14:32 | 只看该作者
有主函数的代码吗
